* | Regenerate. | Ralf Corsepius | 2010-11-09 | 14 | -84/+84 |
* | binutils-2.20.90 | Ralf Corsepius | 2010-11-09 | 28 | -56/+56 |
* | New. Rebase patch against binutils-2.20.90. | Ralf Corsepius | 2010-11-09 | 1 | -0/+76 |
* | Housekeeping. | Ralf Corsepius | 2010-11-06 | 8 | -11614/+0 |
* | Regenerate. | Ralf Corsepius | 2010-10-14 | 1 | -20/+5 |
* | Abandon autoconf < 2.68. | Ralf Corsepius | 2010-10-14 | 1 | -12/+2 |
| | | | | Exclude test 199. | ||||
* | Use xz-compressed tarball except on el5. | Ralf Corsepius | 2010-10-14 | 1 | -7/+2 |
| | | | | Abandon autoconf < 2.68. | ||||
* | Bump AUTOCONF_RPMREL. | Ralf Corsepius | 2010-10-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2010-10-09 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101009.diff | Ralf Corsepius | 2010-10-09 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-09 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2010-10-09 | 1 | -0/+5760 |
* | Regenerate. | Ralf Corsepius | 2010-10-08 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101008.diff. | Ralf Corsepius | 2010-10-08 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-08 | 14 | -14/+14 |
* | Add upstream newlib's complex math. | Ralf Corsepius | 2010-10-08 | 1 | -0/+5754 |
* | Regenerate. | Ralf Corsepius | 2010-10-06 | 14 | -112/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-06 | 14 | -14/+14 |
* | newlib-1.18.0-rtems4.11-20101006.diff. | Ralf Corsepius | 2010-10-06 | 14 | -14/+14 |
* | Add patch from http://sourceware.org/ml/newlib/2010/msg00502.html. | Ralf Corsepius | 2010-10-06 | 1 | -0/+1747 |
* | Regenerate. | Ralf Corsepius | 2010-10-04 | 14 | -112/+112 |
* | newlib-1.18.0-rtems4.11-20101004.diff | Ralf Corsepius | 2010-10-04 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-10-04 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2010-10-04 | 1 | -0/+1721 |
* | Add *.spec | Ralf Corsepius | 2010-10-04 | 15 | -0/+15 |
* | Regenerate. | Ralf Corsepius | 2010-09-29 | 1 | -2/+4 |
* | Bump AUTOCONF_RPMREL | Ralf Corsepius | 2010-09-29 | 1 | -1/+1 |
* | Add %bcond_with alltests. | Ralf Corsepius | 2010-09-29 | 1 | -1/+3 |
* | Regenerate. | Ralf Corsepius | 2010-09-23 | 1 | -8/+14 |
* | Add autoconf-2.68. | Ralf Corsepius | 2010-09-23 | 1 | -6/+12 |
* | autoconf-2.68. | Ralf Corsepius | 2010-09-23 | 1 | -1/+1 |
* | Abandon Fedora 11. | Ralf Corsepius | 2010-09-21 | 14 | -85/+0 |
* | New. | Ralf Corsepius | 2010-09-08 | 1 | -0/+595 |
* | Parse condstack in final printing. | Ralf Corsepius | 2010-09-08 | 1 | -1/+13 |
* | Prepend @condstack to @buffer4 lines. | Ralf Corsepius | 2010-09-08 | 1 | -1/+1 |
* | Prepend @condstack to @buffer4 lines. | Ralf Corsepius | 2010-09-08 | 1 | -5/+5 |
* | Simplify %if rules. | Ralf Corsepius | 2010-09-08 | 1 | -12/+4 |
* | Regenerate. | Ralf Corsepius | 2010-09-07 | 1 | -2/+4 |
* | gdb-7.2-rtems4.11-20100907.diff | Ralf Corsepius | 2010-09-07 | 1 | -1/+1 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2010-09-07 | 1 | -1/+1 |
* | Add --enable-sim-trace for powerpc-rtems* | Ralf Corsepius | 2010-09-07 | 1 | -0/+2 |
* | Regenerate. | Ralf Corsepius | 2010-09-07 | 1 | -19/+10 |
* | Bump AUTOMAKE_RPMREL. | Ralf Corsepius | 2010-09-07 | 1 | -1/+1 |
* | Add workaround to mingw shipping an obsolete version of perl. | Ralf Corsepius | 2010-09-07 | 1 | -19/+10 |
| | | | | Remove legacy support for automake < 1.11. | ||||
* | Housekeeping | Ralf Corsepius | 2010-09-07 | 2 | -373/+0 |
* | Regenerate. | Ralf Corsepius | 2010-09-03 | 14 | -42/+98 |
* | Add gdb-7.2 | Ralf Corsepius | 2010-09-03 | 14 | -0/+56 |
* | GDB_VERS = 7.2 | Ralf Corsepius | 2010-09-03 | 14 | -28/+28 |
* | New (gdb-7.1 patches rebased against gdb-7.2) | Ralf Corsepius | 2010-09-03 | 1 | -0/+532 |
* | Abandon Fedora 11. | Ralf Corsepius | 2010-08-28 | 1 | -6/+0 |
