* | 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-27 | 1 | -14/+0 |
| | | | | | | | | | | * configure.ac: Use here-documents to generate cpuopts.tmp. Various fixes and changes to argument processing. Reflect changes to librpc Makefile.ams. * acinclude.m4: Use here-documents to generate cpuopts.tmp. * aclocal/check-itron.m4: Remove HAS_IRON_API. * aclocal/check-multiprocessing.m4: Remove HAS_MP. * aclocal/check-posix.m4: Remove HAS_POSIX_API. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 1 | -2/+2 |
| | | | | | | | | | | | | * aclocal/check-multiprocessing.m4: Add m4-quotes. Remove RTEMS_CHECK_CPU. * aclocal/check-itron.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-networking.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/canonical-target-name.m4: Add m4-quotes. * configure.ac: Merge-in former aclocal/check-cpu.m4. | ||||
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 1 | -0/+37 |
* copied over from aclocal/. |
