* | 2006-07-12 RTEMS | Joel Sherrill | 2006-07-12 | 12 | -10/+141 |
| | | | | | | | | | | | * rtems4.7/arm/gdb-sources.add, rtems4.7/avr/gdb-sources.add, rtems4.7/h8300/gdb-sources.add, rtems4.7/i386/gdb-sources.add, rtems4.7/m68k/gdb-sources.add, rtems4.7/mips/gdb-sources.add, rtems4.7/powerpc/gdb-sources.add, rtems4.7/sh/gdb-sources.add, rtems4.7/sparc/gdb-sources.add, rtems4.7/tic4x/gdb-sources.add: Update gdb to use newer patch. This lets sparc build simulator and mips build at all. * patches/gdb-6.4-rtems-20060712.diff: New file. | ||||
* | Sync. | Ralf Corsepius | 2006-07-11 | 1 | -1/+1 |
* | Rebuild with arm-patch applied. | Ralf Corsepius | 2006-07-11 | 1 | -1/+1 |
* | Use newlib-1.14.0-rtems-20060707.diff | Ralf Corsepius | 2006-07-11 | 1 | -1/+1 |
* | New. Remove arm/endian.h | Ralf Corsepius | 2006-07-11 | 1 | -0/+838 |
* | Add short notice | Ralf Corsepius | 2006-07-11 | 1 | -0/+2 |
* | Remove %define build_infos. | Ralf Corsepius | 2006-07-11 | 1 | -2/+0 |
* | Add binutils-2.17-rtems-20060711.diff. | Ralf Corsepius | 2006-07-11 | 1 | -0/+3 |
* | New. m68k/cpu32 patch. | Ralf Corsepius | 2006-07-11 | 1 | -0/+103 |
* | Sync from freebsd6.1 | Ralf Corsepius | 2006-07-09 | 3 | -38/+43 |
* | Sync. | Ralf Corsepius | 2006-07-08 | 3 | -0/+6 |
* | Update to binutils-2.17, gcc-4.1.1 | Ralf Corsepius | 2006-07-08 | 3 | -6/+6 |
* | Split out GCC. | Ralf Corsepius | 2006-07-07 | 3 | -109/+6 |
* | New. | Ralf Corsepius | 2006-07-07 | 3 | -0/+117 |
* | Split out binutils. | Ralf Corsepius | 2006-07-07 | 6 | -160/+7 |
* | New. | Ralf Corsepius | 2006-07-07 | 4 | -0/+108 |
* | New. | Ralf Corsepius | 2006-07-07 | 2 | -0/+54 |
* | Use relative dirs to automake fragments. | Ralf Corsepius | 2006-07-07 | 10 | -30/+30 |
* | Add leading blank to version string. | Ralf Corsepius | 2006-07-07 | 1 | -1/+1 |
* | Use $(srcdir)/patches/*.diff to make make dist happy | Ralf Corsepius | 2006-07-07 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2006-07-07 | 1 | -1/+1 |
* | Add GCC_OPTS. | Ralf Corsepius | 2006-07-07 | 1 | -0/+1 |
* | Comment out gdb. | Ralf Corsepius | 2006-07-07 | 1 | -3/+3 |
* | Reflex setting up version string has changed in gcc-4.1.0 | Ralf Corsepius | 2006-07-07 | 1 | -1/+6 |
* | Fix stupid typo | Ralf Corsepius | 2006-07-07 | 10 | -10/+10 |
* | Remove. | Ralf Corsepius | 2006-07-06 | 6 | -161/+0 |
* | New. | Ralf Corsepius | 2006-07-06 | 1 | -0/+40 |
* | Remove build_infos | Ralf Corsepius | 2006-07-05 | 1 | -2/+0 |
* | Move %define _prefix inside of %if/%endif | Ralf Corsepius | 2006-07-05 | 1 | -1/+1 |
* | Sync. | Ralf Corsepius | 2006-07-05 | 10 | -82/+50 |
* | New. | Ralf Corsepius | 2006-07-05 | 2 | -0/+147 |
* | Sync with other rtems4.7 targets. | Ralf Corsepius | 2006-07-05 | 10 | -10/+30 |
* | Add patches/*.diff to EXTRA_DIST | Ralf Corsepius | 2006-07-05 | 1 | -0/+1 |
* | New. | Ralf Corsepius | 2006-07-05 | 1 | -0/+822 |
* | Bump version. | Ralf Corsepius | 2006-07-05 | 1 | -1/+1 |
* | Eliminate target_os | Ralf Corsepius | 2006-07-05 | 1 | -19/+0 |
* | Remove AC_CANONICAL_TARGET. | Ralf Corsepius | 2006-07-05 | 1 | -1/+0 |
* | Add --enable-targets. | Ralf Corsepius | 2006-07-05 | 1 | -0/+48 |
* | Add new AC_CONFIG_FILES. | Ralf Corsepius | 2006-07-05 | 1 | -1/+23 |
* | Do not subst build_newlib. | Ralf Corsepius | 2006-07-05 | 1 | -1/+0 |
* | Cleanup EXTRA_DIST | Ralf Corsepius | 2006-07-05 | 1 | -31/+0 |
* | Remove unused constructs. | Ralf Corsepius | 2006-07-05 | 1 | -73/+0 |
* | EXTRA_DIST += ../gcc-prep.add | Ralf Corsepius | 2006-07-05 | 6 | -6/+6 |
* | New. | Ralf Corsepius | 2006-07-05 | 1 | -0/+20 |
* | Remove RPM_OS, rtems/ | Ralf Corsepius | 2006-07-05 | 1 | -2/+1 |
* | Add rtems4.7, freebsd6.1 | Ralf Corsepius | 2006-07-05 | 1 | -0/+2 |
* | Cosmetics. | Ralf Corsepius | 2006-07-05 | 1 | -2/+0 |
* | Package sources by default. | Ralf Corsepius | 2006-07-05 | 30 | -90/+90 |
* | Sync freebsd*/*/Makefile.ams | Ralf Corsepius | 2006-07-05 | 3 | -21/+20 |
* | Reflect changes. | Ralf Corsepius | 2006-07-05 | 6 | -12/+0 |
