* | Regenerate. | Ralf Corsepius | 2009-03-11 | 13 | -76/+76 |
* | newlib-1.17.0-rtems4.10-20090311.diff. | Ralf Corsepius | 2009-03-11 | 13 | -13/+13 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-03-11 | 13 | -13/+13 |
* | Address __assert etc. | Ralf Corsepius | 2009-03-11 | 1 | -0/+890 |
* | Disable sim on mingw32. | Ralf Corsepius | 2009-03-10 | 2 | -3/+8 |
* | Disable m32c simulator. | Ralf Corsepius | 2009-03-10 | 1 | -0/+5 |
* | Upgrade to gdb-6.8.50 | Ralf Corsepius | 2009-03-10 | 3 | -59/+26 |
* | Update. | Ralf Corsepius | 2009-03-09 | 1 | -2/+123 |
* | Bump release. | Ralf Corsepius | 2009-03-09 | 4 | -8/+11 |
* | newlib/libc/machine/powerpc/times.c: Remove. | Ralf Corsepius | 2009-03-09 | 1 | -0/+730 |
* | Regenerate. | Ralf Corsepius | 2009-02-25 | 1 | -1/+4 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-02-25 | 1 | -1/+1 |
* | Disable lm32 simulator on mingw32. | Ralf Corsepius | 2009-02-25 | 1 | -0/+3 |
* | Regenerate. | Ralf Corsepius | 2009-02-25 | 1 | -1/+6 |
* | Add gdb-6.8.50.20090224-rtems4.10-20090225.diff | Ralf Corsepius | 2009-02-25 | 1 | -0/+5 |
* | New. | Ralf Corsepius | 2009-02-25 | 1 | -0/+17143 |
| | | | | | | Rebase gdb-6.8-rtems4.10-20090122.diff patch against gcc-cvs HEAD. Add lm32 sim. Various fixes to get lm32 sim building. | ||||
* | Regenerate, fix spec file. | Ralf Corsepius | 2009-02-24 | 13 | -26/+65 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | Regenerate. | Ralf Corsepius | 2009-02-24 | 13 | -76/+76 |
* | GCC_RPMREL = 8 | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | newlib-1.17.0-rtems4.10-20090224.diff | Ralf Corsepius | 2009-02-24 | 13 | -13/+13 |
* | * libc/unix/ttyname.c: Sync with newlib-cvs. | Ralf Corsepius | 2009-02-24 | 1 | -0/+686 |
| | | | | * configure.host: Add -DHAVE_BLKSIZE to newlib_cflags. | ||||
* | Regenerate. | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | Use "%{?suse}" >= "10.3" to detect suse | Ralf Corsepius | 2009-02-24 | 1 | -1/+1 |
* | New. | Ralf Corsepius | 2009-02-24 | 1 | -0/+223 |
* | Activate GDB. | Ralf Corsepius | 2009-02-24 | 1 | -6/+5 |
* | Use a gdb-snapshot. | Ralf Corsepius | 2009-02-24 | 1 | -2/+3 |
* | Disable python. | Ralf Corsepius | 2009-02-24 | 1 | -0/+3 |
* | Regenerate. | Ralf Corsepius | 2009-02-23 | 2 | -0/+833 |
* | Update. | Ralf Corsepius | 2009-02-23 | 1 | -2/+2 |
* | binutils-2.19.51-20090222. | Ralf Corsepius | 2009-02-23 | 1 | -2/+2 |
* | Activate GCC-4.3.3 | Ralf Corsepius | 2009-02-23 | 1 | -12/+11 |
* | Add lm32 | Ralf Corsepius | 2009-02-23 | 2 | -0/+5245 |
* | Add lm32. | Ralf Corsepius | 2009-02-22 | 1 | -1/+2 |
* | New. | Ralf Corsepius | 2009-02-22 | 6 | -0/+84 |
* | Add lm32 | Ralf Corsepius | 2009-02-22 | 1 | -0/+1 |
* | New. | Ralf Corsepius | 2009-02-22 | 2 | -0/+136 |
* | Regenerate. | Ralf Corsepius | 2009-02-22 | 1 | -1/+4 |
* | Bump version. | Ralf Corsepius | 2009-02-22 | 1 | -1/+1 |
* | Add @SOURCES@, PATCH0. | Ralf Corsepius | 2009-02-22 | 1 | -1/+2 |
* | Add automake-sources.add. | Ralf Corsepius | 2009-02-22 | 1 | -3/+5 |
* | Regenerate. | Ralf Corsepius | 2009-02-20 | 36 | -94/+94 |
* | Split ttyname.c/ttyname_r.c | Ralf Corsepius | 2009-02-20 | 1 | -0/+651 |
* | Regenerate. | Ralf Corsepius | 2009-02-19 | 14 | -72/+72 |
* | Move %{?dist} handling to rtems4.10/*.am. | Ralf Corsepius | 2009-02-19 | 17 | -66/+66 |
* | Update. | Ralf Corsepius | 2009-02-19 | 12 | -12/+12 |
* | Bump GCC_RPMREL, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-19 | 12 | -24/+24 |
* | 2009-02-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-19 | 1 | -0/+386 |
| | | | | | | | | | * libc/sys/rtems/sys/param.h: Update copyright notice from FreeBSD. Remove HZ. Add #include <sys/priority.h> Remove priority handling (moved to sys/priority.h). Remove CLBYTES (Unused, abandoned in BSD). | ||||
* | Regenerate. | Ralf Corsepius | 2009-02-07 | 24 | -101/+109 |
* | Regenerate. | Ralf Corsepius | 2009-02-06 | 10 | -21/+21 |
