Since the CBS scheduler is inspired by AQuoSA project for Linux, additional API
(qreslib) compliant with Linux has been created.
Sptest for qreslib included.
This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* Makefile.am: Reformat.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
* include/rtems/bsd/sys/queue.h, include/rtems/bsd/sys/cdefs.h:
Remove.
PR 1762/cpukit
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add generic serial mouse driver and mouse parser. The parser code was
in the pc386 BSP but was generic so cleaned up and placed here.
Serial mouse driver itself is new.
* libmisc/mouse/README, libmisc/mouse/mouse_parser.c,
libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c,
libmisc/mouse/serial_mouse.h: New files.
* include/rtems/btimer.h: New.
* Makefile.am: Add rtems/btimer.h
* libcsupport/include/timerdrv.h: Reflect having split out functions
to rtems/btimer.h.
* Makefile.am, configure.ac: Revert accident commit adding libdbm to
build.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
PR 1555/cpukit
* Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* include/rtems/tar.h, libcsupport/include/tar.h: Remove.
* configure.ac: Require toolchain to provide tar.h.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h:
Use <tar.h> instead of <rtems/tar.h>.
* Doxygen.in: Update.
Misc. fixes.
* doxy-filter: New (Copy of ../tools/build/doxy-filter).
* Makefile.am: Add doxy-filter.
* Makefile.am, configure.ac: Remove support for shttpd.
* aclocal/enable-shttpd.m4: Remove.
* Makefile.am, configure.ac: Remove support for httpd (GoAhead).
* aclocal/enable-httpd.m4: Remove.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
* Makefile.am: Add mghttpd.
* Makefile.am: Unconditional build libblock.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of
mw-fb directory into fb. Relocated files.
* libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files.
* libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h:
Removed.
Add new BSP Boot Command Line helper routines. Recently boot_card()
has grown the ability to have a command line string pointer. These
routines provide an interface to that string.
* Makefile.am, preinstall.am, libmisc/Makefile.am: changed the
references to mw_fb.h into fb.h
* libmisc/mw-fb/mw_fb.h: renamed fb.h
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedlong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
* Makefile.am, preinstall.am, libcsupport/src/mknod.c,
libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am,
libfs/preinstall.am, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c,
libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support.
* libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* Makefile.am, preinstall.am, libcsupport/Makefile.am,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c,
libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/newlibc_init.c, libcsupport/src/sync.c,
libfs/Makefile.am, libfs/src/imfs/deviceio.c,
sapi/include/confdefs.h: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c,
libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c,
libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c,
libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c,
libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c,
libfs/src/imfs/deviceerrno.c: New files.
* libcsupport/src/newlibc.c: Removed.
adapted PPC exception code
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
libblock/include/rtems/flashdisk.h to the installed header list.
* libblock/Makefile.am: Add flashdisk.c to the files to build.
* libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c:
New.
* Makefile.am: Added libmisc/shell/shellconfig.h to the installed
header list.
* libmisc/shell/shell_cmdset.c: Let the Initial command add occur
in any order rather than before any commands have been added. Also
made the command's strings be copies rather than references.
* sapi/src/ioregisterdriver.c: Return the I/O initialise calls result.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* configure.ac, Makefile.am: Add libmd.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* Makefile.am: Remove libcsupport/include/sys/cdefs.h.
* Makefile.am: Reflect addition of include/rtems/bsd/sys/queue.h.
* Makefile.am: Add include/rtems/endian.h.
* Makefile.am: Remove ampolish3.
