* | Disable binutils infos. | Ralf Corsepius | 2007-01-12 | 1 | -1/+1 |
* | Add BINUTILS_OPTS += | Ralf Corsepius | 2007-01-12 | 6 | -0/+6 |
* | Bump GCC_RPMREL | Ralf Corsepius | 2007-01-12 | 11 | -12/+12 |
* | Update to gcc-core-4.2.0-rtems4.8-20070112.diff | Ralf Corsepius | 2007-01-12 | 1 | -1/+1 |
* | Remove (Obsolete). | Ralf Corsepius | 2007-01-12 | 2 | -18647/+0 |
* | Update (bfin merged into upstream) | Ralf Corsepius | 2007-01-12 | 1 | -0/+31 |
* | Use gcc-core-4.1.1-rtems4.8-20070102.diff | Ralf Corsepius | 2007-01-12 | 3 | -3/+3 |
* | Upgrade to newlib-1.15.0-rtems4.8-20070110. | Ralf Corsepius | 2007-01-12 | 11 | -11/+11 |
* | Add BINUTILS_OPTS. | Ralf Corsepius | 2007-01-12 | 11 | -0/+11 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2007-01-12 | 11 | -11/+11 |
* | Bump releases. | Ralf Corsepius | 2007-01-10 | 1 | -2/+2 |
* | Rename automake-rtems into automake. | Ralf Corsepius | 2007-01-10 | 2 | -8/+13 |
| | | | | Rename autoconf-rtems into autoconf. | ||||
* | Rename autoconf-rtems into autoconf. | Ralf Corsepius | 2007-01-10 | 2 | -7/+12 |
* | Update bugfix address | Ralf Corsepius | 2007-01-10 | 1 | -2/+1 |
* | Add ECANCELED. | Ralf Corsepius | 2007-01-10 | 1 | -0/+849 |
* | Add BINUTILS_OPTS | Ralf Corsepius | 2007-01-04 | 7 | -7/+21 |
* | Add support for newlib-1.15.0 | Ralf Corsepius | 2007-01-04 | 4 | -4/+10 |
* | Add newlib-1.15.0. | Ralf Corsepius | 2007-01-04 | 2 | -4/+7 |
| | | | | New GCC snapshot. | ||||
* | New. | Ralf Corsepius | 2007-01-04 | 1 | -0/+116 |
* | Upgrade to newlib-1.15.0 | Ralf Corsepius | 2007-01-02 | 16 | -24/+48 |
* | New. | Ralf Corsepius | 2007-01-02 | 1 | -0/+140 |
* | New. | Ralf Corsepius | 2006-12-19 | 1 | -0/+838 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 8 | -4/+20 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-11-19 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-20 | 1 | -0/+5 |
| | | | | | * autotools/Makefile.am, autotools/autoconf.add: Upgrade to autoconf-2.61. | ||||
* | 2006-11-19 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-19 | 2 | -3/+3 |
* | GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff | Ralf Corsepius | 2006-11-15 | 2 | -4/+4 |
* | Remove (Obsolete) | Ralf Corsepius | 2006-11-15 | 2 | -6221/+0 |
* | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-15 | 1 | -0/+8 |
| | | | | | | | | * patches/gcc-core-4.2-20061114-rtems4.8-20061115.diff: New. * patches/newlib-1.14.0-bfinrtems-20060810a.diff: Remove (Obsolete). * patches/gcc-4.1.1-bfinrtems-20060810a.diff: Remove (Obsolete). * rtems-4.8/bfin/Makefile.am, rtems-4.8/bin/gcc-sources.add: GCC_REL=4. Upgrade to gcc-core-4.2-20061114-rtems4.8-20061115.diff. | ||||
* | New. | Ralf Corsepius | 2006-11-15 | 1 | -0/+17745 |
* | Add. | Ralf Corsepius | 2006-11-14 | 1 | -0/+556 |
* | 'BR: flex bison' for gcc >= 4.2.0 | Ralf Corsepius | 2006-11-10 | 1 | -0/+3 |
* | Introduce GCC_PKGVERS | Ralf Corsepius | 2006-11-09 | 16 | -15/+25 |
* | Upgrade to gcc-4.2.0-20061031. | Ralf Corsepius | 2006-11-09 | 1 | -2/+7 |
* | New (Merge BFIN patches). | Ralf Corsepius | 2006-11-09 | 2 | -0/+5137 |
* | Update sparc dep to rtems4.8 | Ralf Corsepius | 2006-10-30 | 1 | -1/+1 |
* | Remove (unused) | Ralf Corsepius | 2006-10-27 | 3 | -738/+0 |
* | Remove (unused). | Ralf Corsepius | 2006-10-27 | 1 | -3699/+0 |
* | Remove (broken). | Ralf Corsepius | 2006-10-27 | 1 | -4138/+0 |
* | Remove (obsolete). | Ralf Corsepius | 2006-10-27 | 1 | -838/+0 |
* | 2006-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-27 | 1 | -0/+5 |
| | | | | | * configure.ac, Makefile.am: Remove rtems4.7. * rtems4.7: Remove (Development now in rtems-4-7-branch only). | ||||
* | Remove rtems-4.7 | Ralf Corsepius | 2006-10-27 | 2 | -14/+0 |
* | Remove (unused). | Ralf Corsepius | 2006-10-27 | 59 | -866/+0 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2006-10-27 | 11 | -11/+11 |
| | | | | | * patches/newlib-1.14.0-rtems4.8-20061027.diff: New. * patches/newlib-1.14.0-rtems-20061026.diff: Remove (broken). | ||||
* | Update to newlib-1.14.0-rtems4.8-20061027.diff | Ralf Corsepius | 2006-10-27 | 11 | -11/+11 |
* | New. | Ralf Corsepius | 2006-10-27 | 1 | -0/+4120 |
* | 2006-10-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-26 | 2 | -0/+4142 |
| | | | | * patches/newlib-1.14.0-rtems-20061026.diff: New file. | ||||
* | Let rtems-@RTEMS_API@-repo-conf.spec depend on configure.ac | Ralf Corsepius | 2006-10-25 | 1 | -1/+1 |
* | Bumb version to 0.4 | Ralf Corsepius | 2006-10-25 | 1 | -1/+1 |
* | Bump version to 0.3 | Ralf Corsepius | 2006-10-24 | 1 | -1/+1 |
