* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 15 | -36/+0 |
* | Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git). | Ralf Corsépius | 2012-02-17 | 395 | -79724/+0 |
* | Remove (Obsolete). | Ralf Corsépius | 2012-02-08 | 1 | -497/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 38 | -149/+0 |
* | Add minimal .gitignore files. | Joel Sherrill | 2012-02-01 | 1 | -0/+1 |
* | Regenerate. | Ralf Corsepius | 2011-12-14 | 16 | -32/+144 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2011-12-14 | 16 | -16/+16 |
* | Disable system-readline on EL5 with gdb >= 7.3.91. | Ralf Corsepius | 2011-12-14 | 1 | -1/+8 |
* | readline-6.1.2-2. | Ralf Corsepius | 2011-12-14 | 3 | -7/+7 |
* | Work-around gdb-7.3.91 bug. | Ralf Corsepius | 2011-12-13 | 1 | -0/+6 |
* | Regenerate. | Ralf Corsepius | 2011-12-13 | 16 | -36/+202 |
* | gdb-7.3.91. | Ralf Corsepius | 2011-12-13 | 32 | -20/+90 |
* | New. | Ralf Corsepius | 2011-12-13 | 1 | -0/+417 |
* | Regenerate. | Ralf Corsepius | 2011-12-12 | 1 | -1/+2 |
* | Adjust Source0. | Ralf Corsepius | 2011-12-12 | 1 | -1/+2 |
* | Regenerate. | Ralf Corsepius | 2011-12-12 | 2 | -9/+20 |
* | Bump AUTOCONF_RPMREL. | Ralf Corsepius | 2011-12-12 | 1 | -3/+3 |
| | | | | Update to automake-1.11.1b. | ||||
* | Fix perl module filtering. | Ralf Corsepius | 2011-12-12 | 2 | -5/+16 |
* | Regenerate. | Ralf Corsepius | 2011-11-24 | 15 | -106/+107 |
* | GCC_RPMREL = 4 | Ralf Corsepius | 2011-11-24 | 13 | -13/+13 |
* | gcc-core-4.6.2-rtems4.11-20111124.diff. | Ralf Corsepius | 2011-11-24 | 15 | -15/+15 |
* | New. | Ralf Corsepius | 2011-11-24 | 1 | -0/+582 |
* | Regenerate. | Ralf Corsepius | 2011-11-24 | 1 | -7/+4 |
* | binutils-2.22, gcc-4.4.6 | Ralf Corsepius | 2011-11-24 | 1 | -4/+4 |
* | Regenerate. | Ralf Corsepius | 2011-11-23 | 6 | -24/+24 |
* | binutils-2.22. | Ralf Corsepius | 2011-11-23 | 6 | -12/+12 |
* | Regenerate. | Ralf Corsepius | 2011-11-22 | 15 | -45/+45 |
* | binutils-2.22. | Ralf Corsepius | 2011-11-22 | 15 | -15/+15 |
* | Regenerate. | Ralf Corsepius | 2011-11-18 | 14 | -98/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-11-18 | 15 | -15/+15 |
* | BR: cloog-devel, ppl-devel for suse12_1. | Ralf Corsepius | 2011-11-18 | 1 | -0/+1 |
* | Regenerate. | Ralf Corsepius | 2011-11-16 | 6 | -60/+72 |
* | Abandon gcc-4.5.0. | Ralf Corsepius | 2011-11-16 | 6 | -18/+0 |
* | GCC_RPMREL = 0.20110802.0 | Ralf Corsepius | 2011-11-16 | 6 | -6/+6 |
* | Regenerate. | Ralf Corsepius | 2011-11-15 | 15 | -105/+195 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-11-15 | 15 | -15/+15 |
* | Preps for suse-12.1 | Ralf Corsepius | 2011-11-15 | 1 | -0/+6 |
* | New. | Ralf Corsepius | 2011-10-30 | 1 | -0/+559 |
* | Regenerate. | Ralf Corsepius | 2011-10-28 | 15 | -172/+172 |
* | Preps for gcc-4.6.2. | Ralf Corsepius | 2011-10-28 | 28 | -84/+93 |
* | Regenerate. | Ralf Corsepius | 2011-10-06 | 15 | -120/+120 |
* | newlib-1.19.0-rtems4.11-20111006.diff | Ralf Corsepius | 2011-10-06 | 15 | -15/+15 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-10-06 | 15 | -15/+15 |
* | New. | Ralf Corsepius | 2011-10-06 | 1 | -0/+6336 |
* | Housekeeping. | Ralf Corsepius | 2011-09-28 | 3 | -11340/+0 |
* | Regenerate. | Ralf Corsepius | 2011-09-05 | 16 | -140/+144 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-09-05 | 15 | -15/+15 |
* | gcc-core-4.5.3-rtems4.11-20110905.diff, gcc-g++-4.5.3-rtems4.11-20110905.diff | Ralf Corsepius | 2011-09-05 | 15 | -30/+30 |
* | New. | Ralf Corsepius | 2011-09-05 | 2 | -0/+6373 |
* | Restore bfin hacks. | Ralf Corsepius | 2011-09-05 | 1 | -4/+9 |
