* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
PR 294/rtems
* posix/src/pthread.c: POSIX thread exit handler now confirms that it
created the executing thread before implicitly exitting it.
* libmisc/stackchk/check.c: Spacing.
* libnetworking/Makefile.am: Don't include subdirs.am.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
* librpc/src/xdr/xdr_float.c: Add __AVR__.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
PR 676/networking
* libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead
of DNS servers.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
PR 609/rtems
* score/src/threaddispatch.c: Close race condition between
_Thread_Dispatch and _Thread_Tickle_timeslice.
PR 654/rtems
* score/src/threadinitialize.c: Initialize the per thread watchdog
timer. When the thread control block is reused, we cannot depend on
it being zeroed.
PR 641/rtems
* rtems/src/eventsurrender.c: The problem here is that events may be
lost when sent to a task which enters rtems_event_receive() with options
set to wait with a timeout and to return on receipt of any event. The
events are sent from an interrupt source such as a timer service
routine. If more than one set of events is sent to the task before it
returns, the first event set may be overwritten.
PR 661/rtems
* score/src/objectmp.c: Fix invalid dereference.
PR 660/rtems
* score/cpu/m68k/rtems/score/m68k.h, score/cpu/mips/cpu_asm.S,
score/src/threadinitialize.c, score/src/threadstackallocate.c: Check
for overflow when allocating stack.
PR 659/rtems
* score/src/heapsizeofuserarea.c: Check that address specified is in
the heap.
PR rtems/652
* rtems/src/signalsend.c: Return RTEMS_INVALID_NUMBER when sending an
empty signal set.
PR 650/rtems
* score/src/coremsg.c: Check for mathemathical overflow when calculating
amount of memory to allocate for message buffers.
PR 651/core
* rtems/src/taskident.c: Add NULL check for id.
PR 631/rtems
* rtems/src/msgqcreate.c: Return unsatisfied from message_queue_create
when unable to allocate message buffer memory.
PR 628/rtems
* posix/src/killinfo.c, posix/src/pthreadkill.c, posix/src/ptimer1.c,
posix/src/sigaction.c, posix/src/sigaddset.c, posix/src/sigsuspend.c:
Signal set of 0 is supposed to return EINVAL. In addition
timer_create needed to return an error if the clock was not
CLOCK_REALTIME.
PR 629/rtems
* cpukit/src/mqueuecreatesupp.c: Return EINVAL is mq_maxmsg is
<= 0, not <.
PR 626/networking
* libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid
printing leading FFFFFF for byte values > 127.
PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be
static with RTEMS.
* libnetworking/netinet/in.c: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD.
* libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD.
* libnetworking/sys/sysctl.h: Update from FreeBSD.
* libnetworking/sys/socketvar.h: Update from FreeBSD.
* libnetworking/sys/protosw.h: More partial updates from FreeBSD.
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
* libnetworking/sys/socket.h: Further update from FreeBSD
(Add sa_family_t).
* libnetworking/sys/protosw.h: Partial update from FreeBSD.
* libnetworking/sys/socket.h: Partial update from FreeBSD.
* libnetworking/rtems/rtems_syscall.c: Reflect changes to socket.h.
* libnetworking/kern/uipc_socket.c: Partial update from FreeBSD
(Remove adv-clause from copyright notice).
* libnetworking/netinet/igmp_var.h: Partial update from FreeBSD.
* libnetworking/net/bpf.h, libnetworking/net/if.h,
libnetworking/net/if_dl.h, libnetworking/net/if_ppp.h,
libnetworking/net/netisr.h, libnetworking/net/pppcompress.c,
libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/raw_cb.h, libnetworking/net/route.h,
libnetworking/netinet/icmp_var.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h, libnetworking/netinet/in.h,
libnetworking/netinet/in_pcb.h, libnetworking/netinet/in_systm.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/ip_fw.h,
libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_mroute.h,
libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp_debug.h,
libnetworking/netinet/tcp_seq.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/tcp_var.h, libnetworking/netinet/udp_var.h,
libnetworking/nfs/nfs.h, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/buf.h, libnetworking/sys/callout.h,
libnetworking/sys/conf.h, libnetworking/sys/domain.h,
libnetworking/sys/malloc.h, libnetworking/sys/mbuf.h,
libnetworking/sys/mount.h, libnetworking/sys/protosw.h,
libnetworking/sys/queue.h, libnetworking/sys/rtprio.h,
libnetworking/sys/select.h, libnetworking/sys/signalvar.h,
libnetworking/sys/socket.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h, libnetworking/sys/syslog.h,
libnetworking/sys/ucred.h, libnetworking/sys/uio.h,
libnetworking/vm/vm.h, libnetworking/vm/vm_extern.h,
libnetworking/vm/vm_param.h: Use -D_KERNEL instead of -DKERNEL for
greater FreeBSD compliance.
* libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS.
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/sys/sysctl.h: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD.
* libfs/src/imfs/imfs_debug.c, libfs/src/imfs/memfile.c:
Use fprintf(stdout,...) instead of printf.
* libblock/src/ide_part_table.c: Use fprintf(stdout,...) instead of
printf.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
* sapi/include/rtems/sptables.h: Remove _RTEMS_version.
