* | Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild ↵ | Ralf Corsepius | 2006-02-24 | 1 | -6/+6 | |
| | | | | screwing up on %version. | |||||
* | Invoke gcc-%{gcc_version}/configure | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 | |
* | Add @PREP@, remove RTEMS version magic | Ralf Corsepius | 2006-02-24 | 1 | -12/+2 | |
* | Add gcc-prep.add | Ralf Corsepius | 2006-02-24 | 6 | -6/+18 | |
* | Remove no-define foreign from AM_INIT_AUTOMAKE. | Ralf Corsepius | 2006-02-24 | 1 | -2/+2 | |
* | New. | Ralf Corsepius | 2006-02-24 | 6 | -0/+29 | |
* | Allow shared libgfortran | Ralf Corsepius | 2006-02-24 | 1 | -1/+1 | |
* | Cosmetics. | Ralf Corsepius | 2006-02-22 | 12 | -15/+15 | |
* | Use gcc_version instead of %version, to work around rpm screwing up on ↵ | Ralf Corsepius | 2006-02-22 | 1 | -6/+6 | |
| | | | | %version in mixed-versioned packages. | |||||
* | Run make install-info to get the newlib infos | Ralf Corsepius | 2006-02-22 | 1 | -0/+6 | |
* | Cleanup comment on vxaddr2line. | Ralf Corsepius | 2006-02-22 | 1 | -1/+1 | |
* | Add ",g" in sed call to propagate _prefix to brp-compress. | Ralf Corsepius | 2006-02-22 | 2 | -2/+2 | |
* | Correct /-handling | Ralf Corsepius | 2006-02-22 | 2 | -2/+2 | |
* | Remove. | Ralf Corsepius | 2006-02-22 | 18 | -1148/+0 | |
* | Remove | Ralf Corsepius | 2006-02-22 | 8 | -500/+0 | |
* | Silence the tar calls. | Ralf Corsepius | 2006-02-21 | 2 | -2/+2 | |
* | Add @tool_target@-gcc hacks. | Ralf Corsepius | 2006-02-21 | 1 | -0/+2 | |
* | Remove @tool_target@-gcc hacks. | Ralf Corsepius | 2006-02-21 | 6 | -12/+0 | |
* | Ignore unsupported targets. | Ralf Corsepius | 2006-02-21 | 1 | -2/+2 | |
* | Delete refs to *-w32api-sys-root packages in *-gcc.spec.in | Ralf Corsepius | 2006-02-21 | 5 | -1/+6 | |
* | Delete refs to *-sys-root packages in *-gcc.spec.in | Ralf Corsepius | 2006-02-21 | 1 | -1/+1 | |
* | Delete refs to *-newlib packages in *-gcc.spec.in | Ralf Corsepius | 2006-02-21 | 5 | -5/+5 | |
* | Rename libc to newlib. | Ralf Corsepius | 2006-02-21 | 3 | -9/+10 | |
* | Rename files.libc to files.newlib. | Ralf Corsepius | 2006-02-21 | 2 | -9/+9 | |
* | Re-add BINUTILS_*, GCC_* | Ralf Corsepius | 2006-02-21 | 1 | -0/+5 | |
* | Add osversion | Ralf Corsepius | 2006-02-21 | 1 | -0/+1 | |
* | Eliminate osversion | Ralf Corsepius | 2006-02-21 | 6 | -12/+0 | |
* | Eliminate newlib_version | Ralf Corsepius | 2006-02-21 | 5 | -5/+0 | |
* | Use $(MKSPEC) to generate *-w32api.spec. | Ralf Corsepius | 2006-02-21 | 1 | -5/+1 | |
* | Use $(MKSPEC) to generate *-binutils.spec. | Ralf Corsepius | 2006-02-21 | 6 | -38/+6 | |
* | Use $(MKSPEC) to generate *-gcc.spec. | Ralf Corsepius | 2006-02-21 | 6 | -39/+6 | |
* | Use $(MKSPEC) to generate *-libs.spec. | Ralf Corsepius | 2006-02-21 | 5 | -24/+5 | |
* | Include ../mkspec.am | Ralf Corsepius | 2006-02-21 | 6 | -0/+12 | |
* | New. | Ralf Corsepius | 2006-02-21 | 1 | -0/+5 | |
* | Backup. | Ralf Corsepius | 2006-02-20 | 6 | -50/+50 | |
* | Unconditionally remove configure.info, because cygwin still ships it:( | Ralf Corsepius | 2006-02-20 | 1 | -2/+2 | |
* | Require/BuildRequire: w32api-sys-root, Remove a comment. | Ralf Corsepius | 2006-02-20 | 1 | -1/+3 | |
* | Add blank line. | Ralf Corsepius | 2006-02-20 | 1 | -0/+1 | |
* | Backup. | Ralf Corsepius | 2006-02-20 | 6 | -25/+24 | |
* | Apply @rpmprefix@ to *.spec files. | Ralf Corsepius | 2006-02-20 | 6 | -54/+54 | |
* | Use package version as RPMREL. | Ralf Corsepius | 2006-02-19 | 6 | -18/+18 | |
* | Apply target_alias to setup TARGET. | Ralf Corsepius | 2006-02-19 | 1 | -2/+1 | |
* | Add TARGET_SUBDIRS | Ralf Corsepius | 2006-02-19 | 1 | -1/+1 | |
* | Add AC_CANONICAL_TARGET. | Ralf Corsepius | 2006-02-19 | 1 | -1/+11 | |
| | | | | Apply target magic to setup rtems. | |||||
* | Comment out @tool_target@-gcc %package | Ralf Corsepius | 2006-02-18 | 1 | -7/+7 | |
* | delete sysroot related lines from *gcc.spec | Ralf Corsepius | 2006-02-18 | 1 | -0/+2 | |
* | Switch off _cxx | Ralf Corsepius | 2006-02-18 | 1 | -0/+1 | |
* | Add NEWLIB_VERS | Ralf Corsepius | 2006-02-18 | 2 | -1/+3 | |
* | Reflect newlib having been split out | Ralf Corsepius | 2006-02-18 | 1 | -13/+1 | |
* | Add binutils/prep.add, binutils/build.add binutils/install.add | Ralf Corsepius | 2006-02-18 | 6 | -0/+18 | |
