* | GCC-4.1.1 still installs mf-runtime.h to the wrong directory. | Ralf Corsepius | 2006-06-21 | 1 | -1/+1 |
* | Replace %{build_infos} with %build_infos. | Ralf Corsepius | 2006-06-20 | 16 | -18/+18 |
* | Use star to untar the sources | Ralf Corsepius | 2006-06-20 | 1 | -1/+2 |
* | Add freebsd6.1 | Ralf Corsepius | 2006-06-20 | 1 | -1/+2 |
* | More preps for VPATH builds. | Ralf Corsepius | 2006-06-19 | 5 | -139/+139 |
* | Update. | Ralf Corsepius | 2006-06-18 | 1 | -15/+0 |
* | Bump version. | Ralf Corsepius | 2006-06-17 | 1 | -1/+2 |
| | | | | Add freebsd6.1 | ||||
* | New. | Ralf Corsepius | 2006-06-17 | 7 | -0/+262 |
* | Preps for VPATH builts. | Ralf Corsepius | 2006-06-17 | 2 | -35/+35 |
* | Use star instead of tar. | Ralf Corsepius | 2006-06-17 | 1 | -1/+2 |
* | Preps for VPATH builts. | Ralf Corsepius | 2006-06-08 | 1 | -39/+39 |
* | New. | Ralf Corsepius | 2006-03-23 | 1 | -0/+3 |
* | Add defaults for non-standard $prefix. | Ralf Corsepius | 2006-03-23 | 1 | -2/+7 |
* | Apply @sysdirpattern@ | Ralf Corsepius | 2006-03-17 | 2 | -1/+7 |
* | Use %sysdir instead of %if %_prefix ==|!= /usr | Ralf Corsepius | 2006-03-17 | 12 | -41/+27 |
* | Require base-binutils if building infos. | Ralf Corsepius | 2006-03-16 | 1 | -0/+1 |
* | Remove message erroniously checked in in previous change | Ralf Corsepius | 2006-03-16 | 1 | -1/+0 |
* | Set defaults for ac_default_prefix | Ralf Corsepius | 2006-03-16 | 1 | -1/+2 |
* | Increment version | Ralf Corsepius | 2006-03-15 | 1 | -1/+1 |
* | Add w32api | Ralf Corsepius | 2006-03-15 | 3 | -1/+89 |
* | configure --enable-sim | Ralf Corsepius | 2006-03-11 | 1 | -0/+1 |
* | Use DESTDIR for gdb >= 6.3. | Ralf Corsepius | 2006-03-11 | 1 | -0/+9 |
| | | | | Remove bogus lib*-sim.a | ||||
* | Reflect having added --enable-infos | Ralf Corsepius | 2006-03-10 | 1 | -4/+2 |
* | Increment version | Ralf Corsepius | 2006-03-10 | 1 | -1/+1 |
* | Use %build_infos | Ralf Corsepius | 2006-03-10 | 17 | -29/+31 |
* | Propagate build_infos to *.spec.ins | Ralf Corsepius | 2006-03-10 | 1 | -0/+1 |
* | Rework rpmprefix logic. | Ralf Corsepius | 2006-03-10 | 1 | -20/+38 |
| | | | | Add --enable-infos/build_infos. | ||||
* | Add missing comma. | Ralf Corsepius | 2006-03-10 | 1 | -1/+2 |
* | Add gdb | Ralf Corsepius | 2006-03-10 | 1 | -0/+30 |
* | Add gdb/*.add | Ralf Corsepius | 2006-03-10 | 1 | -0/+8 |
* | New. | Ralf Corsepius | 2006-03-10 | 7 | -0/+216 |
* | 2006-03-10 Add preliminary rtems-gdb specs. | Ralf Corsepius | 2006-03-10 | 1 | -0/+3 |
| | | | | (Immature, incomplete, needs further testing). | ||||
* | Add note on Ada. | Ralf Corsepius | 2006-03-09 | 1 | -0/+5 |
* | Update | Ralf Corsepius | 2006-03-09 | 2 | -3/+27 |
* | Enable fortran and objc | Ralf Corsepius | 2006-03-09 | 1 | -0/+2 |
* | Deactivate PATCH0 (not required for gcc >= 4.1.0 | Ralf Corsepius | 2006-03-08 | 1 | -1/+1 |
* | Activate fortran and objc | Ralf Corsepius | 2006-03-08 | 2 | -0/+4 |
* | New. | Ralf Corsepius | 2006-03-07 | 1 | -0/+4 |
* | Use gcc_rpmvers for subpackage deps. | Ralf Corsepius | 2006-03-07 | 6 | -6/+6 |
* | Use %echo instead of %%echo in %expand | Ralf Corsepius | 2006-03-07 | 1 | -2/+2 |
* | Fix main package name. Update version. | Ralf Corsepius | 2006-03-07 | 1 | -1/+1 |
* | Distribute local *.add files. | Ralf Corsepius | 2006-03-07 | 5 | -0/+32 |
* | Distribute local *.add files. Reflect having renamed *-libc.add into ↵ | Ralf Corsepius | 2006-03-07 | 1 | -2/+9 |
| | | | | *-newlib.add | ||||
* | Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add | Ralf Corsepius | 2006-03-07 | 1 | -1/+2 |
* | Renamed into *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -61/+0 |
* | Renamed from *-libc.add to *-newlib.add | Ralf Corsepius | 2006-03-07 | 2 | -0/+61 |
* | GCC_VERS = 4.1.0 | Ralf Corsepius | 2006-03-06 | 5 | -6/+5 |
* | Subst gcc_rpmvers for LIB packages. | Ralf Corsepius | 2006-03-06 | 5 | -1/+7 |
* | Remove stray blank in %expand to setup rpmvers. | Ralf Corsepius | 2006-03-06 | 7 | -7/+7 |
* | Add osversion hack | Ralf Corsepius | 2006-03-04 | 1 | -1/+10 |
