* | Don't cvsignore rtems*.spec. | Ralf Corsepius | 2009-09-13 | 1 | -1/+0 | |
* | Regenerate. | Ralf Corsepius | 2009-09-13 | 13 | -88/+88 | |
* | newlib-1.17.0-rtems4.10-20090911.diff. | Ralf Corsepius | 2009-09-13 | 12 | -12/+12 | |
* | Bump GCC_RPMREL for mass rebuild against binutils-2.19.90. | Ralf Corsepius | 2009-09-13 | 13 | -13/+13 | |
* | Regenerate. | Ralf Corsepius | 2009-09-13 | 13 | -82/+148 | |
* | Upgrade to binutils 2.19.90. | Ralf Corsepius | 2009-09-13 | 26 | -54/+54 | |
* | New. | Ralf Corsepius | 2009-09-11 | 1 | -0/+1116 | |
* | Update. | Ralf Corsepius | 2009-09-11 | 3 | -8/+8 | |
* | Regenerate. | Ralf Corsepius | 2009-09-11 | 13 | -89/+89 | |
* | newlib-1.17.0-rtems4.10-20090910.diff | Ralf Corsepius | 2009-09-11 | 13 | -13/+13 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-11 | 13 | -13/+13 | |
* | New. | Ralf Corsepius | 2009-09-10 | 1 | -0/+1103 | |
* | Remove. | Ralf Corsepius | 2009-09-09 | 4 | -3321/+0 | |
* | Regenerate. | Ralf Corsepius | 2009-09-09 | 13 | -89/+89 | |
* | newlib-1.17.0-rtems4.10-20090909.diff. | Ralf Corsepius | 2009-09-09 | 13 | -13/+13 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-09 | 13 | -13/+13 | |
* | New. | Ralf Corsepius | 2009-09-09 | 1 | -0/+1095 | |
* | Fix GDB_VERS. | Ralf Corsepius | 2009-09-08 | 2 | -3/+3 | |
* | Update to gdb-6.8.50.20090908. | Ralf Corsepius | 2009-09-08 | 6 | -14/+14 | |
* | gdb-6.8.50.20090908. | Ralf Corsepius | 2009-09-08 | 6 | -14/+14 | |
* | Rebase against gdb-6.8.50.20090908. | Ralf Corsepius | 2009-09-08 | 1 | -0/+544 | |
* | Regenerate. | Ralf Corsepius | 2009-09-07 | 1 | -1/+1 | |
* | Regenerate. | Ralf Corsepius | 2009-09-07 | 1 | -2/+1 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-07 | 1 | -1/+1 | |
* | Regenerate. | Ralf Corsepius | 2009-09-07 | 1 | -20/+57 | |
* | Regenerate. | Ralf Corsepius | 2009-09-07 | 13 | -115/+89 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-07 | 13 | -13/+13 | |
* | Don't push . into multilib subdirs. | Ralf Corsepius | 2009-09-07 | 1 | -2/+1 | |
* | Remove %sysdir %{_prefix} | Ralf Corsepius | 2009-09-07 | 1 | -1/+0 | |
* | Don't put _prefix into dirs. | Ralf Corsepius | 2009-09-06 | 1 | -3/+0 | |
* | Regenerate. | Ralf Corsepius | 2009-09-06 | 13 | -102/+89 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-06 | 13 | -13/+13 | |
* | newlib-1.17.0-rtems4.10-20090906.diff | Ralf Corsepius | 2009-09-06 | 13 | -13/+13 | |
* | New. | Ralf Corsepius | 2009-09-06 | 1 | -0/+1266 | |
* | Activate python. | Ralf Corsepius | 2009-09-05 | 14 | -13/+209 | |
* | Bump GDB_RPMREL = 2. | Ralf Corsepius | 2009-09-05 | 13 | -13/+13 | |
* | Fix %bcond_without/with python conditional. | Ralf Corsepius | 2009-09-05 | 1 | -2/+2 | |
* | Add python support. | Ralf Corsepius | 2009-09-05 | 2 | -0/+14 | |
* | Fix expat. | Ralf Corsepius | 2009-09-03 | 3 | -6/+10 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-09-03 | 2 | -2/+2 | |
* | Regenerate. | Ralf Corsepius | 2009-09-03 | 8 | -8/+8 | |
* | Reset GDB_RPMREL. | Ralf Corsepius | 2009-09-03 | 8 | -8/+8 | |
* | Upgrade to gdb-6.8.50.20090902. | Ralf Corsepius | 2009-09-03 | 24 | -62/+88 | |
* | Upgrade to gdb-6.8.50.20090902. | Ralf Corsepius | 2009-09-02 | 15 | -78/+212 | |
* | New. | Ralf Corsepius | 2009-09-02 | 1 | -0/+532 | |
* | Regenerate. | Ralf Corsepius | 2009-09-02 | 14 | -114/+100 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-09-02 | 12 | -12/+12 | |
* | Bump GDB_RPMREL. Disable infos. | Ralf Corsepius | 2009-09-02 | 2 | -4/+4 | |
* | Introduce noarch subpackages. Fix dir ownerships. | Ralf Corsepius | 2009-09-02 | 2 | -0/+7 | |
