* | Add .rh clause to extra_arg. | Ralf Corsepius | 2007-05-17 | 1 | -0/+1 |
* | Add --enable-os-subdir. Bump version to 0.6. | Ralf Corsepius | 2007-05-17 | 1 | -1/+6 |
* | Add --enable-os-subdir. | Ralf Corsepius | 2007-05-17 | 1 | -1/+6 |
* | Add OS_SUBDIR. | Ralf Corsepius | 2007-05-17 | 3 | -12/+14 |
* | Remove (Obsolete). | Ralf Corsepius | 2007-05-16 | 2 | -18218/+0 |
* | New (Re-base patch against gcc-4.2.0 final) | Ralf Corsepius | 2007-05-15 | 1 | -0/+31 |
* | New (merge-in gcc-4.2.0 final patches). | Ralf Corsepius | 2007-05-14 | 1 | -0/+18187 |
* | Comment out cpukit. | Ralf Corsepius | 2007-05-11 | 2 | -10/+12 |
* | Add PATH if prefix != /usr | Ralf Corsepius | 2007-05-11 | 2 | -1/+7 |
* | New. | Ralf Corsepius | 2007-05-10 | 13 | -0/+58 |
* | Add cpukit. | Ralf Corsepius | 2007-05-10 | 11 | -0/+66 |
* | New. | Ralf Corsepius | 2007-05-10 | 6 | -0/+108 |
* | New. | Ralf Corsepius | 2007-05-03 | 1 | -0/+31 |
* | Rebase against gcc-core-4.2.0-20070430 (gcc-4.2.0 rc2) | Ralf Corsepius | 2007-05-01 | 1 | -0/+31 |
* | Update to newlib-1.15.0-rtems4.8-20070413.diff | Ralf Corsepius | 2007-04-14 | 22 | -22/+22 |
* | Add CLOCK_MONOTONIC. | Ralf Corsepius | 2007-04-13 | 1 | -0/+1449 |
| | | | | Sync readlink, usleep with SUSv3. | ||||
* | Add mips .sdata handling from GCC-4.2 | Ralf Corsepius | 2007-04-09 | 1 | -0/+102 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2007-04-09 | 1 | -1/+1 |
* | Upgrade to gcc-core-4.1.2-rtems4.8-20070405.diff | Ralf Corsepius | 2007-04-09 | 1 | -1/+1 |
* | Update. | Ralf Corsepius | 2007-03-28 | 3 | -3/+3 |
* | Upgrade to gcc-4.1.2. Remove rtprio.h from newlib. | Ralf Corsepius | 2007-03-16 | 8 | -16/+16 |
* | Upgrade to newlib-1.15.0-rtems4.8-20070316.diff | Ralf Corsepius | 2007-03-16 | 11 | -11/+11 |
* | New (Eliminate rtprio.h) | Ralf Corsepius | 2007-03-16 | 1 | -0/+1403 |
* | New (Incorporate Joels patch to increase mem-sizes for erc32 sim.) | Ralf Corsepius | 2007-03-06 | 1 | -0/+119 |
* | Add exec_prefix. | Ralf Corsepius | 2007-03-06 | 4 | -8/+9 |
* | Add support for exec_prefix. | Ralf Corsepius | 2007-03-01 | 3 | -5/+8 |
* | Remove (obsolete). | Ralf Corsepius | 2007-02-28 | 2 | -147/+0 |
* | New. | Ralf Corsepius | 2007-02-28 | 1 | -0/+31 |
* | Upgrade to gcc-4.2-20070221 | Ralf Corsepius | 2007-02-28 | 2 | -3/+3 |
* | Remove unused code. | Ralf Corsepius | 2007-02-28 | 1 | -8/+2 |
* | Rebase binutils/gcc | Ralf Corsepius | 2007-02-27 | 4 | -34/+23 |
* | Add BINTUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -1/+1 |
* | Remove _use_internal_dependency_generator 0. | Ralf Corsepius | 2007-02-27 | 2 | -6/+0 |
| | | | | Remove __debug_install_post %{nil}. | ||||
* | Use MKSPEC0. | Ralf Corsepius | 2007-02-27 | 1 | -2/+2 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -0/+2 |
| | | | | Add GCC_PKGVERS. | ||||
* | Upgrade to cygwin-1.5.24-2. | Ralf Corsepius | 2007-02-27 | 1 | -2/+2 |
| | | | | Upgrade to w32api-3.8-1. | ||||
* | Upgrade to gcc-4.1.2. | Ralf Corsepius | 2007-02-27 | 2 | -2/+2 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -1/+3 |
| | | | | | Add GCC_PKGVERS. gcc-4.1.2. | ||||
* | mf-runtime.h is still broken in gcc-4.1.2 | Ralf Corsepius | 2007-02-27 | 1 | -1/+1 |
* | Add freebsd6.2 | Ralf Corsepius | 2007-02-27 | 1 | -2/+5 |
* | New. | Ralf Corsepius | 2007-02-27 | 11 | -0/+263 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 2 | -0/+4 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 1 | -1/+3 |
| | | | | | Add GCC_PKGVERS. Try gcc-4.1.2. | ||||
* | Add MKSPEC0. | Ralf Corsepius | 2007-02-26 | 16 | -15/+18 |
* | Use binutils_pkgvers instead of binutils_version in Source0. | Ralf Corsepius | 2007-02-26 | 17 | -17/+17 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 3 | -4/+4 |
* | Add GDB_PKGVERS. | Ralf Corsepius | 2007-02-26 | 1 | -0/+1 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 2 | -1/+1 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 6 | -0/+7 |
