path: root/cpukit/Makefile.am (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* PR1908: consolidate libqos code and fix installed header locationGedare Bloom2012-04-231-1/+3
* PR1908: QoS library for CBS schedulerPetr Benes2012-04-151-0/+1
| | | | | | | Since the CBS scheduler is inspired by AQuoSA project for Linux, additional API (qreslib) compliant with Linux has been created. Sptest for qreslib included.
* Revert "Google C++ Testing Framework 1.6.0."Sebastian Huber2012-01-261-1/+0
| | | | This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* Google C++ Testing Framework 1.6.0.Sebastian Huber2012-01-231-0/+1
* 2011-05-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-05-161-50/+62
| | | | * Makefile.am: Reformat.
* 2011-05-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-131-1/+2
| | | | | | * libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files. * libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes above.
* 2011-03-24 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-241-4/+0
| | | | | | * include/rtems/bsd/sys/queue.h, include/rtems/bsd/sys/cdefs.h: Remove. * Makefile.am: Reflect changes above.
* 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-03-141-0/+4
| | | | | | | | | | | PR 1762/cpukit * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add generic serial mouse driver and mouse parser. The parser code was in the pc386 BSP but was generic so cleaned up and placed here. Serial mouse driver itself is new. * libmisc/mouse/README, libmisc/mouse/mouse_parser.c, libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c, libmisc/mouse/serial_mouse.h: New files.
* 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-091-0/+1
| | | | | | | * include/rtems/btimer.h: New. * Makefile.am: Add rtems/btimer.h * libcsupport/include/timerdrv.h: Reflect having split out functions to rtems/btimer.h.
* 2010-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-041-1/+0
| | | | | * Makefile.am, configure.ac: Revert accident commit adding libdbm to build.
* 2010-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-041-0/+1
| | | | | | | * Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c: * posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c, posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c: New files.
* 2010-08-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-131-1/+2
| | | | | | | | * libblock/include/rtems/media.h, libblock/src/media-desc.c, libblock/src/media-dev-ident.c, libblock/src/media-path.c, libblock/src/media-server.c, libblock/src/media.c: New files. * Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes above.
* Remove itron.Ralf Corsepius2010-06-171-1/+1
* 2010-06-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-06-141-1/+3
| | | | | PR 1555/cpukit * Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* 2010-06-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-131-1/+1
| | | | | | | * include/rtems/tar.h, libcsupport/include/tar.h: Remove. * configure.ac: Require toolchain to provide tar.h. * libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h: Use <tar.h> instead of <rtems/tar.h>.
* 2010-06-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-111-0/+3
| | | | | | | * Doxygen.in: Update. Misc. fixes. * doxy-filter: New (Copy of ../tools/build/doxy-filter). * Makefile.am: Add doxy-filter.
* 2010-06-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-091-1/+0
| | | | | * Makefile.am, configure.ac: Remove support for shttpd. * aclocal/enable-shttpd.m4: Remove.
| | | | | * Makefile.am, configure.ac: Remove support for httpd (GoAhead). * aclocal/enable-httpd.m4: Remove.
* 2010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns2010-02-181-0/+23
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required.
* 2009-11-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-221-0/+1
| | | | * Makefile.am: Add mghttpd.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-2/+0
| | | | * Makefile.am: Unconditional build libblock.
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-081-2/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* 2009-08-21 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-211-2/+2
| | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of mw-fb directory into fb. Relocated files. * libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files. * libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Removed.
* 2009-08-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-051-0/+3
| | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add new BSP Boot Command Line helper routines. Recently boot_card() has grown the ability to have a command line string pointer. These routines provide an interface to that string.
* 2009-08-03 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-031-1/+1
| | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am: changed the references to mw_fb.h into fb.h * libmisc/mw-fb/mw_fb.h: renamed fb.h
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-0/+3
| | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add the stringto family of string to number converters. These are error checking wrappers for the strtoXXX methods and do their best to return false if the conversion failed. The error checking required for this is tedious and error prone. Hence better to have in a family of helper routines. * libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h, libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c, libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c, libmisc/stringto/stringtolonglong.c, libmisc/stringto/stringtounsignedchar.c, libmisc/stringto/stringtounsignedint.c, libmisc/stringto/stringtounsignedlong.c, libmisc/stringto/stringtounsignedlonglong.c: New files.
* UpdateThomas Doerfler2009-05-051-1/+5
* removed obsolete references to login.hThomas Doerfler2009-04-141-2/+1
* 2009-03-27 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-03-271-1/+2
| | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c, telnetd/telnetd.c, telnetd/telnetd.h: Generalized login check. * libmisc/shell/login.h, libmisc/shell/login_check.c, libmisc/shell/login_prompt.c: New files. * libmisc/stackchk/check.c: Changed format for blown stack message. * libcsupport/src/libio_sockets.c: Removed superfluous cast. * libnetworking/rtems/ftpfs.h: Documentation.
* Add include/sys/priority.h.Ralf Corsepius2009-02-201-0/+1
* Remove tar.h.Ralf Corsepius2009-02-061-2/+0
* Install libnetworking/sys/uio.h if building for NEWLIB.Ralf Corsepius2009-01-051-0/+2
* Remove include/rtems/stdint.h.Ralf Corsepius2008-12-171-1/+1
* 2008-10-14 Wei Shen <cquark@gmail.com>Joel Sherrill2008-10-141-0/+3
| | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/src/mknod.c, libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am, libfs/preinstall.am, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support. * libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* 2008-09-17 Miao Yan <yanmiaobest@gmail.com>Joel Sherrill2008-09-171-0/+3
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libcsupport/Makefile.am, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c, libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c, libcsupport/src/newlibc_init.c, libcsupport/src/sync.c, libfs/Makefile.am, libfs/src/imfs/deviceio.c, sapi/include/confdefs.h: Merge GSOC project code to add simple device only filesystem (devfs), optionally completely drop out filesystem, and to clean up disabling newlib reentrancy support. This dropped 17K from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K code space. * libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c, libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c, libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c, libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c, libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c, libfs/src/imfs/deviceerrno.c: New files. * libcsupport/src/newlibc.c: Removed.
* added BSP to m68kThomas Doerfler2008-07-111-1/+4
| | | | adapted PPC exception code
* 2008-05-01 Chris Johns <chrisj@rtems.org>Chris Johns2008-05-011-0/+1
| | | | | | | | | * libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c, libblock/src/nvdisk.c: New. A Non-volatile memory disk drive. * Makefile.am, preinstall.am, libblock/Makefile.am: Updated for the NV disk driver.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-141-1/+1
| | | | | | | | * Makefile.am, preinstall.am: Added libblock/include/rtems/flashdisk.h to the installed header list. * libblock/Makefile.am: Add flashdisk.c to the files to build. * libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c: New.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-121-1/+1
| | | | | | | | | * Makefile.am: Added libmisc/shell/shellconfig.h to the installed header list. * libmisc/shell/shell_cmdset.c: Let the Initial command add occur in any order rather than before any commands have been added. Also made the command's strings be copies rather than references. * sapi/src/ioregisterdriver.c: Return the I/O initialise calls result.
* 2007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-121-0/+1
| | | | | | | | | | | | * Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-06-121-0/+1
| | | | * configure.ac, Makefile.am: Add libmd.
* Add shttpd.Ralf Corsepius2007-06-111-0/+1
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-151-3/+0
| | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am, rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h, rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/object.h, score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtems/src/ratemongetstatistics.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c, score/src/objectgetnameasstring.c: New files. * libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-2/+1
| | | | * Makefile.am: Remove libcsupport/include/sys/cdefs.h.
* Reflect introduction of include/rtems/bsd/sys/cdefs.h.Ralf Corsepius2007-05-101-0/+1
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-0/+3
| | | | * Makefile.am: Reflect addition of include/rtems/bsd/sys/queue.h.
* 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-091-0/+2
| | | | * Makefile.am: Add include/rtems/endian.h.
