* posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/timer.h, posix/src/cond.c,
posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c,
posix/src/keydelete.c, posix/src/keygetspecific.c,
posix/src/keyrundestructors.c, posix/src/keysetspecific.c,
posix/src/killinfo.c, posix/src/mqueue.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c,
posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c, posix/src/psignal.c,
posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c,
posix/src/sysconf.c: Convert to using c99 fixed size types.
* score/include/rtems/system.h: include <stdint.h>.
PR/589 rtems
* include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h).
* libcsupport/src/malloc.c: Remove lvalue casts.
* libcsupport/include/chain.h, libcsupport/include/clockdrv.h,
libcsupport/include/ringbuf.h, libcsupport/include/spurious.h,
libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h,
libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c,
libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c,
libcsupport/src/error.c, libcsupport/src/libio.c,
libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c,
libcsupport/src/no_libc.c, libcsupport/src/termios.c,
libcsupport/src/termiosreserveresources.c: Convert to using c99
fixed-size types.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c,
libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* libnetworking/net/radix.c: Remove warning.
* libmisc/shell/cmds.c: Remove warning.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate
warnings. Explicitly defeat __STRICT_ANSI__ since both
legitimately use routines beyond ANSI.
* libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
Add cast to avoid type punning warning in gcc 3.3.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
PR 584/RTEMS
* rtems/src/eventtimeout.c: Fix critical section window.
PR 582/core
* posix/src/mqueue.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueueunlink.c: Use memory
from workspace to avoid use of mutex during dispatch disable critical
section. Besides memory for object names should come from the
Workspace anyway.
* aclocal/version.m4: 4.6.99.0.
* libnetworking/Makefile.am: Remove ACLOCAL_AMFLAGS.
PR pppd/564
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the
system use a slow baudrate for the modem or the tcp/ip-packet is
fragmented.
* ChangeLog, rtems/Makefile.am, rtems/include/rtems/rtems/support.h:
Reverse developmental patches accidentally committed.
PR pppd/564
* rtems/Makefile.am, rtems/include/rtems/rtems/support.h: ppp0
Interface lose packets if the system use a slow baudrate for the
modem or the tcp/ip-packet is fragmented.
* ChangeLog: Merge-in libnetworking/ChangeLog.
* libnetworking/ChangeLog: Remove.
* ChangeLog: Merge-in libcsupport/ChangeLog.
* libcsupport/ChangeLog: Remove.
* ChangeLog: Merge-in libblock/ChangeLog, libfs/ChangeLog.
* libblock/ChangeLog, libfs/ChangeLog: Remove.
* ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog.
* libmisc/ChangeLog, librpc/ChangeLog: Remove.
* ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog,
sapi/ChangeLog, rtems/ChangeLog.
* itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog,
rtems/ChangeLog: Remove.
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp).
Add TMPINSTALL_FILES to CLEANFILES.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
* configure.ac: Requires automake >= 1.8.1.
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* wrapup/Makefile.am: Include compile.am.
Use TMP_LIBS instead of LIBS to avoid potential conflicts with
auto*tools' LIBS.
Reflect new locations of libscorecpu*.a
* Makefile.am: Remove AUTOMAKE_FILES.
* automake/compile.am: Replace contents with contents of
automake/amcompile.am.
* automake/amcompile.am, automake/lib.am: Remove.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
Reflect changes to libblock/Makefile.am.
Reflect changes to libcsupport/Makefile.am.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* wrapup/Makefile.am: Reflect changes to library Makefile.ams.
* automake/amcompile.am: New.
* configure.ac: Add subdir-objects, AM_PROG_CC_C_O.
* aclocal/version.m4: Updated to rtems-20031217-test.
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB.
* wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* aclocal/env-rtemscpu.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
