* acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED.
* backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/zilog/z8536.h, backward/zilog/z8036.h,
backward/zilog/z8030.h: New.
* Makefile.am: Reflect having added new files above.
* configure.ac: Add AC_CHECK_SIZEOF([CPU_CONTEXT]..).
Add SIZEOF_CPU_CONTEXT to cpuopts.h.
Add RTEMS_PROG_CCAS.
* acinclude.m4: Use unquoted "here" document to propagate $3 to
cpuopts.tmp.
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
