* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-24 | 1 | -0/+21 | |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+13 | |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-28 | 1 | -0/+27 | |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-14 | 1 | -0/+4 | |
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030128. | |||||
* | 2003-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 1 | -0/+5 | |
| | | | | | * automake/local.am: Remove distclean-local. Remove PROJECT_TOOLS. | |||||
* | 2003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-21 | 1 | -0/+5 | |
| | | | | | * automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused). | |||||
* | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-19 | 1 | -1/+4 | |
| | | | | * automake/compile.am: Remove $(RTEMS_BSP_CFLAGS). | |||||
* | 2002-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-14 | 1 | -0/+5 | |
| | | | | | * wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in from the 2002-12-12 patch). | |||||
* | 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-13 | 1 | -0/+4 | |
| | | | | * wrapup/Makefile.am: Fix typo in yesterday's patch. | |||||
* | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-12 | 1 | -0/+5 | |
| | | | | | * wrapup/Makefile.am: Don't create $ARCH. Use install-data-local to install librtemscpu.a | |||||
* | 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-12 | 1 | -0/+4 | |
| | | | | * wrapup/Makefile.am: Add libmisc. | |||||
| | | | | * configure.ac: Add AC_CONFIG_SUBDIR(libmisc). | |||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -0/+6 | |
| | | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CHECK_CUSTOM_BSP. * aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP. * aclocal/check-bsps.m4: Remove. | |||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -0/+5 | |
| | | | | | * wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead. * configure.ac: Require autoconf >= 2.54, automake-1.7.2. | |||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -0/+10 | |
| | | | | | * wrapup/Makefile.am: Reflect changes to score/. * configure.ac: Reflect changes to score/. | |||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -0/+4 | |
| | | | | * configure.ac: Add AC_SUBST(INLINEdir). | |||||
| | | | | | * wrapup/Makefile.am: Reflect changes to rtems/. * configure.ac: Reflect changes to rtems/. | |||||
| | | | | | * wrapup/Makefile.am: Reflect changes to posix/. Reflect changes to itron/. | |||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 1 | -0/+4 | |
| | | | | * automake/compile.am: Rework *FLAGS, AM_*FLAGS handling. | |||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 1 | -0/+12 | |
| | | | | | | | | | | | | * automake/multilib.am: Don't include @RTEMS_BSP@.cfg. * automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Hard-code RTEMS_CFLAGS_PROFILE = -pg * aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4. Remove GCCSED. * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. | |||||
| | | | | * aclocal/rtems-flags.m4: New. | |||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-20 | 1 | -0/+4 | |
| | | | | * automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused). | |||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 1 | -1/+6 | |
| | | | | | * aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x. * aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4. | |||||
* | 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-18 | 1 | -0/+4 | |
| | | | | * include/rtems/libio.h: Remove. | |||||
* | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-18 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021118. | |||||
* | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-15 | 1 | -0/+5 | |
| | | | | | * include/rtems/userenv.h: Rely upon <limits.h> for _POSIX_LOGIN_NAME_MAX. | |||||
* | 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-15 | 1 | -0/+6 | |
| | | | | | | * aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS. * automake/compile.am: Acknowledge configuration-time CFLAGS. Remove CFLAGS_DEFAULT. | |||||
* | 2002-11-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-11 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021111. | |||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 1 | -0/+9 | |
| | | | | * ChangeLog: Corrected. | |||||
* | 2002-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-30 | 1 | -0/+4 | |
| | | | | * aclocal/check-bsp-cache.m4: Remove. | |||||
* | 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-29 | 1 | -0/+4 | |
| | | | | * aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER. | |||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 1 | -0/+4 | |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
* | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-21 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-20021021-test. | |||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 | |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
* | 2002-10-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-07 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021007. | |||||
* | 2002-10-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-04 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-JUNK. | |||||
* | 2002-10-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-04 | 1 | -4/+0 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021004. | |||||
* | 2002-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-29 | 1 | -0/+7 | |
| | | | | | | | * score/include/Makefile.am: Remove cpuopt.h generation. * configure.ac: Correct package name. Don't build ada if POSIX is disabled. Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap. | |||||
* | 2002-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-22 | 1 | -0/+5 | |
| | | | | | * aclocal/prog-gnat.m4: New. * configure.ac: Add ada subdir handling. | |||||
* | 2002-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-20 | 1 | -0/+4 | |
| | | | | * aclocal/bsp-alias.m4: Remove. | |||||
* | Fix ChangeLog. | Ralf Corsepius | 2002-08-13 | 1 | -5/+0 | |
* | 2002-08-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-08 | 1 | -0/+5 | |
| | | | | | * setup.def, binutils/base-binutils.add, binutils/target-binutils.add: Updated to binutils 2.13 which has no known issues. | |||||
* | 2002-08-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-07 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020807. | |||||
* | 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-07 | 1 | -0/+6 | |
| | | | | | | * configure.ac: Add missing ',' to librpc activation. Add AC_MSG_CHECKING/AC_MSG_RESULT. * aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU. | |||||
* | 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-07 | 1 | -0/+5 | |
| | | | | | * configure.ac: Fix bug in librpc activation, having introduced by yesterday's patch. | |||||
* | 2002-08-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-06 | 1 | -0/+4 | |
| | | | | * configure.ac: or32 does not currently support librpc. |
