* | Fix package name. | Ralf Corsepius | 2008-03-22 | 1 | -1/+1 |
* | Add termcap. | Ralf Corsepius | 2008-03-22 | 1 | -0/+4 |
* | New. | Ralf Corsepius | 2008-03-22 | 3 | -0/+63 |
* | New. | Ralf Corsepius | 2008-03-22 | 1 | -0/+21 |
* | Add readline. | Ralf Corsepius | 2008-03-22 | 3 | -0/+49 |
* | include ../mpfr.am | Ralf Corsepius | 2008-03-22 | 1 | -1/+1 |
* | Remove. | Ralf Corsepius | 2008-03-22 | 1 | -22/+0 |
* | New. | Ralf Corsepius | 2008-03-22 | 2 | -0/+43 |
* | Split-out mpfr.add ncurses.am zlib.am. | Ralf Corsepius | 2008-03-22 | 1 | -86/+4 |
* | New (Split-out from i686/Makefile.am). | Ralf Corsepius | 2008-03-22 | 3 | -0/+64 |
* | Replaced with ncurses*.add | Ralf Corsepius | 2008-03-22 | 2 | -49/+0 |
* | Replace libncurses-devel with ncurses. | Ralf Corsepius | 2008-03-22 | 1 | -13/+14 |
* | New. | Ralf Corsepius | 2008-03-22 | 2 | -0/+47 |
* | Add mpfr. | Ralf Corsepius | 2008-03-20 | 1 | -0/+25 |
* | New. | Ralf Corsepius | 2008-03-20 | 2 | -0/+47 |
* | Add gmp. | Ralf Corsepius | 2008-03-20 | 1 | -0/+24 |
* | Disable debug_package for cygwin. | Ralf Corsepius | 2008-03-20 | 1 | -0/+1 |
* | Add _libdir for cygwin. | Ralf Corsepius | 2008-03-20 | 1 | -0/+1 |
* | Add cygwin optflags hack. | Ralf Corsepius | 2008-03-20 | 1 | -0/+4 |
* | Use %__tar instead of /usr/bin/star. | Ralf Corsepius | 2008-03-20 | 1 | -2/+1 |
* | Rename Source60 into Source70. | Ralf Corsepius | 2008-03-19 | 2 | -2/+2 |
* | Upgrade to cygwin-1.5.25-11, w32api-3.11-1. | Ralf Corsepius | 2008-03-19 | 1 | -4/+4 |
* | Add %{_bindir} to PATH to cater CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -0/+6 |
| | | | | Set CFLAGS_FOR_BUILD. | ||||
* | Add %{_bindir} to PATH to catter CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -0/+3 |
* | BR: @rpmprefix@%{_host}-gcc for CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -0/+4 |
* | Set CFLAGS_FOR_BUILD and CC for CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -1/+5 |
* | BR: @rpmprefix@@tool_target@-gcc and @rpmprefix@%{_host}-gcc for CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -0/+5 |
* | BR: @rpmprefix@@tool_target@-gcc-c++ for CdnX-builds. | Ralf Corsepius | 2008-03-18 | 1 | -0/+3 |
* | Bump RPMRELS. Sync with rtems-4-8-branch. | Ralf Corsepius | 2008-03-14 | 1 | -5/+6 |
* | Fix typo. | Ralf Corsepius | 2008-03-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2008-03-14 | 11 | -43/+54 |
* | Add binutils-patch. | Ralf Corsepius | 2008-03-12 | 1 | -1/+1 |
* | New. | Ralf Corsepius | 2008-03-12 | 1 | -0/+24 |
* | Switch back to old GCC_RPMREL versioning scheme. | Ralf Corsepius | 2008-03-06 | 4 | -4/+4 |
* | Bump version. | Ralf Corsepius | 2008-03-06 | 1 | -1/+1 |
* | Use binutils-2.18-rtems4.9-20080211.diff. | Ralf Corsepius | 2008-03-06 | 4 | -4/+4 |
* | New. | Ralf Corsepius | 2008-03-06 | 1 | -0/+89 |
* | Preps for gcc-4.3.0 final. | Ralf Corsepius | 2008-03-06 | 18 | -45/+45 |
* | Sync with freebsd7.0. | Ralf Corsepius | 2008-03-06 | 1 | -3/+3 |
* | Upgrade to binutils-2.18. | Ralf Corsepius | 2008-03-06 | 4 | -10/+8 |
| | | | | | Upgrade to gcc-4.2.3. Activate objc. | ||||
* | Require gmp and mpfr for gcc > 4.2.0 fortran. | Ralf Corsepius | 2008-03-06 | 1 | -0/+7 |
* | Sync with the freebsds. | Ralf Corsepius | 2008-03-05 | 2 | -5/+5 |
* | Abandon freebsd6.1. | Ralf Corsepius | 2008-03-05 | 2 | -4/+0 |
* | Abandon. | Ralf Corsepius | 2008-03-05 | 11 | -263/+0 |
* | Add freebsd6.3, freebsd7.0 | Ralf Corsepius | 2008-03-05 | 2 | -1/+10 |
* | New. | Ralf Corsepius | 2008-03-05 | 22 | -0/+533 |
* | Abandon freebsd6.0 | Ralf Corsepius | 2008-03-05 | 2 | -4/+0 |
* | Abandon. | Ralf Corsepius | 2008-03-05 | 23 | -535/+0 |
* | Abandon freebsd5.2 | Ralf Corsepius | 2008-03-05 | 2 | -4/+0 |
