* | Ignore the build output. | Chris Johns | 2006-08-15 | 1 | -0/+1 |
* | binutils-2.17-rtems-20060812.diff | Ralf Corsepius | 2006-08-12 | 1 | -1/+1 |
* | Remove (Merged into binutils-2.17-rtems-20060812.diff). | Ralf Corsepius | 2006-08-12 | 1 | -13/+0 |
* | Update from binutils-2.17_branch. | Ralf Corsepius | 2006-08-12 | 1 | -0/+520 |
| | | | | Merge bfin patch. | ||||
* | Add bfin | Ralf Corsepius | 2006-08-12 | 1 | -0/+1 |
* | Reset RPMRELS. | Ralf Corsepius | 2006-08-12 | 1 | -3/+3 |
* | 2006-08-11 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-08-11 | 13 | -0/+22555 |
| | | | | | | | | | | | | | * configure.ac, gcc/build.add, gcc/target-gcc.add: Add bfin target prior to merge. Add ability to disable libssp and libstdcxx-pch which apparently are required to build the Blackfin port. * patches/binutils-2.17-rtems-bfin-20060810.diff, patches/gcc-4.1.1-bfinrtems-20060810a.diff, patches/gdb-6.5-bfinrtems-20060810a.diff, patches/newlib-1.14.0-bfinrtems-20060810a.diff, rtems4.7/bfin/.cvsignore, rtems4.7/bfin/Makefile.am, rtems4.7/bfin/binutils-sources.add, rtems4.7/bfin/gcc-sources.add, rtems4.7/bfin/gdb-sources.add: New files. | ||||
* | Bump RPMREL. | Ralf Corsepius | 2006-08-10 | 11 | -30/+30 |
* | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-09 | 2 | -0/+5 |
| | | | | * .cvsignore: Add INSTALL. | ||||
* | 2006-08-07 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-08-07 | 1 | -0/+37 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * build.sh: Log the script command lines. * build-rpms.sh: Updated to handle a different build processor to a i686. * build-exes.sh: Removed the tool version as Ralf has removed it from the rpms. 2006-08-05 Chris Johns <chrisj@rtems.org> * build-exes.sh: Update the release tag. 2006-08-04 Chris Johns <chrisj@rtems.org> * build-exes.sh: Updated to support the new installer. * build-rpms.sh: Updated to use common rather than base. More rpmbuild work arounds. * build.sh: Fix the return code when used with tee. * rtems.ini: Updated hello screen. * rtems-tools.nsi: Generate the batch files when installing. * AUTHORS, README: Convert to DOS format. 2006-07-22 Chris Johns <chrisj@rtems.org> * COPYING, build.sh, rtems-license.rtf: Changes to the installer and an extra script to build all. | ||||
* | Log the script command lines. | Chris Johns | 2006-08-07 | 1 | -0/+2 |
* | Updated to handle a different build processor to a i686. | Chris Johns | 2006-08-07 | 1 | -50/+47 |
* | Removed the tool version as Ralf has removed it from the rpms. | Chris Johns | 2006-08-07 | 1 | -5/+6 |
* | Update the release tag. | Chris Johns | 2006-08-05 | 1 | -1/+1 |
* | Updated to support the new installer. | Chris Johns | 2006-08-04 | 1 | -6/+25 |
* | Updated to use common rather than base. More rpmbuild work arounds. | Chris Johns | 2006-08-04 | 1 | -5/+12 |
* | Fix the return code when used with tee. | Chris Johns | 2006-08-04 | 1 | -4/+15 |
* | Updated hello screen. | Chris Johns | 2006-08-04 | 1 | -56/+59 |
* | Generate the batch files when installing. | Chris Johns | 2006-08-04 | 1 | -9/+81 |
* | Convert to DOS format. | Chris Johns | 2006-08-04 | 2 | -19/+19 |
* | Bump version. | Ralf Corsepius | 2006-08-03 | 1 | -1/+1 |
* | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 1 | -2/+2 |
* | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 11 | -30/+30 |
* | Remove (Obsolete) | Ralf Corsepius | 2006-08-03 | 1 | -50/+0 |
* | Remove | Ralf Corsepius | 2006-08-03 | 1 | -822/+0 |
* | Update to using newlib-1.14.0-rtems-20060707.diff | Ralf Corsepius | 2006-08-03 | 6 | -6/+6 |
* | Bump version. | Ralf Corsepius | 2006-08-02 | 1 | -1/+1 |
* | Use further shared spec-fragments. | Ralf Corsepius | 2006-08-02 | 2 | -0/+6 |
* | Split out target-autoconf.add | Ralf Corsepius | 2006-08-02 | 1 | -31/+2 |
* | Split out target-automake.add | Ralf Corsepius | 2006-08-02 | 1 | -30/+0 |
* | New. | Ralf Corsepius | 2006-08-02 | 2 | -0/+47 |
* | Add objc | Ralf Corsepius | 2006-07-25 | 2 | -2/+2 |
* | Remove sed -e /[@]tool_target[@]-newlib/d" | Ralf Corsepius | 2006-07-25 | 1 | -1/+0 |
* | Remove blank lines. | Ralf Corsepius | 2006-07-25 | 1 | -5/+5 |
* | More %if %build_newlib blocks. | Ralf Corsepius | 2006-07-25 | 2 | -0/+4 |
* | New. | Ralf Corsepius | 2006-07-25 | 1 | -0/+60 |
* | Fix rpmgroup. | Ralf Corsepius | 2006-07-25 | 2 | -26/+22 |
| | | | | Cosmetics. | ||||
* | Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 | Ralf Corsepius | 2006-07-25 | 1 | -2/+2 |
* | Bump version. | Ralf Corsepius | 2006-07-24 | 1 | -1/+3 |
| | | | | Add AC_CONFIG_FILES([autotools/Makefile]) | ||||
* | Add autotools. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 |
* | Add provisory/preliminary autotools support. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 |
* | Cleanup. | Ralf Corsepius | 2006-07-24 | 1 | -6/+3 |
| | | | | Add note on autotools. | ||||
* | New. | Ralf Corsepius | 2006-07-24 | 6 | -0/+235 |
* | Add Chris and Joel. | Ralf Corsepius | 2006-07-24 | 1 | -0/+8 |
* | 2006-07-23 Rename "*-base-*" packages into <tool>-common. | Ralf Corsepius | 2006-07-24 | 1 | -0/+5 |
| | | | | | | Rename GCC's "*-<lang>" packages into "*-gcc-<lang>". Many small directory ownership fixes. Build all GCC packages with --enable-threads. | ||||
* | Bump version | Ralf Corsepius | 2006-07-23 | 1 | -1/+1 |
* | Minor fixes. | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 |
* | Let rpm Obsolete < %{binutils_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 2 | -4/+8 |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -9/+10 |
| | | | | Rename *gfortran into *gcc-gfortran |
