* posix/include/intr.h, posix/include/rtems/posix/intr.h
posix/inline/rtems/posix/intr.inl.
posix/macros/rtems/posix/intr.inl, posix/src/intr.c:
Remove (Unused, dead).
* posix/Makefile.am: Reflect changes above. Rework.
* posix/Makefile.am: Build devctl.
* rtems/Makefile.am: Rework.
* score/Makefile.am: Rework.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* Makefile.am: Remove doxygen support having accidentially slipped
into, though yesterday's patch.
* Makefile.am, ftpd/Makefile.am, httpd/Makefile.am,
itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am,
librpc/Makefile.am, posix/Makefile.am, pppd/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am,
score/cpu/arm/Makefile.am, score/cpu/avr/Makefile.am,
score/cpu/c4x/Makefile.am, score/cpu/h8300/Makefile.am,
score/cpu/i386/Makefile.am, score/cpu/m68k/Makefile.am,
score/cpu/mips/Makefile.am, score/cpu/no_cpu/Makefile.am,
score/cpu/powerpc/Makefile.am, score/cpu/sh/Makefile.am,
score/cpu/sparc/Makefile.am, score/cpu/unix/Makefile.am,
telnetd/Makefile.am, zlib/Makefile.am: Remove all-local:.
* libcsupport/src/error.c: include and use inttypes.h.
* libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting.
* libcsupport/src/unixlibc.c, libfs/src/imfs/ioman.c: Change
rtems_io_register_name to take a const char *.
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name
* ChangeLog: fixed wrong date of last ChangeLog entry.
PR 849/networking
* librpc/src/rpc/rtems_portmapper.c: Increased stack size
by ARGSIZE to prevent overrun.
* configure.ac: New header guard for cpuopts.h.
* libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and
if_media.h having moved.
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
* libnetworking/Makefile.am: Re-add rtems/rtems_mii_ioctl.h,
rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c.
Add dev/mii/mii.h, net/if_media.h (Moved from c/src/libchip).
* automake/local.am: Remove depend.
* include/rtems/stdint.h: Disable RTEMS proprietary fixed-size types.
* configure.ac: Add RTEMS_NETWORKING to cpuopts.h.
Add RTEMS_DEPRECATED_TYPES to config.h.
Add AC_CONFIG_COMMANDS(preinstall-stamp) magic.
Misc. cleanups.
* libnetworking/net/if.h: Add forward reference declaration to
struct mbuf so ifru_tap callback is properly typed.
* libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE
which needs to be defined so various pieces of the .h files are
visible to device drives.
* libnetworking/Makefile.am: Comment out using
rtems/rtems_mii_ioctl.h, rtems/rtems_mii_ioctl.c,
* pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add
missing copyright notice.
* libi2c/libi2c.c: Include config.h.
* libi2c/libi2c.c, libi2c/libi2c.h,
libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c,
score/src/heap.c: Eliminate obsolete types.
* httpd/Makefile.am: Remove bogus noinst_LIBRARIES.
* libnetworking/Makefile.am,
libnetworking/preinstall.am: Added simple implementation of ethernet
media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys.
* libnetworking/rtems/rtems_mii_ioctl.c,
libnetworking/rtems/rtems_mii_ioctl_kern.c: New files.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
* libnetworking/net/zlib.c: Remove.
* libnetworking/net/zlib.h: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* pppd/Makefile.am: Fix typo.
PR 840/rtems:
* include/rtems/irq.h: Fix several typos.
* configure.ac: Add zlib.
* Makefile.am: Add zlib.
* libnetworking/net/zlib.h, libnetworking/net/zlib.c:
Update from FreeBSD.
* libnetworking/net/ppp.h: Remove.
* libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c:
Reflect changes above. Cosmetics from FreeBSD.
* libnetworking/Makefile.am: Add opt_ppp.h, remove net/ppp.h.
* libnetworking/Makefile.am: Don't install loop.h.
* include/rtems/concat.h: Add EXPAND0, CONCAT0.
* telnetd/Makefile.am: Only build if LIBSHELL is available.
* pppd/Makefile.am, pppd/auth.c, pppd/chap.c, pppd/md5.c, pppd/md5.h,
pppd/pppd.h: Misc. minor fixes.
* configure.ac: Add pppd.
* Makefile.am: Add pppd.
* pppd/Makefile.am:
Install rtemsdialer.h, rtemspppd.h to $(includedir)/rtems.
* pppd/ipxcp.c, pppd/ipxcp.h: Remove (Unused).
* backward/rtemspppd.h, backward/rtemsdialer.h: New.
* Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h.
* Makefile.am: Add telnetd.
* configure.ac: Add telnetd.
* telnetd/icmds.c: Rename register_icmds to
_rtems_telnet_register_icmds. Make main_* functions static.
* telnetd/pty.c: Make many functions static.
Rename rtems_telnetd_maximum_ptys to rtems_pty_maximum_ptys.
* telnetd/pty.h: Reflect changes above.
Rename get_pty to rtems_pty_get. New header guards.
* telnetd/telnetd.c: Reflect changes above.
* telnetd/telnetd.h: New header guards.
* telnet/telnet.h, telnet/telnet.c: Rename
rtems_initialize_telnetd to rtems_telnetd_initialize,
main_telnetd to rtems_telnetd_main,
register_telnetd to rtems_telnetd_register.
* sapi/include/confdefs.h, telnetd/pty.c, telnetd/pty.h: Attempt
to fix MAX_PTYS and provide a real configuration entry. This should
make telnetd some suitable for inclusion in cpukit.
* libfs/src/dosfs/msdos_misc.c: Revert to vers. 1.9.
