path: root/contrib (follow)
* New.Ralf Corsepius2004-04-136-0/+350
* 2004-02-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-212-0/+22
| | | | * README: New file.
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-202-1/+5
| | | | * rtems-apt-conf.spec.in: Add @VERSION@ to Source0.
* Update.Ralf Corsepius2004-02-201-4/+8
* Add ChangeLogRalf Corsepius2004-02-201-0/+7
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-2010-0/+709
| | | | | | | * Makefile.am, gpg/gpg-pubkey-eac29b6f-3fe1f458, ChangeLog, vendors.list.d/rtems.list, sources.list.d/rtems-4.6.list, sources.list.d/rtems-4.7.list, configure.ac, .cvsignore, COPYING, rtems-apt-conf.spec.in, INSTALL: New.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-124-2/+8
| | | | * Makefile.am: Cosmetics.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-124-4/+12
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-114-11/+11
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-114-2/+10
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-114-2/+10
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-072-31/+47
| | | | | | | * i386-cygwin-gcc.spec.in: Use %_prefix instead of %prefix. Add gnatlib. Add %defattr(-,root,root). Provide virtual packages i386-cygwin-[c++|g++|gnat].
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-283-4/+16
| | | | | * setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You must build and install a C only toolset first though.
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-282-0/+10
| | | | * .cvsignore: Add entries to .cvsignore.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-271-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * setup.def, sparc-solaris-binutils.spec.in: Updated and used to build sparc-solaris 3.2.1-1 C language only. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2001-04-16 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Added missing files. * setup.def: New shot using gcc 3.0.4 RPMs. * sparc-solaris-binutils.spec.in: Switched to bz2 file. * sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive and use find to pick up all files. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-02-08 Joel Sherrill <joel@OARcorp.com> * .cvsignore: New file. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * Makefile.am: New file, missed previously. 2004-02-05 Joel Sherrill <joel@OARcorp.com> * ChangeLog, configure.ac, setup, setup.def, sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in, sparc-solaris-libs.spec.in: New files.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-272-5/+10
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-273-2/+13
| | | | | | * i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for revision 2.
* 2003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-274-18/+20
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def: Updated to current Cygwin versions and fixed some minor nits in the specifications. 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * setup.def: Update to binutils-20021117-1. * i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1. Adaptations to RH-8.0/rpm-4.1. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in: Modified group. 2001-01-22 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest versions and packaging. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-13 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Corrected for missing files. 2001-08-31 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Missed in previous commit. 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin.
* 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-163-7/+15
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-214-6/+18
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-165-39/+27
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-286-6/+18
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-082-0/+10
| | | | | | | | | | | | | * Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused with RTEMS. * r46kstub.c: Renamed to mips-stub.c. * mips-stub.c: New file -- was r46kstub.c. * memlimits.h: New file was limits.h. * limits.h: Removed. * r4600.h: Eliminated need for this file. * README: Updated. * gdb_if.h: Added CVS Id. * mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-3/+8
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+26
* 2004-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-057-0/+429
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-227-11/+18
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+80
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-78/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-1/+8
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-132-1/+10
* 2001-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-311-0/+4
* 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-08-3110-0/+565
