path: root/cpukit/aclocal/check-networking.m4 (follow)
* epiphany: Remove support for this targetSebastian Huber2020-07-051-4/+0
| | | | | | | Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB integration) the Epiphany architecture was obsoleted in RTEMS 5.1. Update #3941.
* m32c: Remove this targetSebastian Huber2018-11-121-1/+1
| | | | Update #3599.
* config: Fix check networkingSebastian Huber2018-10-301-17/+5
| | | | | | This Autoconf macro used cache variables which are not longer present. Update #3409.
* check-networking.m4: Disable legacy stack for x86_64 and epiphanyJoel Sherrill2018-10-181-1/+5
| | | | | x86_64 is 64-bits and too new for the legacy stack to support. epiphany is a small target and cannot compile the legacy (or new) stack.
* Remove make preinstallChris Johns2018-01-251-1/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* Remove AVR portJoel Sherrill2016-01-191-1/+1
| | | | closes #2443.
* Remove H8300 portJoel Sherrill2016-01-041-1/+1
| | | | updates #2452.
* Always disable networking for h8300Joel Sherrill2015-03-061-0/+4
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-1/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-251-2/+2
| | | | | * aclocal/check-networking.m4, aclocal/check-posix.m4: Rebase check on "$host".
* 2009-11-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-191-3/+0
| | | | | * aclocal/check-networking.m4: Do NOT disable networking for the avr and the m32c.
* Remove unix/posix.Ralf Corsepius2009-10-141-3/+0
* 2009-08-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-171-0/+3
| | | | | * aclocal/check-networking.m4: Disable BSD TCP/IP for small memory targets.
* Integrate type checks.Ralf Corsepius2006-11-181-11/+18
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-1/+0
| | | | | | | | | * aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING). * aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING). * automake/amcompile.am: Remove $(ARCH). * wrapup/Makefile.am: Add $(ARCH). Remove compile.am, lib.am. Include amcompile.am.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-211-2/+2
| | | | | | | | | | | | * aclocal/check-multiprocessing.m4: Add m4-quotes. Remove RTEMS_CHECK_CPU. * aclocal/check-itron.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-networking.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/canonical-target-name.m4: Add m4-quotes. * configure.ac: Merge-in former aclocal/check-cpu.m4.
* 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-071-1/+1
| | | | | | * configure.ac: Add missing ',' to librpc activation. Add AC_MSG_CHECKING/AC_MSG_RESULT. * aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-0/+29
* copied over from aclocal/.
