path: root/contrib (follow)
* Regenerate.Ralf Corsepius2010-09-231-8/+14
* Add autoconf-2.68.Ralf Corsepius2010-09-231-6/+12
* autoconf-2.68.Ralf Corsepius2010-09-231-1/+1
* Abandon Fedora 11.Ralf Corsepius2010-09-2114-85/+0
* New.Ralf Corsepius2010-09-081-0/+595
* Parse condstack in final printing.Ralf Corsepius2010-09-081-1/+13
* Prepend @condstack to @buffer4 lines.Ralf Corsepius2010-09-081-1/+1
* Prepend @condstack to @buffer4 lines.Ralf Corsepius2010-09-081-5/+5
* Simplify %if rules.Ralf Corsepius2010-09-081-12/+4
* Regenerate.Ralf Corsepius2010-09-071-2/+4
* gdb-7.2-rtems4.11-20100907.diffRalf Corsepius2010-09-071-1/+1
* Bump GDB_RPMREL.Ralf Corsepius2010-09-071-1/+1
* Add --enable-sim-trace for powerpc-rtems*Ralf Corsepius2010-09-071-0/+2
* Regenerate.Ralf Corsepius2010-09-071-19/+10
* Bump AUTOMAKE_RPMREL.Ralf Corsepius2010-09-071-1/+1
* Add workaround to mingw shipping an obsolete version of perl.Ralf Corsepius2010-09-071-19/+10
| | | | Remove legacy support for automake < 1.11.
* HousekeepingRalf Corsepius2010-09-072-373/+0
* Regenerate.Ralf Corsepius2010-09-0314-42/+98
* Add gdb-7.2Ralf Corsepius2010-09-0314-0/+56
* GDB_VERS = 7.2Ralf Corsepius2010-09-0314-28/+28
* New (gdb-7.1 patches rebased against gdb-7.2)Ralf Corsepius2010-09-031-0/+532
* Abandon Fedora 11.Ralf Corsepius2010-08-281-6/+0
* Regenerate.Ralf Corsepius2010-08-2614-27/+27
* binutils-2.20.1-rtems4.11-20100826.diffRalf Corsepius2010-08-2613-13/+13
* Bump BINUTILS_RPMREL.Ralf Corsepius2010-08-2614-14/+14
* Add binutils-pr11939 patch.Ralf Corsepius2010-08-261-0/+99
* Regenerate.Ralf Corsepius2010-08-2514-112/+112
* Bump GCC_RPMREL.Ralf Corsepius2010-08-2514-14/+14
* newlib-1.18.0-rtems4.11-20100825.diff.Ralf Corsepius2010-08-2514-14/+14
* New.Ralf Corsepius2010-08-251-0/+1458
* Regenerate.Ralf Corsepius2010-08-1814-112/+266
* Add bcond_with gcc_stdint.Ralf Corsepius2010-08-182-0/+11
* gcc-core-4.5.1-rtems4.11-20100818.diffRalf Corsepius2010-08-1814-14/+14
* GCC_RPMREL = 5Ralf Corsepius2010-08-1814-14/+14
* New.Ralf Corsepius2010-08-181-0/+422
* Remove bogusly included files.Ralf Corsepius2010-08-151-67/+2
* mpfr-2.4.2Ralf Corsepius2010-08-133-7/+7
* Regenerate.Ralf Corsepius2010-08-132-4/+18
* Bump GCC_RPMREL.Ralf Corsepius2010-08-132-2/+2
* Regenerate.Ralf Corsepius2010-08-126-12/+54
* Bump GCC_RPMREL.Ralf Corsepius2010-08-126-6/+6
* New.Ralf Corsepius2010-08-121-0/+622
* Regenerate.Ralf Corsepius2010-08-1214-28/+28
* gdb-7.1-rtems4.11-20100812.diff.Ralf Corsepius2010-08-1214-14/+14
* Bump GDB_RPMREL = 4Ralf Corsepius2010-08-1214-14/+14
* Regenerate.Ralf Corsepius2010-08-1014-112/+112
* newlib-1.18.0-rtems4.11-20100810.diff.Ralf Corsepius2010-08-1014-14/+14
* Bump GCC_RPMREL.Ralf Corsepius2010-08-1014-14/+14
* New.Ralf Corsepius2010-08-101-0/+1443
* Regenerate.Ralf Corsepius2010-08-051-4/+13
