path: root/contrib (unfollow)
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-2/+8
* Makefile.am: Cosmetics.
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-4/+12
2003-12-112003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-11/+11
2003-08-112003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-2/+10
2003-02-112003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-2/+10
2003-02-072003-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-31/+47
* i386-cygwin-gcc.spec.in: Use %_prefix instead of %prefix. Add gnatlib. Add %defattr(-,root,root). Provide virtual packages i386-cygwin-[c++|g++|gnat].
2003-01-282003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+16
* setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You must build and install a C only toolset first though.
2003-01-282003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+10
* .cvsignore: Add entries to .cvsignore.
2003-01-272003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+2
* setup.def, sparc-solaris-binutils.spec.in: Updated and used to build sparc-solaris 3.2.1-1 C language only. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2001-04-16 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Added missing files. * setup.def: New shot using gcc 3.0.4 RPMs. * sparc-solaris-binutils.spec.in: Switched to bz2 file. * sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive and use find to pick up all files. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-02-08 Joel Sherrill <joel@OARcorp.com> * .cvsignore: New file. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * Makefile.am: New file, missed previously. 2004-02-05 Joel Sherrill <joel@OARcorp.com> * ChangeLog, configure.ac, setup, setup.def, sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in, sparc-solaris-libs.spec.in: New files.
2003-01-272003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-5/+10
2003-01-272003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+13
* i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for revision 2.
2003-01-272003-01-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-18/+20
* i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def: Updated to current Cygwin versions and fixed some minor nits in the specifications. 2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * setup.def: Update to binutils-20021117-1. * i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1. Adaptations to RH-8.0/rpm-4.1. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. 2001-02-05 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in: Modified group. 2001-01-22 Joel Sherrill <joel@OARcorp.com> * i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in, i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest versions and packaging. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-09-13 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Corrected for missing files. 2001-08-31 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Missed in previous commit. 2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in, i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def: New files that support building RPMs for Linux hosted cross compilers targeting Cygwin.
2003-01-162003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-7/+15
2002-10-212002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-6/+18
2002-04-162001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-39/+27
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-6/+18
2002-02-082002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+10
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused with RTEMS. * r46kstub.c: Renamed to mips-stub.c. * mips-stub.c: New file -- was r46kstub.c. * memlimits.h: New file was limits.h. * limits.h: Removed. * r4600.h: Eliminated need for this file. * README: Updated. * gdb_if.h: Added CVS Id. * mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
2002-02-052001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-3/+8
2002-02-052001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+26
2002-02-052004-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill7-0/+429
2002-01-222001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill7-11/+18
2001-10-122001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+80
2001-10-122001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-78/+0
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+8
2001-09-132001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+10
2001-08-312001-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
2001-08-312001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-0/+565
