* | Fix broken info. | Ralf Corsepius | 2008-12-12 | 1 | -0/+178 |
* | Regenerate. | Ralf Corsepius | 2008-12-12 | 2 | -2/+2 |
* | Re-base against upstream newlib. | Ralf Corsepius | 2008-12-12 | 1 | -0/+380 |
* | Regenerate. | Ralf Corsepius | 2008-12-12 | 12 | -35/+35 |
* | newlib-1.16.0.cvs.20081212 | Ralf Corsepius | 2008-12-12 | 23 | -35/+35 |
* | Regenerate. | Ralf Corsepius | 2008-12-06 | 1 | -1/+1 |
* | newlib-1.16.0.cvs.20081205-rtems4.10-20081206.diff. | Ralf Corsepius | 2008-12-06 | 1 | -1/+1 |
* | Add fix for the h8300/msx. | Ralf Corsepius | 2008-12-06 | 1 | -0/+554 |
* | Regenerate. | Ralf Corsepius | 2008-12-05 | 11 | -11/+11 |
* | gcc-core-4.3.2-rtems4.10-20081205.diff. | Ralf Corsepius | 2008-12-05 | 11 | -11/+11 |
* | New. | Ralf Corsepius | 2008-12-05 | 1 | -0/+253 |
* | Regenerate. | Ralf Corsepius | 2008-12-05 | 12 | -37/+37 |
* | GCC_RPMREL = 17, newlib-1.16.0.cvs.20081205. | Ralf Corsepius | 2008-12-05 | 24 | -37/+37 |
* | New. | Ralf Corsepius | 2008-12-05 | 1 | -0/+554 |
* | Fix typo. | Ralf Corsepius | 2008-12-02 | 1 | -1/+1 |
* | Rebuild GCC. | Ralf Corsepius | 2008-12-02 | 1 | -1/+1 |
* | Upgrade binutils. | Ralf Corsepius | 2008-12-02 | 1 | -2/+2 |
* | Remove (Obsolete). | Ralf Corsepius | 2008-11-29 | 2 | -671/+0 |
* | Rebase patch against updated newlib-cvs. | Ralf Corsepius | 2008-11-29 | 1 | -0/+367 |
* | Regenerate. | Ralf Corsepius | 2008-11-28 | 12 | -36/+36 |
* | newlib-1.16.0.cvs.20081128. | Ralf Corsepius | 2008-11-28 | 24 | -36/+36 |
* | Update. | Ralf Corsepius | 2008-11-27 | 1 | -0/+390 |
* | Regenerate. | Ralf Corsepius | 2008-11-27 | 12 | -36/+36 |
* | newlib-1.16.0.cvs.20081127 | Ralf Corsepius | 2008-11-27 | 12 | -12/+12 |
* | newlib-1.16.0.cvs.20081127--rtems4.10-20081127.diff | Ralf Corsepius | 2008-11-27 | 12 | -12/+12 |
* | Bump GCC_RPMREL = 15%{?dist}. | Ralf Corsepius | 2008-11-27 | 12 | -12/+12 |
* | Update to automake-1.10.2 | Ralf Corsepius | 2008-11-27 | 2 | -5/+5 |
* | Regenerate. | Ralf Corsepius | 2008-11-25 | 12 | -36/+36 |
* | Rebase patches against newlib-1.16.0.cvs.20081125. | Ralf Corsepius | 2008-11-25 | 1 | -0/+374 |
* | newlib-1.16.0.cvs.20081125-rtems4.10-20081125.diff. | Ralf Corsepius | 2008-11-25 | 12 | -12/+12 |
* | GCC_RELVER = 14%{?dist}. | Ralf Corsepius | 2008-11-25 | 12 | -24/+24 |
| | | | | NEWLIB_PKGVERS = $(NEWLIB_VERS).cvs.20081125. | ||||
* | newlib-1.16.0.cvs.20081124-rtems4.10-20081124.diff | Ralf Corsepius | 2008-11-25 | 12 | -12/+12 |
* | newlib-1.16.0.cvs.20081124. | Ralf Corsepius | 2008-11-25 | 12 | -24/+24 |
| | | | | GCC_RPMREL = 13%{?dist}. | ||||
* | Add getdents stub. | Ralf Corsepius | 2008-11-24 | 1 | -0/+374 |
* | Regenerate. | Ralf Corsepius | 2008-11-24 | 12 | -36/+36 |
* | GCC_RPMREL = 12%{?dist}. | Ralf Corsepius | 2008-11-24 | 12 | -24/+24 |
* | newlib-1.16.0-rtems4.10-20081120.diff. | Ralf Corsepius | 2008-11-24 | 12 | -12/+12 |
* | Regenerate. | Ralf Corsepius | 2008-11-19 | 12 | -55/+60 |
* | Add NEWLIB_PKGVERS. | Ralf Corsepius | 2008-11-19 | 2 | -0/+2 |
* | Preps for newlib-cvs. | Ralf Corsepius | 2008-11-19 | 12 | -12/+24 |
| | | | | Bump GCC_RPMREL. | ||||
* | Update to gcc-core-4.3.2-rtems4.10-20081119.diff. | Ralf Corsepius | 2008-11-19 | 12 | -43/+36 |
| | | | | Preps for newlib-cvs. | ||||
* | Fix errors having crept in in previous versions. | Ralf Corsepius | 2008-11-19 | 1 | -0/+245 |
* | New. | Ralf Corsepius | 2008-11-19 | 1 | -0/+297 |
| | | | | Rebase newlib-*-rtems4.10 patch against newlib-cvs. | ||||
* | Regenerate. | Ralf Corsepius | 2008-11-19 | 1 | -1/+48 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-19 | 1 | -2/+2 |
| | | | | Activate c++. | ||||
* | Update. | Ralf Corsepius | 2008-11-19 | 6 | -29/+57 |
* | Regenerate. | Ralf Corsepius | 2008-11-10 | 12 | -24/+36 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-10 | 12 | -12/+12 |
* | Upgrade to cygwin-1.5.25-14. | Ralf Corsepius | 2008-11-10 | 1 | -4/+4 |
| | | | | Upgrade to w32api-3.12-1. |
