path: root/contrib (follow)
* Regenerate.Ralf Corsepius2008-08-2810-60/+134
* Bump GCC_RPMREL.Ralf Corsepius2008-08-2810-10/+10
* Regenerate.Ralf Corsepius2008-08-2810-20/+50
* Add rtems4.10.Ralf Corsepius2008-08-281-0/+1
* Bump BINUTILS_RPMREL.Ralf Corsepius2008-08-2810-10/+10
* gcc-4.3.2Ralf Corsepius2008-08-2820-10/+80
* New.Ralf Corsepius2008-08-281-0/+117
* Use URLs for patches.Ralf Corsepius2008-08-2811-11/+11
* Use URLs for patches.Ralf Corsepius2008-08-271-1/+1
* Remove (Obsolete).Ralf Corsepius2008-08-274-357/+0
* Use URLs for patches.Ralf Corsepius2008-08-2711-11/+11
* Abandon gcc-4.3.0.Ralf Corsepius2008-08-2710-90/+20
| | | | | Use URLs for patches. newlib-1.16.0-rtems4.9-20080827.diff.
* Update.Ralf Corsepius2008-08-2710-10/+10
* New.Ralf Corsepius2008-08-272-0/+2082
* Remove.Ralf Corsepius2008-08-271-27/+0
* Remove tic4x (Abandoned).Ralf Corsepius2008-08-272-2/+0
* Remove.Ralf Corsepius2008-08-272-8/+0
* Remove (Abandon).Ralf Corsepius2008-08-275-845/+0
* Use full URLs to patches.Ralf Corsepius2008-08-2710-20/+20
* Abandon rtems4.10/tic4x.Ralf Corsepius2008-08-271-1/+0
* Abandon tic4x.Ralf Corsepius2008-08-271-1/+0
* Remove (Abandoned).Ralf Corsepius2008-08-277-871/+0
* Don't install windmc.1 if windmc is not available.Ralf Corsepius2008-07-271-0/+3
* Remove (Incorporated by upstream.)Ralf Corsepius2008-07-071-11/+0
* New.Ralf Corsepius2008-07-061-0/+11
* Add full URL to patch.Ralf Corsepius2008-07-0521-21/+21
* Add rtems-4.10.Ralf Corsepius2008-07-031-0/+14
* gcc-core-4.3.1-rtems4.9-20080628.diffRalf Corsepius2008-07-032-2/+2
* New.Ralf Corsepius2008-07-0342-0/+12864
* Backup.Ralf Corsepius2008-07-035-15/+47
* Add m68k/cf 5329Ralf Corsepius2008-07-031-0/+117
* Remove 4.3.0.Ralf Corsepius2008-07-0310-79/+9
* Set target to rtems4.10.Ralf Corsepius2008-07-0312-12/+12
* Reset *_RPMREL.Ralf Corsepius2008-07-0312-44/+44
* New.Ralf Corsepius2008-07-0376-0/+1183
* Upgrade to gcc-4.3.1Ralf Corsepius2008-06-091-7/+7
* Add gcc-4.3.1. Abandon gcc-4.2.3.Ralf Corsepius2008-06-099-63/+68
* Upgrade to gcc-4.3.1.Ralf Corsepius2008-06-0910-20/+20
* Do not use string comparisions.Ralf Corsepius2008-06-091-2/+2
* New.Ralf Corsepius2008-06-091-0/+107
* Remove.Ralf Corsepius2008-06-0515-11331/+0
* Bump GCC_RPMREL.Ralf Corsepius2008-06-041-1/+1
* Upgrade to binutils-20080523-1.Ralf Corsepius2008-06-042-3/+5
* Add hack to adjust n/ncr260vt300wppRalf Corsepius2008-06-041-2/+4
* Bump ncurses RPMREL.Ralf Corsepius2008-06-041-1/+1
* BR/R: terminfoRalf Corsepius2008-06-041-0/+3
* Add hack to adjust Eterm-colorRalf Corsepius2008-06-041-1/+1
* Add hack to adjust Eterm-colorRalf Corsepius2008-06-041-0/+4
* New.Ralf Corsepius2008-06-043-0/+63
* Add TERMINFO.Ralf Corsepius2008-06-041-0/+4
