path: root/contrib (follow)
* Add freebsd8.2Ralf Corsepius2011-02-282-0/+5
* New.Ralf Corsepius2011-02-2724-0/+2773
* Add -mcpu=8540/-mfloat-gprs=double multilib.Ralf Corsepius2011-02-201-19/+46
| | | | Remove -mcpu=601 multilib.
* Add missing brace.Ralf Corsepius2011-02-201-2/+2
* Regenerate.Ralf Corsepius2011-02-2011-11/+11
* Fix typo.Ralf Corsepius2011-02-2014-14/+14
* New.Ralf Corsepius2011-02-201-0/+420
* Regenerate.Ralf Corsepius2011-02-2014-112/+123
* Bump GCC_RPMREL.Ralf Corsepius2011-02-2014-14/+14
* gcc-core-4.5.2-rtems4.11-20110220.diffRalf Corsepius2011-02-2014-14/+14
* New.Ralf Corsepius2011-02-201-0/+5887
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-024-3/+11
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* Add gcc-g++-4.5.2-rtems4.11-20110131.diff.Ralf Corsepius2011-01-3114-0/+14
* Regenerate.Ralf Corsepius2011-01-2914-308/+112
* Bump GCC_RPMREL.Ralf Corsepius2011-01-2914-14/+14
* BR: cloog-ppl-devel on f15.Ralf Corsepius2011-01-291-0/+1
* Update to w32api-3.15-1.Ralf Corsepius2011-01-292-5/+5
* Update to cygwin-1.7.7-1.Ralf Corsepius2011-01-292-5/+5
* Abandon fedora-11, fedora-12, openSUSE-11.0, openSUSE-11.0.Ralf Corsepius2011-01-291-15/+0
* Regenerate.Ralf Corsepius2011-01-0914-112/+112
* newlib-1.19.0-rtems4.11-20110109.diffRalf Corsepius2011-01-0914-14/+14
* Bump GCC_RPMREL.Ralf Corsepius2011-01-0914-14/+14
* New (Add 32bit double tgamma fixes).Ralf Corsepius2011-01-091-0/+2081
* Update.Ralf Corsepius2011-01-071-65/+72
* New.Ralf Corsepius2011-01-071-0/+2044
* Regenerate.Ralf Corsepius2011-01-0714-318/+196
* newlib-1.19.0-rtems4.11-20110107.diff.Ralf Corsepius2011-01-0714-210/+70
| | | | Abandon gcc-4.5.0, gcc-4.5.1.
* Bump GCC_RPMREL.Ralf Corsepius2011-01-0714-42/+42
| | | | | NEWLIB_VERS = 1.19.0. Reset NEWLIB_RPMREL.
* Regenerate.Ralf Corsepius2011-01-0714-28/+28
* Bump BINUTILS_RPMREL = 2.Ralf Corsepius2011-01-0714-14/+14
* Add binutils-2.21-rtems4.11-20110107.diff.Ralf Corsepius2011-01-0714-14/+14
* New.Ralf Corsepius2011-01-071-0/+75
* Housekeeping.Ralf Corsepius2011-01-076-1460/+0
* Remove.Ralf Corsepius2010-12-261-45/+0
* Regenerate.Ralf Corsepius2010-12-1714-137/+137
* gcc-4.5.2 (final).Ralf Corsepius2010-12-1728-56/+56
* Rebase patch for gcc-4.5.2.Ralf Corsepius2010-12-171-0/+399
* Update to zlib-1.2.5-1.Ralf Corsepius2010-12-162-5/+5
* Regenerate.Ralf Corsepius2010-12-1114-224/+313
* gcc-4.5.2Ralf Corsepius2010-12-1114-0/+98
* GCC_VERS = 4.5.2Ralf Corsepius2010-12-1114-56/+56
* Regenerate.Ralf Corsepius2010-12-1116-136/+152
* Binutils-2.21.Ralf Corsepius2010-12-118-24/+24
| | | | | BINUTILS_RPMREL = 0.20101211.0. GCC_RPMREL = 0.20101211.0.
* Add fedora 15.Ralf Corsepius2010-12-111-6/+6
| | | | Remove fedora 12.
* binutils-2.21.Ralf Corsepius2010-12-0942-112/+112
* Regenerate.Ralf Corsepius2010-11-2614-112/+112
* newlib-1.18.0-rtems4.11-20101126.diffRalf Corsepius2010-11-2614-14/+14
* Bump GCC_RPMREL.Ralf Corsepius2010-11-2614-14/+14
* New.Ralf Corsepius2010-11-261-0/+6742
* Regenerate.Ralf Corsepius2010-11-0914-84/+84
