* | Regenerate. | Ralf Corsepius | 2011-03-10 | 1 | -4/+8 |
* | Rename amd64 into x86_64. | Ralf Corsepius | 2011-03-10 | 1 | -1/+1 |
* | Rename freebsd8.2/amd64/ into freebsd8.2/x86_64/. | Ralf Corsepius | 2011-03-10 | 1 | -1/+1 |
* | Remove bogus comment. | Ralf Corsepius | 2011-03-10 | 2 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 2 | -32/+18 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-10 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 4 | -52/+35 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-10 | 5 | -5/+5 |
* | Abandon freebsd8.0. | Ralf Corsepius | 2011-03-10 | 2 | -6/+1 |
* | Abandon. | Ralf Corsepius | 2011-03-10 | 24 | -2791/+0 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 2 | -43/+38 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 14 | -98/+196 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-10 | 14 | -14/+14 |
* | Add suse11_4. | Ralf Corsepius | 2011-03-10 | 1 | -0/+7 |
* | Add freebsd8.2 | Ralf Corsepius | 2011-02-28 | 2 | -0/+5 |
* | New. | Ralf Corsepius | 2011-02-27 | 24 | -0/+2773 |
* | Add -mcpu=8540/-mfloat-gprs=double multilib. | Ralf Corsepius | 2011-02-20 | 1 | -19/+46 |
| | | | | Remove -mcpu=601 multilib. | ||||
* | Add missing brace. | Ralf Corsepius | 2011-02-20 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-02-20 | 11 | -11/+11 |
* | Fix typo. | Ralf Corsepius | 2011-02-20 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2011-02-20 | 1 | -0/+420 |
* | Regenerate. | Ralf Corsepius | 2011-02-20 | 14 | -112/+123 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-02-20 | 14 | -14/+14 |
* | gcc-core-4.5.2-rtems4.11-20110220.diff | Ralf Corsepius | 2011-02-20 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2011-02-20 | 1 | -0/+5887 |
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 4 | -3/+11 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | Add gcc-g++-4.5.2-rtems4.11-20110131.diff. | Ralf Corsepius | 2011-01-31 | 14 | -0/+14 |
* | Regenerate. | Ralf Corsepius | 2011-01-29 | 14 | -308/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-01-29 | 14 | -14/+14 |
* | BR: cloog-ppl-devel on f15. | Ralf Corsepius | 2011-01-29 | 1 | -0/+1 |
* | Update to w32api-3.15-1. | Ralf Corsepius | 2011-01-29 | 2 | -5/+5 |
* | Update to cygwin-1.7.7-1. | Ralf Corsepius | 2011-01-29 | 2 | -5/+5 |
* | Abandon fedora-11, fedora-12, openSUSE-11.0, openSUSE-11.0. | Ralf Corsepius | 2011-01-29 | 1 | -15/+0 |
* | Regenerate. | Ralf Corsepius | 2011-01-09 | 14 | -112/+112 |
* | newlib-1.19.0-rtems4.11-20110109.diff | Ralf Corsepius | 2011-01-09 | 14 | -14/+14 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-01-09 | 14 | -14/+14 |
* | New (Add 32bit double tgamma fixes). | Ralf Corsepius | 2011-01-09 | 1 | -0/+2081 |
* | Update. | Ralf Corsepius | 2011-01-07 | 1 | -65/+72 |
* | New. | Ralf Corsepius | 2011-01-07 | 1 | -0/+2044 |
* | Regenerate. | Ralf Corsepius | 2011-01-07 | 14 | -318/+196 |
* | newlib-1.19.0-rtems4.11-20110107.diff. | Ralf Corsepius | 2011-01-07 | 14 | -210/+70 |
| | | | | Abandon gcc-4.5.0, gcc-4.5.1. | ||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-01-07 | 14 | -42/+42 |
| | | | | | NEWLIB_VERS = 1.19.0. Reset NEWLIB_RPMREL. | ||||
* | Regenerate. | Ralf Corsepius | 2011-01-07 | 14 | -28/+28 |
* | Bump BINUTILS_RPMREL = 2. | Ralf Corsepius | 2011-01-07 | 14 | -14/+14 |
* | Add binutils-2.21-rtems4.11-20110107.diff. | Ralf Corsepius | 2011-01-07 | 14 | -14/+14 |
* | New. | Ralf Corsepius | 2011-01-07 | 1 | -0/+75 |
* | Housekeeping. | Ralf Corsepius | 2011-01-07 | 6 | -1460/+0 |
* | Remove. | Ralf Corsepius | 2010-12-26 | 1 | -45/+0 |
* | Regenerate. | Ralf Corsepius | 2010-12-17 | 14 | -137/+137 |
