* | Add gcc/base-go.add and gcc/target-go.add. | Ralf Corsepius | 2011-04-20 | 1 | -0/+2 |
* | Eliminate $optargs | Ralf Corsepius | 2011-04-20 | 1 | -4/+4 |
* | Whitespace fixes. | Ralf Corsepius | 2011-04-03 | 1 | -1/+1 |
* | Add support for gcc-go tarballs. | Ralf Corsepius | 2011-04-03 | 1 | -0/+5 |
* | Reflect /go subdir handling having move into install.add. | Ralf Corsepius | 2011-04-03 | 1 | -2/+0 |
* | Handle /go subdirs. | Ralf Corsepius | 2011-04-03 | 1 | -1/+12 |
* | Remove @tool_target@-@tool_target@-gccgo. | Ralf Corsepius | 2011-04-03 | 1 | -0/+8 |
* | Don't ship libffi's man-pages. | Ralf Corsepius | 2011-04-03 | 1 | -0/+3 |
* | Regenerate. | Ralf Corsepius | 2011-04-02 | 27 | -52/+56 |
* | Abandon NoSource: | Ralf Corsepius | 2011-04-02 | 29 | -113/+0 |
* | Preps for gccgo. | Ralf Corsepius | 2011-04-02 | 2 | -0/+7 |
* | New. | Ralf Corsepius | 2011-04-02 | 2 | -0/+81 |
* | Add %build_go. | Ralf Corsepius | 2011-04-02 | 1 | -11/+13 |
| | | | | Cosmetics. | ||||
* | Regenerate. | Ralf Corsepius | 2011-03-26 | 14 | -191/+135 |
* | Reflect gcc-4.6.0 is out. | Ralf Corsepius | 2011-03-26 | 14 | -98/+42 |
| | | | | Abandon newlib-1.18.0 | ||||
* | Reflect gcc-4.6.0 is out. | Ralf Corsepius | 2011-03-26 | 12 | -24/+24 |
| | | | | Bump GCC_RPMREL. | ||||
* | New. | Ralf Corsepius | 2011-03-26 | 1 | -0/+433 |
* | newlib-1.19.0-rtems4.11-20110323.diff. | Ralf Corsepius | 2011-03-26 | 1 | -1/+1 |
* | gcc-core-4.6.0-RC-20110321-rtems4.11-20110323.diff | Ralf Corsepius | 2011-03-25 | 12 | -13/+13 |
* | Add missing dirent.h patch. | Ralf Corsepius | 2011-03-24 | 1 | -127/+143 |
* | New. | Ralf Corsepius | 2011-03-24 | 1 | -0/+3688 |
* | Regenerate. | Ralf Corsepius | 2011-03-24 | 14 | -112/+112 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-24 | 14 | -14/+14 |
* | newlib-1.19.0-rtems4.11-20110323.diff. | Ralf Corsepius | 2011-03-24 | 14 | -14/+14 |
* | Abandon | Ralf Corsepius | 2011-03-23 | 24 | -2618/+0 |
* | Abandon netbsd5.0.2. | Ralf Corsepius | 2011-03-23 | 2 | -5/+0 |
* | gcc-core-4.6.0-RC-20110321-rtems4.11-20110323.diff | Ralf Corsepius | 2011-03-23 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-03-23 | 2 | -16/+16 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-23 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-03-22 | 14 | -120/+279 |
* | Update to gcc-4.6.0-RC-20110321. | Ralf Corsepius | 2011-03-22 | 12 | -48/+48 |
* | Preps for gcc-4.6.0. | Ralf Corsepius | 2011-03-22 | 14 | -0/+98 |
* | Preps for gcc-4.6.0. | Ralf Corsepius | 2011-03-22 | 2 | -0/+5 |
* | Abandon. | Ralf Corsepius | 2011-03-21 | 24 | -2815/+0 |
* | Abandon freebsd8.1 | Ralf Corsepius | 2011-03-21 | 2 | -5/+0 |
* | Regenerate. | Ralf Corsepius | 2011-03-21 | 10 | -40/+142 |
* | GCC_VERS = 4.5.2. | Ralf Corsepius | 2011-03-21 | 10 | -20/+20 |
| | | | | GCC_RPMREL = 0.20110321.1. | ||||
* | Preps for gcc-4.5.2. | Ralf Corsepius | 2011-03-21 | 10 | -16/+78 |
* | New. | Ralf Corsepius | 2011-03-20 | 24 | -0/+2596 |
* | Add netbsd5.1. | Ralf Corsepius | 2011-03-20 | 2 | -0/+5 |
* | Eliminate RPM_OS. | Ralf Corsepius | 2011-03-20 | 1 | -17/+0 |
* | Add config.status, config.sub, config.log. | Ralf Corsepius | 2011-03-20 | 1 | -1/+3 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 1 | -4/+8 |
* | Rename amd64 into x86_64. | Ralf Corsepius | 2011-03-10 | 1 | -1/+1 |
* | Rename freebsd8.2/amd64/ into freebsd8.2/x86_64/. | Ralf Corsepius | 2011-03-10 | 1 | -1/+1 |
* | Remove bogus comment. | Ralf Corsepius | 2011-03-10 | 2 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 2 | -32/+18 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-10 | 2 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2011-03-10 | 4 | -52/+35 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2011-03-10 | 5 | -5/+5 |
