* wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p.
* score/Makefile.am: Remove macros/README.
* score/include/rtems/score/heap.h, score/src/heap.c,
score/src/heapallocatealigned.c, score/src/heapresizeblock.c:
More size_t for heap-sizes.
score/src/heapallocate.c, score/src/heapextend.c: Use size_t for
heap-sizes.
* libnetworking/resolv.h: Typo fixes. Remove __P().
* rtems/include/rtems/rtems/tasks.h, rtems/src/taskcreate.c:
Use size_t for stack-sizes.
* libnetworking/vm/vm_extern.h: Remove non-implemented/unused
functions.
* configure.ac: Check fo intmax_t, uintptr_t, intptr_t,
pthread.h, pthread_rwlock_t, pthread_barrier_t, pthread_spinlock_t.
* libcsupport/src/gxx_wrappers.c: fix PR#690. Supply
taskvar dtor to plug memory leak. Applied patch attached
to PR#690.
* libcsupport/src/getpagesize.c: New (moved from posix/src).
* posix/src/getpagesize.c: Removed.
* posix/Makefile.am: Remove references to getpagesize.c.
* libcsupport/Makefile.am: Add getpagesize.c.
* posix/src/sysconf.c: Add support for _SC_PAGESIZE (PR 1215).
* posix/src/mqueuesendsupp.c: Remove cast to make broken const cast
visible.
* score/inline/rtems/score/coremsg.inl: More size_t and consts.
* rtems/src/msgqsend.c: Use size_t for sizes.
* rtems/src/msgqurgent.c: Use size_t for sizes.
* rtems/src/msgqbroadcast.c: Use size_t for sizes.
* rtems/src/msgmp.c: Use size_t for sizes.
* rtems/src/msgqsubmit.c: Use size_t for sizes.
* rtems/include/rtems/rtems/msgmp.h: Use size_t for sizes.
* rtems/include/rtems/rtems/message.h: Use size_t for sizes.
* score/inline/rtems/score/coremsg.inl: Use size_t for sizes.
* itron/src/trcv_mbf.c: Use size_t for sizes.
* libmisc/monitor/mon-object.c: Use size_t for sizes.
* libmisc/monitor/mon-server.c: Use size_t for sizes.
* libmisc/monitor/monitor.h: Use size_t for sizes.
* libmisc/mw-fb/mw_uid.c: Use size_t for sizes.
* rtems/src/msgqreceive.c: Use size_t for sizes.
* posix/src/mqueuerecvsupp.c: Use size_t for sizes.
* score/src/coremsgseize.c: Use size_t for sizes.
* posix/include/rtems/posix/mqueue.h: Use size_t for sizes.
* posix/src/mqueuesendsupp.c: Use size_t for sizes.
* score/include/rtems/score/coremsg.h: Use size_t for sizes.
* score/src/coremsgbroadcast.c: Use size_t for sizes.
* score/src/coremsgsubmit.c: Use size_t for sizes.
* libblock/src/show_bdbuf.c: Use inttypes.h macros.
* libmisc/mw-fb/mw_fb.h: Eliminate __u32, __u16.
* libnetworking/libc/gethostbyht.c: Remove warning on unused vars.
Remove isblank (supposed to be provided by libc).
* libblock/src/show_bdbuf.c: Convert from DOS to UNIX.
* score/include/rtems/system.h: Remove __RTEMS_MAJOR__,
__RTEMS_MINOR__, __RTEMS_REVISION__ (moved to cpuopt.h).
* configure.ac: Dynamically derive __ __RTEMS_MAJOR__,
__RTEMS_MINOR__, __RTEMS_REVISION__ from _RTEMS_VERSION.
Add __RTEMS_MAJOR__, __RTEMS_MINOR__,__RTEMS_REVISION__ to cpuopt.h.
#define __RTEMS_MINOR__ 7 (BZ 1206).
fixed synchronization bug between ata.c and bdbuf.c
* libi2c/libi2c.c, libi2c/libi2c.h:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libnetworking/rtems/rtems_mii_ioctl.c,
* libnetworking/rtems/rtems_mii_ioctl.h,
* libnetworking/rtems/rtems_mii_ioctl_kern.c:
* libcsupport/src/error.c: rtems_progname is no longer defined in
the BSP startup since it never held a meaningful value.
* posix/include/aio.h: s/aoi_lio_opcode/aio_lio_opcode/
(BZ 1203).
* backward/rtc.h, backward/vmeintr.h, backward/confdefs.h,
backward/clockdrv.h, backward/itron.h, backward/console.h,
backward/imfs.h, backward/iosupp.h, backward/chain.h,
backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/spurious.h, backward/rtemspppd.h, backward/zilog/z8536.h,
backward/zilog/z8030.h, backward/zilog/z8036.h, backward/dosfs.h,
backward/rtemsdialer.h, backward/asm.h, backward/timerdrv.h,
backward/ringbuf.h, backward/ftpd.h:
Abandon.
* rtems/include/rtems/rtems/types.h: Abandon backward compatibility
types.
* include/rtems/stdint.h: Abandon DEPRECATED_TYPES.
* configure.ac: Abandon DEPRECATED_TYPES/--enable-deprecated.
* Makefile.am: Abandon DEPRECATED_TYPES.
* aclocal/rtems-ampolish.m4: Use am_aux_dir/ampolish3.
* aclocal/rtems-ampolish.m4: Require AM_MAINTAINER_MODE.
* aclocal/rtems-top.m4: Remove RTEMS_AMPOLISH.
* configure.ac: Add RTEMS_AMPOLISH.
* rtems/src/barrierrelease.c: Remove stray rtems_unsigned32.
* libfs/src/imfs/imfs.h: Remove
increment_and_check_linkcounts (unused),
decrement_linkcounts (unused, broken).
* libnetworking/net/route.c, libnetworking/netinet/ip_input.c,
libnetworking/sys/domain.h: Cosmetics from FreeBSD.
* libnetworking/rtems/rtems_glue.c: Remove local
extern strdup.
* libcsupport/include/rtems/libio.h, libcsupport/src/read.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/memfile.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/rtems/rtems_syscall.c:
Use size_t instead of uint32_t for read/write count-args.
* rtems/src/timerserverfirewhen.c: Remove local
extern _Timer_Seconds_chain.
* rtems/src/timerserverfireafter.c: Remove local
extern _Timer_Ticks_chain.
* score/include/rtems/score/object.h, score/src/objectclearname.c,
score/src/objectcopynameraw.c, score/src/objectcopynamestring.c:
Add const qualifiers, use size_t where appropriate.
* score/inline/rtems/score/thread.inl: Add const qualifiers to work
around aliasing effects.
* score/inline/rtems/score/chain.inl: Add const qualifiers (works
around 651 aliasing bugs).
* posix/src/prwlockunlock.c, rtems/Makefile.am,
rtems/src/barrierrelease.c, rtems/src/barrierwait.c,
score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c:
Complete implementation of barrier as the rest of the test code is
now implemented. Also add blocking code to rwlock.
