* | Regenerate. | Ralf Corsepius | 2011-01-09 | 14 | -112/+112 |
* | newlib-1.19.0-rtems4.11-20110109.diff | Ralf Corsepius | 2011-01-09 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-01-09 | 14 | -14/+14 |
* | New (Add 32bit double tgamma fixes). | Ralf Corsepius | 2011-01-09 | 1 | -0/+2081 |
* | Update. | Ralf Corsepius | 2011-01-07 | 1 | -65/+72 |
* | New. | Ralf Corsepius | 2011-01-07 | 1 | -0/+2044 |
* | Regenerate. | Ralf Corsepius | 2011-01-07 | 14 | -318/+196 |
* | newlib-1.19.0-rtems4.11-20110107.diff. | Ralf Corsepius | 2011-01-07 | 14 | -210/+70 |
| | | | | Abandon gcc-4.5.0, gcc-4.5.1. | ||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-01-07 | 14 | -42/+42 |
| | | | | | NEWLIB_VERS = 1.19.0. Reset NEWLIB_RPMREL. | ||||
* | Regenerate. | Ralf Corsepius | 2011-01-07 | 14 | -28/+28 |
* | Bump BINUTILS_RPMREL = 2. | Ralf Corsepius | 2011-01-07 | 14 | -14/+14 |
* | Add binutils-2.21-rtems4.11-20110107.diff. | Ralf Corsepius | 2011-01-07 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2011-01-07 | 1 | -0/+75 |
* | Housekeeping. | Ralf Corsepius | 2011-01-07 | 6 | -1460/+0 |
* | Remove. | Ralf Corsepius | 2010-12-26 | 1 | -45/+0 |
* | Regenerate. | Ralf Corsepius | 2010-12-17 | 14 | -137/+137 |
* | gcc-4.5.2 (final). | Ralf Corsepius | 2010-12-17 | 28 | -56/+56 |
* | Rebase patch for gcc-4.5.2. | Ralf Corsepius | 2010-12-17 | 1 | -0/+399 |
* | Update to zlib-1.2.5-1. | Ralf Corsepius | 2010-12-16 | 2 | -5/+5 |
* | Regenerate. | Ralf Corsepius | 2010-12-11 | 14 | -224/+313 |
* | gcc-4.5.2 | Ralf Corsepius | 2010-12-11 | 14 | -0/+98 |
* | GCC_VERS = 4.5.2 | Ralf Corsepius | 2010-12-11 | 14 | -56/+56 |
* | Regenerate. | Ralf Corsepius | 2010-12-11 | 16 | -136/+152 |
* | Binutils-2.21. | Ralf Corsepius | 2010-12-11 | 8 | -24/+24 |
| | | | | | BINUTILS_RPMREL = 0.20101211.0. GCC_RPMREL = 0.20101211.0. | ||||
* | Add fedora 15. | Ralf Corsepius | 2010-12-11 | 1 | -6/+6 |
| | | | | Remove fedora 12. | ||||
* | binutils-2.21. | Ralf Corsepius | 2010-12-09 | 42 | -112/+112 |
* | Regenerate. | Ralf Corsepius | 2010-11-26 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101126.diff | Ralf Corsepius | 2010-11-26 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-11-26 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2010-11-26 | 1 | -0/+6742 |
* | Regenerate. | Ralf Corsepius | 2010-11-09 | 14 | -84/+84 |
* | binutils-2.20.90 | Ralf Corsepius | 2010-11-09 | 28 | -56/+56 |
* | New. Rebase patch against binutils-2.20.90. | Ralf Corsepius | 2010-11-09 | 1 | -0/+76 |
* | Housekeeping. | Ralf Corsepius | 2010-11-06 | 8 | -11614/+0 |
* | Regenerate. | Ralf Corsepius | 2010-10-14 | 1 | -20/+5 |
* | Abandon autoconf < 2.68. | Ralf Corsepius | 2010-10-14 | 1 | -12/+2 |
| | | | | Exclude test 199. | ||||
* | Use xz-compressed tarball except on el5. | Ralf Corsepius | 2010-10-14 | 1 | -7/+2 |
| | | | | Abandon autoconf < 2.68. | ||||
* | Bump AUTOCONF_RPMREL. | Ralf Corsepius | 2010-10-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2010-10-09 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101009.diff | Ralf Corsepius | 2010-10-09 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-09 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2010-10-09 | 1 | -0/+5760 |
* | Regenerate. | Ralf Corsepius | 2010-10-08 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101008.diff. | Ralf Corsepius | 2010-10-08 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-08 | 14 | -14/+14 |
* | Add upstream newlib's complex math. | Ralf Corsepius | 2010-10-08 | 1 | -0/+5754 |
* | Regenerate. | Ralf Corsepius | 2010-10-06 | 14 | -112/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-06 | 14 | -14/+14 |
* | newlib-1.18.0-rtems4.11-20101006.diff. | Ralf Corsepius | 2010-10-06 | 14 | -14/+14 |
* | Add patch from http://sourceware.org/ml/newlib/2010/msg00502.html. | Ralf Corsepius | 2010-10-06 | 1 | -0/+1747 |
