* | Regenerate. | Ralf Corsepius | 2010-04-27 | 13 | -39/+26 |
* | Regenerate. | Ralf Corsepius | 2010-04-27 | 6 | -24/+18 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-27 | 6 | -6/+6 |
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -95/+13 |
* | Abandon gcc-4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -104/+13 |
| | | | | newlib-1.18.0-rtems4.10-20100426.diff. | ||||
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -186/+104 |
* | Abandon gcc-g++-4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -39/+0 |
* | Add missing ; | Ralf Corsepius | 2010-04-26 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2010-04-26 | 1 | -0/+1254 |
* | Abandon 4.4.2. | Ralf Corsepius | 2010-04-26 | 13 | -65/+13 |
| | | | | newlib-1.18.0-rtems4.11-20100423.diff. | ||||
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-26 | 13 | -13/+13 |
* | Fix no-brainer bug in previous change. | Ralf Corsepius | 2010-04-26 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2010-04-26 | 13 | -117/+234 |
* | Rename cygwin-gcc-3.4.4.diff inro cygwin-gcc-3.4.4-3.diff. | Ralf Corsepius | 2010-04-25 | 1 | -0/+0 |
* | New. | Ralf Corsepius | 2010-04-25 | 1 | -0/+12 |
* | Regenerate. | Ralf Corsepius | 2010-04-25 | 1 | -3/+1 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2010-04-25 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2010-04-25 | 1 | -47/+220 |
* | Refactor patching. | Ralf Corsepius | 2010-04-25 | 2 | -4/+19 |
* | Revert to gcc-3.4.4. | Ralf Corsepius | 2010-04-25 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 13 | -0/+13 |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 5 | -0/+5 |
* | Require gmp-4.2 if building mpc. | Ralf Corsepius | 2010-04-24 | 1 | -0/+1 |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 5 | -15/+55 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-24 | 5 | -5/+5 |
* | Regenerate. | Ralf Corsepius | 2010-04-24 | 13 | -78/+91 |
* | Revert last patch. | Ralf Corsepius | 2010-04-24 | 13 | -13/+13 |
* | Fix typo in comment. | Ralf Corsepius | 2010-04-24 | 1 | -5/+6 |
| | | | | | Use %{el6} to identify building for CentOS6/RHEL6. Reflect several packages are missing from RHEL6 Beta. | ||||
* | Regenerate. | Ralf Corsepius | 2010-04-23 | 13 | -104/+195 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-23 | 13 | -13/+13 |
* | newlib-1.18.0-rtems4.11-20100423.diff. | Ralf Corsepius | 2010-04-23 | 13 | -13/+13 |
* | New. | Ralf Corsepius | 2010-04-23 | 1 | -0/+1238 |
* | Add rhel6. | Ralf Corsepius | 2010-04-23 | 1 | -0/+7 |
* | Abandon freebsd7.2. | Ralf Corsepius | 2010-04-19 | 2 | -4/+0 |
* | Abandon freebsd7.2 | Ralf Corsepius | 2010-04-19 | 15 | -1407/+0 |
* | Regenerate. | Ralf Corsepius | 2010-04-19 | 7 | -13/+13 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2010-04-19 | 2 | -2/+2 |
* | Sync with amd64. | Ralf Corsepius | 2010-04-19 | 1 | -1/+1 |
* | Fix up Source0, Source1-URL. | Ralf Corsepius | 2010-04-19 | 1 | -2/+2 |
* | New. | Ralf Corsepius | 2010-04-19 | 9 | -0/+1232 |
* | Add netbsd5.0.2/amd64. | Ralf Corsepius | 2010-04-19 | 1 | -0/+1 |
* | Add am64 | Ralf Corsepius | 2010-04-19 | 1 | -1/+2 |
* | New (add amd64-netbsd*5). | Ralf Corsepius | 2010-04-19 | 1 | -0/+303 |
* | Abandon netbsd5.0.1 | Ralf Corsepius | 2010-04-19 | 2 | -4/+0 |
* | Remove. | Ralf Corsepius | 2010-04-19 | 15 | -1025/+0 |
* | Housekeeping. | Ralf Corsepius | 2010-04-19 | 3 | -3433/+0 |
* | New (Add i386*netbsdelf hack.) | Ralf Corsepius | 2010-04-19 | 1 | -0/+294 |
* | Bump *_RPMREL. | Ralf Corsepius | 2010-04-19 | 4 | -6/+6 |
* | New. | Ralf Corsepius | 2010-04-19 | 15 | -0/+1325 |
