2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/rtems-debug.m4: Remove. * aclocal/enable-rtems-debug.m4: New (Split out from rtems-debug.m4). * aclocal/check-rtems-debug.m4: New (Split out from rtems-debug.m4). | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/local.am: Remove "debug". | |||||
2003-08-11 | 2003-08-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* configure.ac: Removed duplicate entry. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-08-08 | 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add libmisc/fsmount/Makefile. | |||||
2003-07-15 | 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* wrapup/Makefile.am: Remove bogus $(MULTISUBDIR). | |||||
2003-07-08 | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* configure.ac: Merge-in librpc/configure.ac. * Makefile.am: Add librpc to SUBDIRS. Remove @subdirs@. | |||||
2003-07-08 | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Merge-in libcsupport/configure.ac. * Makefile.am: Add libcsupport to SUBDIRS. | |||||
2003-07-08 | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+7 | |
* configure.ac: Merge-in posix/configure.ac. Merge-in itron/configure.ac. Misc. cosmetical changes. * Makefile.am: Add posix, itron to SUBDIRS. | |||||
* configure.ac: Merge-in libnetworking/configure.ac. Remove "rtems-" from RTEMS_VERSION. Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]). * Makefile.am: Add libmisc to SUBDIRS. | |||||
* configure.ac: Merge-in libmisc/configure.ac. * Makefile.am: Add libmisc to SUBDIRS. | |||||
* configure.ac: Merge-in libfs/configure.ac. * Makefile.am: Add libfs to SUBDIRS. | |||||
* configure.ac: Merge-in libblock/configure.ac. * Makefile.am: Add libblock to SUBDIRS. | |||||
* configure.ac: Merge-in ada/configure.ac. * Makefile.am: Add ada to SUBDIRS. | |||||
2003-07-03 | 2003-07-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/version.m4: Updated to rtems-ss-20030703. | |||||
2003-05-27 | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
PR 409: * include/Makefile.am: Add rtems/stdint.h * include/rtems/stdint.h: New. | |||||
2003-05-27 | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+7 | |
PR 321: * aclocal/env-rtemscpu.m4: Remove support for profile-variant. * automake/compile.am: Ditto. * automake/local.am: Ditto. | |||||
2003-05-14 | 2003-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Remove LIBSUFFIX_VA (unused). | |||||
2003-05-02 | 2003-05-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+11 | |
* aclocal/env-rtemscpu.m4: Merge-in env-rtemsbsp.m4. * aclocal/env-rtemsbsp.m4: Remove. * aclocal/enable-rtemsbsp.m4: Remove. 2003-05-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/env-rtemscpu.m4: Remove stray '/' in setting up project_libdir. | |||||
2003-04-17 | 2003-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/version.m4: Updated to rtems-ss-20030417. | |||||
2003-04-11 | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/version.m4: Updated to rtems-ss-20030411. | |||||
* aclocal/version.m4: Updated to rtems-ss-20020411. | |||||
2003-03-24 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+21 | |
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+13 | |
2003-02-28 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+27 | |
2003-02-14 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-01-28 | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/version.m4: Updated to rtems-ss-20030128. | |||||
2003-01-23 | 2003-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* automake/local.am: Remove distclean-local. Remove PROJECT_TOOLS. | |||||
2003-01-21 | 2003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused). | |||||
2002-12-19 | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+4 | |
* automake/compile.am: Remove $(RTEMS_BSP_CFLAGS). | |||||
2002-12-14 | 2002-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in from the 2002-12-12 patch). | |||||
2002-12-13 | 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* wrapup/Makefile.am: Fix typo in yesterday's patch. | |||||
2002-12-12 | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* wrapup/Makefile.am: Don't create $ARCH. Use install-data-local to install librtemscpu.a | |||||
2002-12-12 | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* wrapup/Makefile.am: Add libmisc. | |||||
* configure.ac: Add AC_CONFIG_SUBDIR(libmisc). | |||||
2002-12-09 | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CHECK_CUSTOM_BSP. * aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP. * aclocal/check-bsps.m4: Remove. | |||||
2002-12-09 | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead. * configure.ac: Require autoconf >= 2.54, automake-1.7.2. | |||||
2002-12-09 | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+10 | |
* wrapup/Makefile.am: Reflect changes to score/. * configure.ac: Reflect changes to score/. | |||||
2002-12-09 | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add AC_SUBST(INLINEdir). | |||||
* wrapup/Makefile.am: Reflect changes to rtems/. * configure.ac: Reflect changes to rtems/. | |||||
* wrapup/Makefile.am: Reflect changes to posix/. Reflect changes to itron/. | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling. | |||||
2002-12-06 | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+12 | |
* automake/multilib.am: Don't include @RTEMS_BSP@.cfg. * automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Hard-code RTEMS_CFLAGS_PROFILE = -pg * aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4. Remove GCCSED. * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. | |||||
* aclocal/rtems-flags.m4: New. | |||||
2002-11-20 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused). | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+6 | |
* aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x. * aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4. | |||||
2002-11-18 | 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* include/rtems/libio.h: Remove. | |||||
2002-11-18 | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/version.m4: Updated to rtems-ss-20021118. | |||||
2002-11-15 | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* include/rtems/userenv.h: Rely upon <limits.h> for _POSIX_LOGIN_NAME_MAX. |
