* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 4 | -18/+2787 |
| | | | | | | * rtems4.10/sparc/Makefile.am: Bump RTEMS CPU Kit version. * patches/gcc-ada-4.3.2-rtems4.10-20080910.diff: New file. * patches/gcc-ada-4.2.0-rtems4.8-20070705.diff: Removed. | ||||
* | newlib-1.16.0-rtems4.10-20080925.diff. | Ralf Corsepius | 2008-09-25 | 6 | -10/+10 |
* | Undef __ATTRIBUTE_IMPURE_PTR__. | Ralf Corsepius | 2008-09-25 | 1 | -0/+1053 |
* | Remove *.orig files having crept into patch. | Ralf Corsepius | 2008-09-18 | 1 | -11614/+0 |
* | binutils-2.18.91. | Ralf Corsepius | 2008-09-17 | 30 | -60/+60 |
* | Switch to gdb-6.8-rtems4.10-20080917.diff. | Ralf Corsepius | 2008-09-17 | 30 | -40/+40 |
* | Add patch from http://sourceware.org/ml/gdb-patches/2008-02/msg00472.html | Ralf Corsepius | 2008-09-17 | 1 | -0/+13354 |
* | Switch to gcc-core-4.3.2-rtems4.10-20080917.diff. | Ralf Corsepius | 2008-09-17 | 3 | -4/+4 |
* | Remove MULTILIB_EXTRA_OPTS from gcc/config/rs6000/t-rtems. | Ralf Corsepius | 2008-09-17 | 1 | -0/+122 |
* | Regenerate. | Ralf Corsepius | 2008-09-12 | 21 | -89/+32 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2008-09-12 | 11 | -11/+11 |
* | Update. | Ralf Corsepius | 2008-09-12 | 10 | -10/+10 |
* | Remove (unused). | Ralf Corsepius | 2008-09-12 | 1 | -597/+0 |
* | Merge-in Joels gdb-6.8-sysv-ipc-1.diff. | Ralf Corsepius | 2008-09-12 | 1 | -0/+1304 |
* | GCC_RPMREL = 3 (Rebuild against binutils-2.18.90). | Ralf Corsepius | 2008-09-11 | 10 | -10/+10 |
* | Abandon gcc-4.3.1. | Ralf Corsepius | 2008-09-11 | 9 | -63/+0 |
* | Remove (unused). | Ralf Corsepius | 2008-09-11 | 2 | -185/+0 |
* | Upgrade to binutils-2.18.90. | Ralf Corsepius | 2008-09-11 | 30 | -160/+80 |
* | Remove. | Ralf Corsepius | 2008-09-10 | 3 | -2975/+0 |
* | Upgrade autoconf to 2.63. | Ralf Corsepius | 2008-09-10 | 1 | -2/+2 |
* | Bump RTEMS_API to 4.10. | Ralf Corsepius | 2008-09-10 | 1 | -1/+1 |
* | Remove freebsd6.2, freebsd6.3, rtems4.9. | Ralf Corsepius | 2008-09-10 | 2 | -22/+0 |
* | Remove. | Ralf Corsepius | 2008-09-10 | 133 | -13795/+0 |
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -1/+5 |
| | | | | * AUTHORS: Convert to UNIX CR/LF style. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 4 | -424/+428 |
| | | | | * AUTHORS, COPYING, README: Convert to UNIX CR/LF style. | ||||
* | Add --enable-newlib-io-c99-formats. | Ralf Corsepius | 2008-09-08 | 1 | -0/+3 |
* | Regenerate. | Ralf Corsepius | 2008-09-03 | 39 | -159/+476 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2008-09-03 | 20 | -20/+90 |
* | New. | Ralf Corsepius | 2008-09-03 | 1 | -0/+117 |
* | Remove. | Ralf Corsepius | 2008-09-03 | 1 | -1492/+0 |
* | Regenerate. | Ralf Corsepius | 2008-08-28 | 10 | -60/+134 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-08-28 | 10 | -10/+10 |
* | Regenerate. | Ralf Corsepius | 2008-08-28 | 10 | -20/+50 |
* | Add rtems4.10. | Ralf Corsepius | 2008-08-28 | 1 | -0/+1 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2008-08-28 | 10 | -10/+10 |
* | gcc-4.3.2 | Ralf Corsepius | 2008-08-28 | 20 | -10/+80 |
* | New. | Ralf Corsepius | 2008-08-28 | 1 | -0/+117 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-28 | 11 | -11/+11 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-27 | 1 | -1/+1 |
* | Remove (Obsolete). | Ralf Corsepius | 2008-08-27 | 4 | -357/+0 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-27 | 11 | -11/+11 |
* | Abandon gcc-4.3.0. | Ralf Corsepius | 2008-08-27 | 10 | -90/+20 |
| | | | | | Use URLs for patches. newlib-1.16.0-rtems4.9-20080827.diff. | ||||
* | Update. | Ralf Corsepius | 2008-08-27 | 10 | -10/+10 |
* | New. | Ralf Corsepius | 2008-08-27 | 2 | -0/+2082 |
* | Remove. | Ralf Corsepius | 2008-08-27 | 1 | -27/+0 |
* | Remove tic4x (Abandoned). | Ralf Corsepius | 2008-08-27 | 2 | -2/+0 |
* | Remove. | Ralf Corsepius | 2008-08-27 | 2 | -8/+0 |
* | Remove (Abandon). | Ralf Corsepius | 2008-08-27 | 5 | -845/+0 |
* | Use full URLs to patches. | Ralf Corsepius | 2008-08-27 | 10 | -20/+20 |
* | Abandon rtems4.10/tic4x. | Ralf Corsepius | 2008-08-27 | 1 | -1/+0 |
