* | Add note on Ada. | Ralf Corsepius | 2006-03-09 | 1 | -0/+5 |
* | Update | Ralf Corsepius | 2006-03-09 | 2 | -3/+27 |
* | Enable fortran and objc | Ralf Corsepius | 2006-03-09 | 1 | -0/+2 |
* | Deactivate PATCH0 (not required for gcc >= 4.1.0 | Ralf Corsepius | 2006-03-08 | 1 | -1/+1 |
* | Activate fortran and objc | Ralf Corsepius | 2006-03-08 | 2 | -0/+4 |
* | New. | Ralf Corsepius | 2006-03-07 | 1 | -0/+4 |
* | Use gcc_rpmvers for subpackage deps. | Ralf Corsepius | 2006-03-07 | 6 | -6/+6 |
* | Use %echo instead of %%echo in %expand | Ralf Corsepius | 2006-03-07 | 1 | -2/+2 |
* | Fix main package name. Update version. | Ralf Corsepius | 2006-03-07 | 1 | -1/+1 |
* | Distribute local *.add files. | Ralf Corsepius | 2006-03-07 | 5 | -0/+32 |
* | Distribute local *.add files. Reflect having renamed *-libc.add into ↵ | Ralf Corsepius | 2006-03-07 | 1 | -2/+9 |
| | | | | *-newlib.add | ||||
* | Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add | Ralf Corsepius | 2006-03-07 | 1 | -1/+2 |
* | Renamed into *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -61/+0 |
* | Renamed from *-libc.add to *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -0/+61 |
* | GCC_VERS = 4.1.0 | Ralf Corsepius | 2006-03-06 | 5 | -6/+5 |
* | Subst gcc_rpmvers for LIB packages. | Ralf Corsepius | 2006-03-06 | 5 | -1/+7 |
* | Remove stray blank in %expand to setup rpmvers. | Ralf Corsepius | 2006-03-06 | 7 | -7/+7 |
* | Add osversion hack | Ralf Corsepius | 2006-03-04 | 1 | -1/+10 |
* | Propagate osversion. | Ralf Corsepius | 2006-03-03 | 1 | -1/+1 |
* | Add gfortran. | Ralf Corsepius | 2006-03-03 | 5 | -0/+10 |
| | | | | Add objc. | ||||
* | Remove --sysroot | Ralf Corsepius | 2006-03-01 | 1 | -1/+3 |
* | gcc-4.1.0 still has issues with mudflap. | Ralf Corsepius | 2006-03-01 | 1 | -2/+2 |
* | Add --with-sysroot (Required by GCC-4.1.0) | Ralf Corsepius | 2006-02-28 | 1 | -0/+1 |
* | Revert to cd'ing into gcc-%{gcc_version} for gcc_update | Ralf Corsepius | 2006-02-27 | 1 | -2/+3 |
* | Fix stupid typo. | Ralf Corsepius | 2006-02-25 | 2 | -2/+2 |
* | Use gcc_rpmvers to setup Version: | Ralf Corsepius | 2006-02-25 | 10 | -10/+10 |
* | GPL. | Ralf Corsepius | 2006-02-25 | 1 | -0/+1 |
* | Add my Copyright blurb. | Ralf Corsepius | 2006-02-25 | 1 | -0/+17 |
* | New. | Ralf Corsepius | 2006-02-25 | 5 | -0/+341 |
* | Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild ↵ | Ralf Corsepius | 2006-02-24 | 1 | -6/+6 |
| | | | | screwing up on %version. | ||||
* | Invoke gcc-%{gcc_version}/configure | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 |
* | Add @PREP@, remove RTEMS version magic | Ralf Corsepius | 2006-02-24 | 1 | -12/+2 |
* | Add gcc-prep.add | Ralf Corsepius | 2006-02-24 | 6 | -6/+18 |
* | Remove no-define foreign from AM_INIT_AUTOMAKE. | Ralf Corsepius | 2006-02-24 | 1 | -2/+2 |
* | New. | Ralf Corsepius | 2006-02-24 | 6 | -0/+29 |
* | Allow shared libgfortran | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2006-02-22 | 12 | -15/+15 |
* | Use gcc_version instead of %version, to work around rpm screwing up on ↵ | Ralf Corsepius | 2006-02-22 | 1 | -6/+6 |
| | | | | %version in mixed-versioned packages. | ||||
* | Run make install-info to get the newlib infos | Ralf Corsepius | 2006-02-22 | 1 | -0/+6 |
* | Cleanup comment on vxaddr2line. | Ralf Corsepius | 2006-02-22 | 1 | -1/+1 |
* | Add ",g" in sed call to propagate _prefix to brp-compress. | Ralf Corsepius | 2006-02-22 | 2 | -2/+2 |
* | Correct /-handling | Ralf Corsepius | 2006-02-22 | 2 | -2/+2 |
* | Remove. | Ralf Corsepius | 2006-02-22 | 18 | -1148/+0 |
* | Remove | Ralf Corsepius | 2006-02-22 | 8 | -500/+0 |
* | Silence the tar calls. | Ralf Corsepius | 2006-02-21 | 2 | -2/+2 |
* | Add @tool_target@-gcc hacks. | Ralf Corsepius | 2006-02-21 | 1 | -0/+2 |
* | Remove @tool_target@-gcc hacks. | Ralf Corsepius | 2006-02-21 | 6 | -12/+0 |
* | Ignore unsupported targets. | Ralf Corsepius | 2006-02-21 | 1 | -2/+2 |
* | Delete refs to *-w32api-sys-root packages in *-gcc.spec.in | Ralf Corsepius | 2006-02-21 | 5 | -1/+6 |
* | Delete refs to *-sys-root packages in *-gcc.spec.in | Ralf Corsepius | 2006-02-21 | 1 | -1/+1 |
