* | Add sparc64. | Ralf Corsepius | 2010-05-21 | 1 | -0/+2 | |
* | New. | Ralf Corsepius | 2010-05-21 | 7 | -0/+364 | |
* | Housekeeping. | Ralf Corsepius | 2010-05-04 | 8 | -50755/+0 | |
* | Remove. | Ralf Corsepius | 2010-05-04 | 1 | -294/+0 | |
* | Regenerate. | Ralf Corsepius | 2010-04-29 | 13 | -166/+166 | |
* | GCC-4.4.4. | Ralf Corsepius | 2010-04-29 | 26 | -78/+78 | |
* | New. | Ralf Corsepius | 2010-04-29 | 1 | -0/+4541 | |
* | Regenerate. | Ralf Corsepius | 2010-04-27 | 13 | -39/+26 | |
* | Regenerate. | Ralf Corsepius | 2010-04-27 | 6 | -24/+18 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-27 | 6 | -6/+6 | |
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -95/+13 | |
* | Abandon gcc-4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -104/+13 | |
| | | | | newlib-1.18.0-rtems4.10-20100426.diff. | |||||
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -186/+104 | |
* | Abandon gcc-g++-4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -39/+0 | |
* | Add missing ; | Ralf Corsepius | 2010-04-26 | 2 | -2/+2 | |
* | New. | Ralf Corsepius | 2010-04-26 | 1 | -0/+1254 | |
* | Abandon 4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -65/+13 | |
| | | | | newlib-1.18.0-rtems4.11-20100423.diff. | |||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-26 | 13 | -13/+13 | |
* | Fix no-brainer bug in previous change. | Ralf Corsepius | 2010-04-26 | 1 | -2/+2 | |
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -117/+234 | |
* | Rename cygwin-gcc-3.4.4.diff inro cygwin-gcc-3.4.4-3.diff. | Ralf Corsepius | 2010-04-25 | 1 | -0/+0 | |
* | New. | Ralf Corsepius | 2010-04-25 | 1 | -0/+12 | |
* | Regenerate. | Ralf Corsepius | 2010-04-25 | 1 | -3/+1 | |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2010-04-25 | 1 | -1/+1 | |
* | Regenerate. | Ralf Corsepius | 2010-04-25 | 1 | -47/+220 | |
* | Refactor patching. | Ralf Corsepius | 2010-04-25 | 2 | -4/+19 | |
* | Revert to gcc-3.4.4. | Ralf Corsepius | 2010-04-25 | 1 | -2/+2 | |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 13 | -0/+13 | |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 5 | -0/+5 | |
* | Require gmp-4.2 if building mpc. | Ralf Corsepius | 2010-04-24 | 1 | -0/+1 | |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 5 | -15/+55 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-24 | 5 | -5/+5 | |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 13 | -78/+91 | |
* | Revert last patch. | Ralf Corsepius | 2010-04-24 | 13 | -13/+13 | |
* | Fix typo in comment. | Ralf Corsepius | 2010-04-24 | 1 | -5/+6 | |
| | | | | | Use %{el6} to identify building for CentOS6/RHEL6. Reflect several packages are missing from RHEL6 Beta. | |||||
* | Regenerate. | Ralf Corsepius | 2010-04-23 | 13 | -104/+195 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-23 | 13 | -13/+13 | |
* | newlib-1.18.0-rtems4.11-20100423.diff. | Ralf Corsepius | 2010-04-23 | 13 | -13/+13 | |
* | New. | Ralf Corsepius | 2010-04-23 | 1 | -0/+1238 | |
* | Add rhel6. | Ralf Corsepius | 2010-04-23 | 1 | -0/+7 | |
* | Abandon freebsd7.2. | Ralf Corsepius | 2010-04-19 | 2 | -4/+0 | |
* | Abandon freebsd7.2 | Ralf Corsepius | 2010-04-19 | 15 | -1407/+0 | |
* | Regenerate. | Ralf Corsepius | 2010-04-19 | 7 | -13/+13 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-19 | 2 | -2/+2 | |
* | Sync with amd64. | Ralf Corsepius | 2010-04-19 | 1 | -1/+1 | |
* | Fix up Source0, Source1-URL. | Ralf Corsepius | 2010-04-19 | 1 | -2/+2 | |
* | New. | Ralf Corsepius | 2010-04-19 | 9 | -0/+1232 | |
* | Add netbsd5.0.2/amd64. | Ralf Corsepius | 2010-04-19 | 1 | -0/+1 | |
* | Add am64 | Ralf Corsepius | 2010-04-19 | 1 | -1/+2 | |
