* | Update. | Ralf Corsepius | 2007-11-14 | 3 | -4/+4 |
* | Remove. | Ralf Corsepius | 2007-11-14 | 2 | -16330/+0 |
* | Add makeinfo hacks. | Ralf Corsepius | 2007-11-14 | 1 | -0/+16245 |
* | gcc-core-4.2.2-rtems4.9-20071114.diff. | Ralf Corsepius | 2007-11-14 | 24 | -26/+26 |
* | Reflect having removed *diffs | Ralf Corsepius | 2007-11-14 | 18 | -54/+18 |
* | Remove. | Ralf Corsepius | 2007-11-14 | 2 | -145/+0 |
* | Add m68k FreeScale mv4 multilibs. | Ralf Corsepius | 2007-11-14 | 1 | -0/+52 |
* | Abandon gcc-4.0.3 | Ralf Corsepius | 2007-11-13 | 9 | -36/+0 |
* | Remove. | Ralf Corsepius | 2007-11-13 | 2 | -204/+0 |
* | backup. | Ralf Corsepius | 2007-11-13 | 10 | -18/+35 |
* | Remove *.origs | Ralf Corsepius | 2007-11-13 | 1 | -6790/+0 |
* | Regenerate. | Ralf Corsepius | 2007-11-13 | 1 | -5/+4 |
* | GCC_RPMREL = 3. | Ralf Corsepius | 2007-11-13 | 1 | -1/+1 |
* | Add gcc-core-3.4.6-rtems4.9-20071111.diff. | Ralf Corsepius | 2007-11-13 | 1 | -4/+1 |
* | New. | Ralf Corsepius | 2007-11-13 | 1 | -0/+6817 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2007-11-12 | 11 | -11/+11 |
* | Exclude %{gcclib}/@tool_target@/%{gcc_version}/include/ssp for avr. | Ralf Corsepius | 2007-11-12 | 1 | -0/+2 |
* | Fix stupid typo. | Ralf Corsepius | 2007-11-12 | 1 | -1/+1 |
* | New. | Ralf Corsepius | 2007-11-12 | 1 | -0/+27 |
* | Abandon gcc-4.0.3, gcc-3.4.6. Switch to gcc-4.0.4. ↵ | Ralf Corsepius | 2007-11-12 | 1 | -5/+2 |
| | | | | gcc-core-4.0.4-rtems4.9-20071111.diff | ||||
* | Abandon gcc-4.0.3. Switch to gcc-4.0.4. | Ralf Corsepius | 2007-11-12 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2007-11-09 | 10 | -170/+10 |
* | gcc-3.4.6-2. | Ralf Corsepius | 2007-11-09 | 1 | -18/+2 |
* | Abandon gcc-4.1.1 | Ralf Corsepius | 2007-11-09 | 11 | -44/+0 |
* | Remove. | Ralf Corsepius | 2007-11-09 | 2 | -80/+0 |
* | Abandon gcc-4.2.1 | Ralf Corsepius | 2007-11-09 | 11 | -44/+0 |
* | Abandon gcc-4.1.2. | Ralf Corsepius | 2007-11-09 | 11 | -44/+0 |
* | Abandon gcc-4.2.0. | Ralf Corsepius | 2007-11-09 | 11 | -44/+0 |
* | Remove. | Ralf Corsepius | 2007-11-09 | 3 | -105/+0 |
* | Remove. | Ralf Corsepius | 2007-11-09 | 1 | -187/+0 |
* | Use gcc-core-4.2.2-rtems4.9-20071109.diff | Ralf Corsepius | 2007-11-09 | 11 | -11/+11 |
* | Remove bogus *.origs. | Ralf Corsepius | 2007-11-09 | 1 | -0/+49 |
* | Fix stupid typo | Ralf Corsepius | 2007-11-04 | 22 | -22/+22 |
* | regenerate | Ralf Corsepius | 2007-11-04 | 22 | -385/+22 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2007-11-04 | 11 | -11/+11 |
* | Update. | Ralf Corsepius | 2007-11-04 | 11 | -44/+11 |
* | New. | Ralf Corsepius | 2007-11-04 | 1 | -0/+24 |
* | Assume gdb >= 6.4 | Ralf Corsepius | 2007-11-01 | 2 | -32/+0 |
* | Remove GDB. | Ralf Corsepius | 2007-11-01 | 1 | -5/+0 |
* | Remove. | Ralf Corsepius | 2007-11-01 | 2 | -160/+0 |
* | gdb-6.7.1-4 | Ralf Corsepius | 2007-11-01 | 21 | -73/+224 |
* | Hard-code -lncurses instead of -ltinfo. | Ralf Corsepius | 2007-10-31 | 1 | -1/+1 |
* | Add hacks to get erc32 building | Ralf Corsepius | 2007-10-31 | 1 | -14/+44 |
* | Cleanups for erc32. | Ralf Corsepius | 2007-10-31 | 2 | -2/+3 |
* | Reflect suse-10.3 having expat in libexpat-devel. | Ralf Corsepius | 2007-10-31 | 1 | -1/+8 |
* | gdb-4.7.1 | Ralf Corsepius | 2007-10-31 | 20 | -11/+41 |
* | Force building against expat | Ralf Corsepius | 2007-10-31 | 1 | -0/+3 |
* | New. | Ralf Corsepius | 2007-10-31 | 1 | -0/+45 |
* | Update. | Ralf Corsepius | 2007-10-17 | 5 | -10/+10 |
* | Remove | Ralf Corsepius | 2007-10-12 | 1 | -45/+0 |
