* .cvsignore: Add install-sh and missing.
* i686-pc-cygwin-binutils.spec.in, i686-pc-cygwin-gcc.spec.in,
i686-pc-cygwin-libs.spec.in, i686-pc-cygwin-mingw.spec.in,
i686-pc-cygwin-w32api.spec.in: New.
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Remove.
* setup.def: Update to current cygwin.
* Makefile.am, configure.ac: Reflect changes above.
* README: New file.
* rtems-apt-conf.spec.in: Add @VERSION@ to Source0.
* Makefile.am, gpg/gpg-pubkey-eac29b6f-3fe1f458, ChangeLog,
vendors.list.d/rtems.list, sources.list.d/rtems-4.6.list,
sources.list.d/rtems-4.7.list, configure.ac, .cvsignore, COPYING,
rtems-apt-conf.spec.in, INSTALL: New.
* Makefile.am: Cosmetics.
* i386-cygwin-gcc.spec.in: Use %_prefix instead of %prefix.
Add gnatlib.
Add %defattr(-,root,root).
Provide virtual packages i386-cygwin-[c++|g++|gnat].
* setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You
must build and install a C only toolset first though.
* .cvsignore: Add entries to .cvsignore.
* setup.def, sparc-solaris-binutils.spec.in: Updated and
used to build sparc-solaris 3.2.1-1 C language only.
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2001-04-16 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Added missing files.
* setup.def: New shot using gcc 3.0.4 RPMs.
* sparc-solaris-binutils.spec.in: Switched to bz2 file.
* sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive
and use find to pick up all files.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-02-08 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: New file.
2001-02-05 Joel Sherrill <joel@OARcorp.com>
* Makefile.am: New file, missed previously.
2004-02-05 Joel Sherrill <joel@OARcorp.com>
* ChangeLog, configure.ac, setup, setup.def,
sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in,
sparc-solaris-libs.spec.in: New files.
* i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for
revision 2.
* i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def:
Updated to current Cygwin versions and fixed some minor nits in
the specifications.
2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* setup.def: Update to binutils-20021117-1.
* i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1.
Adaptations to RH-8.0/rpm-4.1.
Add autom4te*cache.
* i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Modified group.
2001-01-22 Joel Sherrill <joel@OARcorp.com>
i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest
versions and packaging.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-13 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Corrected for missing files.
2001-08-31 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Missed in previous commit.
2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
Add autom4te*cache.
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused
with RTEMS.
* r46kstub.c: Renamed to mips-stub.c.
* mips-stub.c: New file -- was r46kstub.c.
* memlimits.h: New file was limits.h.
* limits.h: Removed.
* r4600.h: Eliminated need for this file.
* README: Updated.
* gdb_if.h: Added CVS Id.
* mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
targeting Cygwin.
