* Makefile.am: Add preinstall-stamp.
* include/rtems/bspIo.h: Fix cpp-guards, remove references to i386.
* ChangeLog: Deleted duplicate blank line.
* Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove
ITRON_SUBDIRS.
* configure.ac: Rework enable_unixlib handling.
Add RTEMS_MULTILIBS to cpuopts.h.
* include/Makefile.am: Add rtems/fs.h, rtems/userenv.h.
Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h.
* wrapup/Makefile.am: Add install-hook.
Remove SIZE_RTEMS.
* include/rtems/fs.h: New, extracted from libio_.h.
* include/rtems/userenv.h: New. extracted from libio_.h.
* Makefile.am: Readded reference to wrapup.
* wrapup/.cvsignore: Readded.
* include/.cvsignore: New file.
* Makefile.am, configure.ac: Remove references to wrapup subdirectory.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* wrapup/posix/Makefile.am: Add multilib support.
* wrapup/itron/Makefile.am: Add multilib support.
* wrapup/rtems/Makefile.am: Add multilib support.
* Makefile.am: Add multilib support.
* configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy.
* configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron.
Reflect changes to configuration of rtems, score and sapi subdirs.
* configure.in: Remove.
* wrapup/rtems/Makefile.am: Fix comments to make automake-1.5 happy.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* configure.in: AC_DEFINE RTEMS_UNIX if RTEMS_CPU=unix.
* configure.in: Removed error check for enabling macros with
either POSIX or ITRON API.
* wrapup/rtems/Makefile.am: Use PROJECT_TOPdir in path to size_rtems.
* wrapup/itron/Makefile.am, wrapup/posix/Makefile.am,
wrapup/rtems/Makefile.am: Include compile.am
