* | Regenerate. | Ralf Corsepius | 2008-09-03 | 39 | -159/+476 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2008-09-03 | 20 | -20/+90 |
* | New. | Ralf Corsepius | 2008-09-03 | 1 | -0/+117 |
* | Remove. | Ralf Corsepius | 2008-09-03 | 1 | -1492/+0 |
* | Regenerate. | Ralf Corsepius | 2008-08-28 | 10 | -60/+134 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-08-28 | 10 | -10/+10 |
* | Regenerate. | Ralf Corsepius | 2008-08-28 | 10 | -20/+50 |
* | Add rtems4.10. | Ralf Corsepius | 2008-08-28 | 1 | -0/+1 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2008-08-28 | 10 | -10/+10 |
* | gcc-4.3.2 | Ralf Corsepius | 2008-08-28 | 20 | -10/+80 |
* | New. | Ralf Corsepius | 2008-08-28 | 1 | -0/+117 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-28 | 11 | -11/+11 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-27 | 1 | -1/+1 |
* | Remove (Obsolete). | Ralf Corsepius | 2008-08-27 | 4 | -357/+0 |
* | Use URLs for patches. | Ralf Corsepius | 2008-08-27 | 11 | -11/+11 |
* | Abandon gcc-4.3.0. | Ralf Corsepius | 2008-08-27 | 10 | -90/+20 |
| | | | | | Use URLs for patches. newlib-1.16.0-rtems4.9-20080827.diff. | ||||
* | Update. | Ralf Corsepius | 2008-08-27 | 10 | -10/+10 |
* | New. | Ralf Corsepius | 2008-08-27 | 2 | -0/+2082 |
* | Remove. | Ralf Corsepius | 2008-08-27 | 1 | -27/+0 |
* | Remove tic4x (Abandoned). | Ralf Corsepius | 2008-08-27 | 2 | -2/+0 |
* | Remove. | Ralf Corsepius | 2008-08-27 | 2 | -8/+0 |
* | Remove (Abandon). | Ralf Corsepius | 2008-08-27 | 5 | -845/+0 |
* | Use full URLs to patches. | Ralf Corsepius | 2008-08-27 | 10 | -20/+20 |
* | Abandon rtems4.10/tic4x. | Ralf Corsepius | 2008-08-27 | 1 | -1/+0 |
* | Abandon tic4x. | Ralf Corsepius | 2008-08-27 | 1 | -1/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2008-08-27 | 7 | -871/+0 |
* | Don't install windmc.1 if windmc is not available. | Ralf Corsepius | 2008-07-27 | 1 | -0/+3 |
* | Remove (Incorporated by upstream.) | Ralf Corsepius | 2008-07-07 | 1 | -11/+0 |
* | New. | Ralf Corsepius | 2008-07-06 | 1 | -0/+11 |
* | Add full URL to patch. | Ralf Corsepius | 2008-07-05 | 21 | -21/+21 |
* | Add rtems-4.10. | Ralf Corsepius | 2008-07-03 | 1 | -0/+14 |
* | gcc-core-4.3.1-rtems4.9-20080628.diff | Ralf Corsepius | 2008-07-03 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2008-07-03 | 42 | -0/+12864 |
* | Backup. | Ralf Corsepius | 2008-07-03 | 5 | -15/+47 |
* | Add m68k/cf 5329 | Ralf Corsepius | 2008-07-03 | 1 | -0/+117 |
* | Remove 4.3.0. | Ralf Corsepius | 2008-07-03 | 10 | -79/+9 |
* | Set target to rtems4.10. | Ralf Corsepius | 2008-07-03 | 12 | -12/+12 |
* | Reset *_RPMREL. | Ralf Corsepius | 2008-07-03 | 12 | -44/+44 |
* | New. | Ralf Corsepius | 2008-07-03 | 76 | -0/+1183 |
* | Upgrade to gcc-4.3.1 | Ralf Corsepius | 2008-06-09 | 1 | -7/+7 |
* | Add gcc-4.3.1. Abandon gcc-4.2.3. | Ralf Corsepius | 2008-06-09 | 9 | -63/+68 |
* | Upgrade to gcc-4.3.1. | Ralf Corsepius | 2008-06-09 | 10 | -20/+20 |
* | Do not use string comparisions. | Ralf Corsepius | 2008-06-09 | 1 | -2/+2 |
* | New. | Ralf Corsepius | 2008-06-09 | 1 | -0/+107 |
* | Remove. | Ralf Corsepius | 2008-06-05 | 15 | -11331/+0 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-06-04 | 1 | -1/+1 |
* | Upgrade to binutils-20080523-1. | Ralf Corsepius | 2008-06-04 | 2 | -3/+5 |
* | Add hack to adjust n/ncr260vt300wpp | Ralf Corsepius | 2008-06-04 | 1 | -2/+4 |
* | Bump ncurses RPMREL. | Ralf Corsepius | 2008-06-04 | 1 | -1/+1 |
* | BR/R: terminfo | Ralf Corsepius | 2008-06-04 | 1 | -0/+3 |
