path: root/cpukit/acinclude.m4 (follow)
* Remove make preinstallChris Johns2018-01-251-10/+11
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* Add magic to update cpuopt.h.Ralf Corsepius2008-06-301-1/+18
* Add _RTEMS_CPUOPT_INIT, _RTEMS_CPUOPT_FINI.Ralf Corsepius2008-06-301-2/+25
* 2004-04-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-121-1/+1
| | | | | | | | * acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED. * backward/motorola/mc68681.h, backward/motorola/mc68230.h, backward/zilog/z8536.h, backward/zilog/z8036.h, backward/zilog/z8030.h: New. * Makefile.am: Reflect having added new files above.
* 2004-04-05 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-051-1/+1
| | | | | | | | * configure.ac: Add AC_CHECK_SIZEOF([CPU_CONTEXT]..). Add SIZEOF_CPU_CONTEXT to cpuopts.h. Add RTEMS_PROG_CCAS. * acinclude.m4: Use unquoted "here" document to propagate $3 to cpuopts.tmp.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-271-5/+14
| | | | | | | | | | * configure.ac: Use here-documents to generate cpuopts.tmp. Various fixes and changes to argument processing. Reflect changes to librpc Makefile.ams. * acinclude.m4: Use here-documents to generate cpuopts.tmp. * aclocal/check-itron.m4: Remove HAS_IRON_API. * aclocal/check-multiprocessing.m4: Remove HAS_MP. * aclocal/check-posix.m4: Remove HAS_POSIX_API.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-201-0/+12
* acinclude.m4: New. * configure.ac: Don't use AUTOHEADER to generate cpuopts.h. Add local autoheader config.h. * aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST. * aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
