* | Cleanup. | Ralf Corsepius | 2006-10-19 | 1 | -3/+1 |
* | Remove. | Ralf Corsepius | 2006-10-19 | 1 | -60/+0 |
* | Bump GCC_RPMREL | Ralf Corsepius | 2006-10-19 | 2 | -2/+2 |
* | rtems-4.7-h8300-rtems4.7-gcc-4.1.1-5 | Ralf Corsepius | 2006-10-19 | 1 | -2/+2 |
* | rtems-4.7-avr-rtems4.7-gcc-4.0.3-2 | Ralf Corsepius | 2006-10-19 | 1 | -2/+2 |
* | 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-16 | 2 | -2/+6 |
| | | | | * configure.ac: Set RTEMS_API to 4.8. | ||||
* | 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-16 | 3 | -10/+18 |
| | | | | | * autotools/Makefile.am, autotools/automake.add: Update to automake-1.10. | ||||
* | New. | Ralf Corsepius | 2006-09-13 | 2 | -0/+3824 |
* | New file. | Joel Sherrill | 2006-09-08 | 1 | -0/+35 |
* | Default to not building bsps. Too many problems. | Chris Johns | 2006-09-03 | 2 | -10/+15 |
* | Handle the noarch rpms. Dump the file list. | Chris Johns | 2006-08-27 | 1 | -6/+10 |
* | Set the prefix into the MSYS fstab, This is a hack but it works. | Chris Johns | 2006-08-27 | 1 | -0/+48 |
* | Ignore more build output files. | Chris Johns | 2006-08-27 | 1 | -1/+1 |
* | Build the autotools for each RTEMS target. | Chris Johns | 2006-08-27 | 1 | -7/+22 |
* | Move the target list into a shared file. | Chris Johns | 2006-08-27 | 1 | -0/+1 |
* | 2006-08-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-08-23 | 1 | -0/+8 |
| | | | | | | | | * rtems4.7/arm/gcc-sources.add, rtems4.7/h8300/gcc-sources.add, rtems4.7/i386/gcc-sources.add, rtems4.7/m68k/gcc-sources.add, rtems4.7/mips/gcc-sources.add, rtems4.7/powerpc/gcc-sources.add rtems4.7/sh/gcc-sources.add, rtems4.7/sparc/gcc-sources.add rtems4.7/tic4x/gcc-sources.add: Add gcc-4.0.3. | ||||
* | Add gcc-4.0.3 | Ralf Corsepius | 2006-08-23 | 9 | -0/+27 |
* | 2006-08-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-08-23 | 2 | -6/+5 |
| | | | | * gcc/build.add: Revert --disable-libssp etc. hacks. | ||||
* | 2006-08-22 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-08-22 | 1 | -0/+5 |
| | | | | | | * rtems4.7/avr/gcc-sources.add: Add the 4.0.3 patch. * patches/gcc-core-4.0.3-rtems-20060822.diff: The .exe for the versioned execuable for MinGW. | ||||
* | Add the 4.0.3 patch. | Chris Johns | 2006-08-22 | 1 | -0/+3 |
* | The .exe for the versioned execuable for MinGW. | Chris Johns | 2006-08-22 | 1 | -0/+14 |
* | Change the rpm to use the version. | Chris Johns | 2006-08-22 | 1 | -4/+5 |
* | Add a version for rtems. | Chris Johns | 2006-08-22 | 1 | -6/+22 |
| | | | | Add checking messages. | ||||
* | Move the build to host tools out of the target root, | Chris Johns | 2006-08-21 | 1 | -81/+96 |
* | 2006-08-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-21 | 4 | -1/+126 |
| | | | | | | | * rtems4.7/h8300/binutils-sources.add, rtems4.7/m68k/binutils-sources.add: Add h8300 _tinydata patch and bump patch for targets needing it. * patches/binutils-2.17-rtems-20060815.diff: New file. | ||||
* | Fix the path in the batch file to the installed path. | Chris Johns | 2006-08-20 | 1 | -1/+1 |
* | Renamed the spec file. | Chris Johns | 2006-08-18 | 2 | -8/+6 |
* | Updated the specs file. | Chris Johns | 2006-08-18 | 1 | -0/+110 |
* | Move to rtems.specs.in. | Chris Johns | 2006-08-17 | 1 | -111/+0 |
* | Add the rtemsrpms package to RTEMS. | Chris Johns | 2006-08-17 | 11 | -0/+822 |
* | Pickup common.add from $(top_srcdir). | Ralf Corsepius | 2006-08-16 | 2 | -2/+2 |
* | Ignore the build output. | Chris Johns | 2006-08-15 | 1 | -0/+1 |
* | binutils-2.17-rtems-20060812.diff | Ralf Corsepius | 2006-08-12 | 1 | -1/+1 |
* | Remove (Merged into binutils-2.17-rtems-20060812.diff). | Ralf Corsepius | 2006-08-12 | 1 | -13/+0 |
* | Update from binutils-2.17_branch. | Ralf Corsepius | 2006-08-12 | 1 | -0/+520 |
| | | | | Merge bfin patch. | ||||
* | Add bfin | Ralf Corsepius | 2006-08-12 | 1 | -0/+1 |
* | Reset RPMRELS. | Ralf Corsepius | 2006-08-12 | 1 | -3/+3 |
* | 2006-08-11 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-08-11 | 13 | -0/+22555 |
| | | | | | | | | | | | | | * configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target prior to merge. Add ability to disable libssp and libstdcxx-pch which apparently are required to build the Blackfin port. * patches/binutils-2.17-rtems-bfin-20060810.diff, patches/gcc-4.1.1-bfinrtems-20060810a.diff, patches/gdb-6.5-bfinrtems-20060810a.diff, patches/newlib-1.14.0-bfinrtems-20060810a.diff, rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am, rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add, rtems4.7/bfin/gdb-sources.add: New files. | ||||
* | Bump RPMREL. | Ralf Corsepius | 2006-08-10 | 11 | -30/+30 |
* | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-09 | 2 | -0/+5 |
| | | | | * .cvsignore: Add INSTALL. | ||||
* | 2006-08-07 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-08-07 | 1 | -0/+37 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * build.sh: Log the script command lines. * build-rpms.sh: Updated to handle a different build processor to a i686. * build-exes.sh: Removed the tool version as Ralf has removed it from the rpms. 2006-08-05 Chris Johns <chrisj@rtems.org> * build-exes.sh: Update the release tag. 2006-08-04 Chris Johns <chrisj@rtems.org> * build-exes.sh: Updated to support the new installer. * build-rpms.sh: Updated to use common rather than base. More rpmbuild work arounds. * build.sh: Fix the return code when used with tee. * rtems.ini: Updated hello screen. * rtems-tools.nsi: Generate the batch files when installing. * AUTHORS, README: Convert to DOS format. 2006-07-22 Chris Johns <chrisj@rtems.org> * COPYING, build.sh, rtems-license.rtf: Changes to the installer and an extra script to build all. | ||||
* | Log the script command lines. | Chris Johns | 2006-08-07 | 1 | -0/+2 |
* | Updated to handle a different build processor to a i686. | Chris Johns | 2006-08-07 | 1 | -50/+47 |
* | Removed the tool version as Ralf has removed it from the rpms. | Chris Johns | 2006-08-07 | 1 | -5/+6 |
* | Update the release tag. | Chris Johns | 2006-08-05 | 1 | -1/+1 |
* | Updated to support the new installer. | Chris Johns | 2006-08-04 | 1 | -6/+25 |
* | Updated to use common rather than base. More rpmbuild work arounds. | Chris Johns | 2006-08-04 | 1 | -5/+12 |
* | Fix the return code when used with tee. | Chris Johns | 2006-08-04 | 1 | -4/+15 |
* | Updated hello screen. | Chris Johns | 2006-08-04 | 1 | -56/+59 |
* | Generate the batch files when installing. | Chris Johns | 2006-08-04 | 1 | -9/+81 |
