path: root/cpukit/Doxyfile.in (follow)
* doxygen: Set the Latex generation default to NO.Chris Johns2017-10-121-1/+1
| | | | Closes #3130.
* doxygen: expand specified compiler macros to empty string, so they are ↵Jan Dolezal2014-12-041-3/+4
| | | | ignored by doxygen
* score misc: Score misc: Clean up Doxygen #5Alex Ivanov2012-11-291-1/+2
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-241-1/+1
| | | | | | | * Doxyfile.in, score/include/rtems/score/apimutex.h, score/include/rtems/score/basedefs.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/object.h: Fix some Doxygen warnings.
* 2010-06-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-141-1/+1
| | | | * Doxygen.in: Use @PERL@ instead of hard-coded /usr/bin/perl.
* 2010-06-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-121-2/+2
| | | | | * Doxygen.in: Activate INCLUDE_GRAPH and INCLUDED_BY_GRAPH.
* Update.Ralf Corsepius2010-06-121-476/+947
* 2009-05-15 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-05-151-6/+17
| | | | | | | | | | | | * Doxygen.in: Fixed project name. Added project number. Enabled auto brief. Disabled include graphs. * include/rtems/irq-extension.h, libblock/include/rtems/bdpart.h, libblock/include/rtems/bdbuf.h, libblock/include/rtems/bdpart.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ramdisk.h, libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ramdisk.c: Documentation. * libblock/src/bdpart.c: Documentation. Fixed NULL pointer access.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-171-1/+1
| | | | | | * Doxyfile.in, rtems/mainpage.h, score/include/rtems/system.h: Move to generating Doxygen for more of CPU Kit. * rtems/Doxyfile, score/Doxyfile, score/mainpage.h: Removed.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-171-0/+1079
* configure.ac: Add generated Doxyfile which can process entire set of preinstalled .h files. * Doxyfile.in: New file.
