* | Update. | Ralf Corsepius | 2007-03-28 | 3 | -3/+3 |
* | Upgrade to gcc-4.1.2. Remove rtprio.h from newlib. | Ralf Corsepius | 2007-03-16 | 8 | -16/+16 |
* | Upgrade to newlib-1.15.0-rtems4.8-20070316.diff | Ralf Corsepius | 2007-03-16 | 11 | -11/+11 |
* | New (Eliminate rtprio.h) | Ralf Corsepius | 2007-03-16 | 1 | -0/+1403 |
* | New (Incorporate Joels patch to increase mem-sizes for erc32 sim.) | Ralf Corsepius | 2007-03-06 | 1 | -0/+119 |
* | Add exec_prefix. | Ralf Corsepius | 2007-03-06 | 4 | -8/+9 |
* | Add support for exec_prefix. | Ralf Corsepius | 2007-03-01 | 3 | -5/+8 |
* | Remove (obsolete). | Ralf Corsepius | 2007-02-28 | 2 | -147/+0 |
* | New. | Ralf Corsepius | 2007-02-28 | 1 | -0/+31 |
* | Upgrade to gcc-4.2-20070221 | Ralf Corsepius | 2007-02-28 | 2 | -3/+3 |
* | Remove unused code. | Ralf Corsepius | 2007-02-28 | 1 | -8/+2 |
* | Rebase binutils/gcc | Ralf Corsepius | 2007-02-27 | 4 | -34/+23 |
* | Add BINTUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -1/+1 |
* | Remove _use_internal_dependency_generator 0. | Ralf Corsepius | 2007-02-27 | 2 | -6/+0 |
| | | | | Remove __debug_install_post %{nil}. | ||||
* | Use MKSPEC0. | Ralf Corsepius | 2007-02-27 | 1 | -2/+2 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -0/+2 |
| | | | | Add GCC_PKGVERS. | ||||
* | Upgrade to cygwin-1.5.24-2. | Ralf Corsepius | 2007-02-27 | 1 | -2/+2 |
| | | | | Upgrade to w32api-3.8-1. | ||||
* | Upgrade to gcc-4.1.2. | Ralf Corsepius | 2007-02-27 | 2 | -2/+2 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-27 | 1 | -1/+3 |
| | | | | | Add GCC_PKGVERS. gcc-4.1.2. | ||||
* | mf-runtime.h is still broken in gcc-4.1.2 | Ralf Corsepius | 2007-02-27 | 1 | -1/+1 |
* | Add freebsd6.2 | Ralf Corsepius | 2007-02-27 | 1 | -2/+5 |
* | New. | Ralf Corsepius | 2007-02-27 | 11 | -0/+263 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 2 | -0/+4 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 1 | -1/+3 |
| | | | | | Add GCC_PKGVERS. Try gcc-4.1.2. | ||||
* | Add MKSPEC0. | Ralf Corsepius | 2007-02-26 | 16 | -15/+18 |
* | Use binutils_pkgvers instead of binutils_version in Source0. | Ralf Corsepius | 2007-02-26 | 17 | -17/+17 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 3 | -4/+4 |
* | Add GDB_PKGVERS. | Ralf Corsepius | 2007-02-26 | 1 | -0/+1 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 2 | -1/+1 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 6 | -0/+7 |
* | Add GCC_PKGVERS. | Ralf Corsepius | 2007-02-26 | 5 | -0/+5 |
* | Add GDB_PKGVERS. | Ralf Corsepius | 2007-02-26 | 11 | -0/+11 |
* | Add BINUTILS_PKGVERS. | Ralf Corsepius | 2007-02-26 | 11 | -0/+11 |
* | Set BINUTILS_RPMREL = 1 | Ralf Corsepius | 2007-02-23 | 1 | -1/+1 |
* | Use http://downloads.sourceforge.net/mingw/ as base for Source0. | Ralf Corsepius | 2007-02-23 | 1 | -1/+1 |
* | Set W32API_RPMREL = 1 | Ralf Corsepius | 2007-02-23 | 1 | -1/+1 |
* | Set MINGW32_RPMREL = 1 | Ralf Corsepius | 2007-02-23 | 1 | -1/+1 |
* | Add GCC_PKGVERS (PR 1220) | Ralf Corsepius | 2007-02-23 | 1 | -0/+1 |
* | Use http://downloads.sourceforge.net/mingw/ as base for Source0. | Ralf Corsepius | 2007-02-23 | 2 | -2/+2 |
* | Upgrade to mingw-runtime-3.11, w32api-3.8. | Ralf Corsepius | 2007-02-23 | 1 | -3/+4 |
| | | | | | Disable building infos for binutils. Add GCC_PKGVERS. | ||||
* | New. | Ralf Corsepius | 2007-02-22 | 1 | -0/+107 |
* | Add GDB_OPTS | Ralf Corsepius | 2007-02-20 | 13 | -1/+15 |
* | Increment BINUTILS_RPMREL | Ralf Corsepius | 2007-02-19 | 11 | -11/+11 |
* | Cosmetics | Ralf Corsepius | 2007-02-19 | 1 | -1/+1 |
* | Rename rtems-testing-@RTEMS_API@ repos into rtems-@RTEMS_API@-testing*. | Ralf Corsepius | 2007-02-18 | 1 | -3/+3 |
* | 2007-02-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-18 | 1 | -0/+6 |
| | | | | | | * configure.ac: Bump version to 0.5. * apt/sources.list.d/rtems.list.in, yum.repos.d/rtems.repo.in: Add rtems/testing repos. | ||||
* | Bump version to 0.5 | Ralf Corsepius | 2007-02-18 | 1 | -1/+1 |
* | Add rtems/testing | Ralf Corsepius | 2007-02-18 | 2 | -0/+39 |
* | gdb-6.6-rtems4.8-20070218.diff | Ralf Corsepius | 2007-02-18 | 11 | -11/+11 |
