path: root/contrib (follow)
* Add missing #endif in powerpc/setjmp.SRalf Corsepius2007-09-131-29/+28
* newlib-1.15.0-rtems4.8-20070912.diff.Ralf Corsepius2007-09-121-1/+1
* GCC_RPMREL = 24.Ralf Corsepius2007-09-121-1/+1
* New (Incorporate Eric Norum's altivec patch)Ralf Corsepius2007-09-121-0/+1627
* Regenerate.Ralf Corsepius2007-09-0211-198/+44
* BINUTILS_VERS = 2.18.Ralf Corsepius2007-08-2911-22/+22
| | | | BINUTILS_RPMREL = 1%{?dist}.
* Abandon *-base-binutils packages.Ralf Corsepius2007-08-291-5/+0
* Abandon binutils < 2.13.Ralf Corsepius2007-08-291-9/+0
* 2007-0823 Chris Johns <chisj@rtems.org>Chris Johns2007-08-222-3/+8
| | | | | * mingw-path.nsi: Change the forward slashes to back slashes for Windows.
* 2007-08-20 Chris Johns <chisj@rtems.org>Chris Johns2007-08-2016-287/+632
| | | | | | | | | | | | | | | | | | | | * filewrite.nsi, getparameters.nsi, instance-check.nsi, mingw-path.nsi, sm-dummy.nsi, strslash.nsi, strstr.nsi, options.nsi: Added the shared between the 2 installer scripts. * msys-path.nsi: Fixed the last LF bug. * rtems-autotools.nsi, rtems-tools.nsi: Fixed the instance check, added a start menu, remove pages from target installers. * rtems.ini: Fixed the URL links. Added support link. * rtems_logo.bmp: Trimmed a little more to get a better image. * ba-wrap.sh: Stop on a error. * build-exes.sh: Use the option parameter variables. Change the order the section appear in the installer.
* gdb-6.6-9.Ralf Corsepius2007-08-0910-25/+25
* gdb-6.6-9.Ralf Corsepius2007-08-098-20/+20
* Regenerate.Ralf Corsepius2007-08-091-21/+6
* New.Ralf Corsepius2007-08-0910-0/+2255
* Increment GDB_RPMREL.Ralf Corsepius2007-08-0911-11/+11
* Append %{?dist} to GDB_RPMREL.Ralf Corsepius2007-08-0911-11/+11
* Remove references to base packages.Ralf Corsepius2007-08-091-5/+0
* Remove support for gdb < 6.0.Ralf Corsepius2007-08-091-14/+0
* Remove %{?dist}Ralf Corsepius2007-08-091-1/+1
* GCC_RPMREL = 23. Rebuild against binutils-2.17.90.Ralf Corsepius2007-08-086-52/+40
* GCC_RPMREL = 23. Rebuild against binutils-2.17.90.Ralf Corsepius2007-08-083-26/+20
* Revert to gcc-4.0.3-12, gcc-4.2.1 doesn't buildRalf Corsepius2007-08-083-10/+112
* Regenerate.Ralf Corsepius2007-08-083-2/+8
* Regenerate.Ralf Corsepius2007-08-082-21/+9
* GCC_RPMREL = 23. Rebuild against binutils-2.17.90Ralf Corsepius2007-08-081-1/+1
* Regenerate.Ralf Corsepius2007-08-082-3/+3
* Regenerate.Ralf Corsepius2007-08-082-24/+12
* GCC_RPMREL = 23. Rebuild against binutils-2.17.90Ralf Corsepius2007-08-081-2/+2
* Regenerate.Ralf Corsepius2007-08-081-1/+1
* BINUTILS_RPMREL = 2Ralf Corsepius2007-08-0722-22/+22
* Regenerate.Ralf Corsepius2007-08-072-8/+174
* Enable infos for binutils.Ralf Corsepius2007-08-072-4/+0
* Upgrade to binutils-2.17.90.Ralf Corsepius2007-08-0722-27/+53
* Regenerate.Ralf Corsepius2007-08-0711-0/+2617
* New.Ralf Corsepius2007-08-071-0/+14
* Sync.Ralf Corsepius2007-08-041-3/+3
* GCC_RPMREL = 22.Ralf Corsepius2007-08-041-1/+1
* Update to gcc-core-4.2.1-rtems4.8-20070804.diff.Ralf Corsepius2007-08-041-1/+1
* Add m68k -m528x.Ralf Corsepius2007-08-041-0/+49
* 2007-08-03 Chris Johns <chisj@rtems.org>Chris Johns2007-08-049-138/+218
| | | | | | | | | | | | | | | | * rtems_logo.bmp: Clipped to get the correct proportions in the installer's header. * upload.sh: Install only the specific build installers. * rtems.ini: Change to show the actual web paths. * version: Build 15. * build-exes.sh, msys-path.nsi, rtems-autotools.nsi, rtems-tools.nsi: Fixed MSYS path detection. Fixed the uninstaller registry data. Changed the way the top level is generated. Now all the sections are added no matter what target is specified.
* GCC_RPMREL = 21Ralf Corsepius2007-08-042-12/+108
* Update to newlib-1.15.0-rtems4.8-20070804.diffRalf Corsepius2007-08-0411-11/+11
* Add tar.h.Ralf Corsepius2007-08-041-0/+1492
* 2007-07-28 Chris Johns <chisj@rtems.org>Chris Johns2007-07-2815-72/+1349
| | | | | | | | | | | * README, build-rpms.sh, rtems.ini, build-exes.sh, rtems-tools.nsi: Updated to the new 4.8 build plus a new installer. * autoconf.def, automake.def, ba-wrap.sh, build-autotools.sh, msys-path.nsi, rtems-autotools.nsi, target-section-text, upload.sh, version: New to version 4.8. Autotools is built when installing.
* chmod +x etc/postinstall/libncurses-devel.shRalf Corsepius2007-07-261-0/+1
* Don't use sed -i.Ralf Corsepius2007-07-261-1/+4
