* aclocal/version.m4: Updated to rtems-ss-20021111.
* ChangeLog: Corrected.
* aclocal/check-bsp-cache.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* aclocal/version.m4: Updated to rtems-20021021-test.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* aclocal/version.m4: Updated to rtems-ss-20021007.
* aclocal/version.m4: Updated to rtems-JUNK.
* aclocal/version.m4: Updated to rtems-ss-20021004.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* aclocal/prog-gnat.m4: New.
* configure.ac: Add ada subdir handling.
* aclocal/bsp-alias.m4: Remove.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* aclocal/version.m4: Updated to rtems-ss-20020807.
* configure.ac: Add missing ',' to librpc activation.
Add AC_MSG_CHECKING/AC_MSG_RESULT.
* aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* configure.ac: Fix bug in librpc activation, having introduced by
yesterday's patch.
* configure.ac: or32 does not currently support librpc.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CONFIG_PER_BSP.
Use AS_IF instead of if/then/else/fi.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* wrapup/Makefile.am: Use libscore.a.
* aclocal/canonicalize-tools.m4: Remove LD.
* automake/lib.am: Remove LD.
* Makefile.am: Put preinstall-stamp into CLEANFILES.
* aclocal/rtems-top.m4: Use with_project_root and MULTIBUILDTOP to
compose PROJECT_TOPdir (Fixes hppa1.1/genoffset problem).
* aclocal/rtems-cpu-subdirs.m4: Removed the or16 port
was just a stub and only the OR32 port is getting worked on.
* wrapup/Makefile.am: LIBBLOCK_OBJS = ../libblock/$(ARCH)/libblock.a.
* automake/compile.am: Use .$(OBJEXT) instead of .o.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of
*.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR).
* automake/lib.am: Use project_libdir instead of
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
* aclocal/rtems-top.m4: Reflect relocation of c/src/exec to cpukit.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* automake/multilib.am: Add install-multi.
* aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting
version.m4.
Add --with-project-root.
Reflect --with-project-root to setting up PROJECT_ROOT.
* aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK).
* aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir.
* aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* configure.ac: RTEMS_TOP(..).
* wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA.
* aclocal/check-bsp-cache.m4: Remove RTEMS_BSP_FAMILY.
* aclocal/project-root.m4: Remove.
* aclocal/enable-multiprocessing.m4: enable_multiprocessing=no.
* aclocal/prog-cc.m4: Remove obsolete comments.
Comment out GCCSED.
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Remove references to RTEMS_BSP.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
Eliminate RTEMS_HAS_MULTIPROCESSING.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* aclocal/subdirs.m4: Remove.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Makefile.am: Include $(top_srcdir)/automake/*.am.
Use aclocal.
* sapi/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/cpu/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/automake/*.am.
* include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
