* | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-21 | 1 | -0/+5 |
| | | | | | * posix/src/keycreate.c, posix/src/killinfo.c: Remove more ITRON references. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-21 | 1 | -0/+6 |
| | | | | | | PR 1581/cpukit * libcsupport/include/rtems/malloc.h, sapi/include/confdefs.h: Remove extra * on function pointer declaration. | ||||
* | 2010-06-21 Peter Dufault <dufault@hda.com> | Joel Sherrill | 2010-06-21 | 1 | -0/+6 |
| | | | | | | PR 1570/cpukit * posix/src/semtimedwait.c: This routine is supposed to return -1/errno NOT the status directly. | ||||
* | 2010-06-21 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-21 | 1 | -0/+7 |
| | | | | | | | PR 1554/cpukit Coverity Id 17 * libi2c/libi2c.c, score/src/objectextendinformation.c: Fix memory leak on error. | ||||
| | | | | | | PR 1559/misc Coverity Id 16 * libmisc/monitor/mon-editor.c: Fix buffer overflow. | ||||
* | 2010-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-20 | 1 | -0/+5 |
| | | | | | * sapi/include/confdefs.h: Add parameters for FIFOs and pipes since they are distinct to the user. | ||||
* | 2010-06-19 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-19 | 1 | -0/+5 |
| | | | | | * sapi/include/confdefs.h: Add CONFIGURE_MAXIMUM_FIFOS to account for resources per FIFO instance. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -0/+1 |
| | | | | * libnetworking/rtems/mkrootfs.h: doxygen cosmetics. | ||||
| | | | | * libnetworking/netinet/if_ether.c: Misc. 64bit fixes from FreeBSD. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -0/+4 |
| | | | | * libfs/src/nfsclient/src/rpcio.c: Misc. 64bit fixes. | ||||
| | | | | * rtems/include/rtems/rtems/object.h: Remove OBJECTS_ITRON_API. | ||||
| | | | | * rtems/src/rtemsobjectidapimaximum.c: Remove OBJECTS_ITRON_API. | ||||
| | | | | * score/include/rtems/score/object.h: Remove OBJECTS_ITRON_API. | ||||
| | | | | * score/include/rtems/score/thread.h: Remove ITRON. | ||||
| | | | | * score/include/rtems/score/interr.h: Remove ITRON. | ||||
| | | | | * rtems/mainpage.h: Remove comment referring to ITRON. | ||||
| | | | | * rtems/src/rtemsobjectgetapiname.c: Remove ITRON. | ||||
| | | | | * sapi/include/rtems/config.h: Remove ITRON. | ||||
| | | | | * score/src/objectapimaximumclass.c: Remove OBJECTS_ITRON_API. | ||||
| | | | | * score/include/rtems/system.h: Remove ITRON_EXTERN. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -1/+2 |
| | | | | * score/src/apiext.c: Remove comment referring to ITRON. | ||||
| | | | | * core/include/rtems/score/object.h: Remove Objects_ITRON_API. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -0/+3 |
| | | | | | | * rtems/src/rtemsobjectgetapiclassname.c, sapi/include/rtems/config.h, sapi/src/exinit.c: Remove RTEMS_ITRON_API conditional blocks. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -0/+2 |
| | | | | | * sapi/Makefile.am: Remove src/itronapi.c. * sapi/src/itronapi.c: Remove. | ||||
* | 2010-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-18 | 1 | -0/+8 |
| | | | | | | | | * score/src/threadsuspend.c, score/src/threadresume.c, score/src/threadreset.c, score/src/threadinitialize.c, score/src/apiext.c, score/include/rtems/score/thread.h, score/include/rtems/score/coresem.h: Remove RTEMS_ITRON_API conditional blocks. | ||||
* | 2010-06-18 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-17 | 1 | -0/+4 |
| | | | | * libfs/src/rfs/rtems-rfs-file-block.c: Clean up uint64_t maths. | ||||
* | 2010-06-18 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-17 | 1 | -0/+6 |
| | | | | | | * libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-file-system.c: Move questionable macros to C functions. | ||||
* | 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -0/+4 |
| | | | | * sapi/include/confdefs.h: Remove ITRON configuration parameters. | ||||
* | Typo. | Joel Sherrill | 2010-06-17 | 1 | -1/+1 |
* | 2010-06-17 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -0/+4 |
| | | | | * sapi/include/confdefs.h: Remove RTEMS_COVERAGE conditionals whi. | ||||
* | 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -0/+6 |
| | | | | | | * score/include/rtems/score/object.h, score/include/rtems/score/thread.h: Remove prototypes for ITRON only methods removed by Ralf. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+88 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/Makefile.am, itron/preinstall.am itron/include/itron.h, itron/include/itronsys/README itron/include/itronsys/eventflags.h, itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h, itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h, itron/include/itronsys/network.h, itron/include/itronsys/port.h, itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h, itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h, itron/include/itronsys/time.h, itron/include/itronsys/types.h, itron/include/itronsys/vmempool.h, itron/include/rtems/itron/README, itron/include/rtems/itron/config.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/intr.h, itron/include/rtems/itron/itronapi.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/network.h, itron/include/rtems/itron/object.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/sysmgmt.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/eventflags.inl, itron/inline/rtems/itron/fmempool.inl, itron/inline/rtems/itron/intr.inl, itron/inline/rtems/itron/mbox.inl, itron/inline/rtems/itron/msgbuffer.inl, itron/inline/rtems/itron/network.inl, itron/inline/rtems/itron/port.inl, itron/inline/rtems/itron/semaphore.inl, itron/inline/rtems/itron/sysmgmt.inl, itron/inline/rtems/itron/task.inl, itron/inline/rtems/itron/time.inl, itron/inline/rtems/itron/vmempool.inl, itron/src/TODO, itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c, itron/src/can_wup.c, itron/src/chg_iXX.c, itron/src/chg_pri.c, itron/src/clr_flg.c, itron/src/cre_flg.c, itron/src/cre_mbf.c, itron/src/cre_mbx.c, itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c, itron/src/cre_sem.c, itron/src/cre_tsk.c, itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c, itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/dis_dsp.c, itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_dsp.c, itron/src/ena_int.c, itron/src/eventflags.c, itron/src/exd_tsk.c, itron/src/ext_tsk.c, itron/src/fmempool.c, itron/src/frsm_tsk.c, itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c, itron/src/get_tid.c, itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c, itron/src/itronintr.c, itron/src/itronsem.c, itron/src/itrontime.c, itron/src/loc_cpu.c, itron/src/mbox.c, itron/src/mboxtranslatereturncode.c, itron/src/msgbuffer.c, itron/src/msgbuffertranslatereturncode.c, itron/src/network.c, itron/src/nget_nod.c, itron/src/nget_ver.c, itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c, itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c, itron/src/pol_flg.c, itron/src/port.c, itron/src/prcv_mbf.c, itron/src/prcv_mbx.c, itron/src/preq_sem.c, itron/src/psnd_mbf.c, itron/src/rcv_mbf.c, itron/src/rcv_mbx.c, itron/src/ref_alm.c, itron/src/ref_cfg.c, itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c, itron/src/ref_sem.c, itron/src/ref_sys.c, itron/src/ref_tsk.c, itron/src/rel_blf.c, itron/src/rel_blk.c, itron/src/rel_wai.c, itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c, itron/src/rot_rdq.c, itron/src/rpl_rdv.c, itron/src/rsm_tsk.c, itron/src/set_flg.c, itron/src/set_tim.c, itron/src/sig_sem.c, itron/src/slp_tsk.c, itron/src/snd_mbf.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/sysmgmt.c, itron/src/tacp_por.c, itron/src/task.c, itron/src/tcal_por.c, itron/src/ter_tsk.c, itron/src/tget_blf.c, itron/src/tget_blk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tslp_tsk.c, itron/src/tsnd_mbf.c, itron/src/twai_flg.c, itron/src/twai_sem.c, itron/src/unl_cpu.c, itron/src/vmempool.c, itron/src/wai_flg.c, itron/src/wai_sem.c, itron/src/wup_tsk.c: Remove (Abandoned). | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+9 |
| | | | | | | | | | * wrapup/Makefile.am, score/Makefile.am: Remove LIBITRON. * score/src/objectallocatebyindex.c, score/src/objectgetbyindex.c, score/src/threadrotatequeue.c: Remove. * Makefile.am: Remove itron. * configure.ac: Remove itron. * aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+2 |
| | | | | | * libfs/src/rfs/rtems-rfs-file-system.h: Revert previous change. Force RTEMS_RFS_VERSION_MASK to be 32bit. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+1 |
| | | | | * libfs/src/rfs/rtems-rfs-rtems-dir.c: Various 64bit fixes. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-format.c: Various 64bit fixes. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-file-system.c: Various 64bit fixes. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-rtems-file.c: Various 64bit fixes. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-buffer.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+5 |
| | | | | * libfs/src/rfs/rtems-rfs-shell.c: Various 64bit fixes. | ||||
* | 2010-06-17 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-06-17 | 1 | -0/+6 |
| | | | | | | libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-block.h: PR 1556. Struct clean up. | ||||
| | | | | * libfs/src/rfs/rtems-rfs-bitmaps-ut.c: Various 64bit fixes. | ||||
* | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-17 | 1 | -0/+4 |
| | | | | * libfs/src/rfs/rtems-rfs-group.c: Various 64bit fixes. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-16 | 1 | -0/+6 |
| | | | | | | PR 1453/cpukit * posix/Makefile.am: newlib uses sysconf() for _CLOCKS_PER_SEC_ so enable it even when POSIX threads are disabled. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 1 | -0/+4 |
| | | | | * libfs/src/rfs/rtems-rfs-file.c: Various 64bit fixes. | ||||
* | 2010-06-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-16 | 1 | -0/+7 |
| | | | | | | | * score/src/objectallocate.c: Add conditionally compiled debug code to printk a message when an object allocation error occurs. This should be helpful in identifying when a ported package required more resources. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 1 | -0/+1 |
| | | | | * libfs/src/rfs/rtems-rfs-inode.c: Various 64bit fixes. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 1 | -0/+2 |
| | | | | | * libfs/src/rfs/rtems-rfs-rtems.c: Various 64bit fixes. Add PRIomode_t. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 1 | -0/+5 |
| | | | | | * libfs/src/rfs/rtems-rfs-buffer-bdbuf.c: Various 64bit fixes. | ||||
* | 2010-06-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-16 | 1 | -0/+10 |
| | | | | | | | | | | | | | | PR 1556/cpukit * libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs-inode.h: Rename "struct rtems_rfs_*_t" into "struct _rtems_rfs_*". |
