2009-08-25 | Regenerate. | Ralf Corsepius | 1 | -6/+6 | |
2009-08-25 | gcc-core-4.3.2-rtems4.9-20090825.diff | Ralf Corsepius | 1 | -1/+1 | |
2009-08-25 | Bump GCC_RPMREL. | Ralf Corsepius | 1 | -1/+1 | |
2009-08-25 | avr: Use _exit from newlib | Ralf Corsepius | 1 | -0/+139 | |
2009-08-13 | Remove centos-4, tighten up suse, move fedora-9 to centos-5. | Ralf Corsepius | 1 | -12/+5 | |
2009-07-26 | Regenerate. | Ralf Corsepius | 2 | -4/+15 | |
2009-07-26 | Set amvers to 1.10. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-26 | Sync with rtems-4.10. | Ralf Corsepius | 4 | -9/+22 | |
2009-07-26 | Don't pass %{?dist} to *_RPM_REL | Ralf Corsepius | 1 | -2/+2 | |
2009-07-23 | Remove. | Ralf Corsepius | 3 | -359/+0 | |
2009-07-23 | Abandon cpukit. | Ralf Corsepius | 6 | -115/+0 | |
2009-07-23 | Abandon mingw32. | Ralf Corsepius | 1 | -1/+0 | |
2009-07-23 | Abandon cygwin, mingw. | Ralf Corsepius | 1 | -6/+0 | |
2009-07-23 | Abandon cygwin. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-23 | Regenerate. | Ralf Corsepius | 9 | -9/+9 | |
2009-07-23 | Update to newlib-1.16.0-rtems4.9-20090324.diff. | Ralf Corsepius | 9 | -9/+9 | |
2009-07-23 | Regenerate. | Ralf Corsepius | 10 | -60/+110 | |
2009-07-23 | Bump GCC_RPMREL. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-23 | Sync. with rtems-4.10. | Ralf Corsepius | 1 | -2/+2 | |
2009-07-21 | Regenerate. | Ralf Corsepius | 10 | -20/+20 | |
2009-07-21 | Sync with rtems-4.10. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-21 | Bump GDB_RPMREL. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-21 | New (Backport from rtems-4.10). | Ralf Corsepius | 1 | -0/+2151 | |
2009-07-21 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-21 | Sync with rtems-4.10. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-21 | Remove. | Ralf Corsepius | 1 | -16245/+0 | |
2009-07-20 | Bump GCC_RPMREL. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-20 | Regenerate. | Ralf Corsepius | 11 | -91/+371 | |
2009-07-20 | Sync with rtems-4.10. | Ralf Corsepius | 1 | -1/+1 | |
2009-07-20 | Remove %{?dist} from BINUTILS_RPMREL. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-20 | Update to gdb-6.8-rtems4.9-20090312.diff. | Ralf Corsepius | 9 | -9/+9 | |
2009-07-20 | Bump GDB_RPMREL. | Ralf Corsepius | 11 | -11/+11 | |
2009-07-20 | Sync with rtems-4.10 | Ralf Corsepius | 1 | -1/+1 | |
2009-07-19 | Regenerate. | Ralf Corsepius | 10 | -20/+20 | |
2009-07-19 | Bump BINUTILS_RPMREL. | Ralf Corsepius | 10 | -10/+10 | |
2009-07-18 | Sync with CVS-HEAD. | Ralf Corsepius | 1 | -1/+1 | |
2009-04-30 | Merge changes from CVS-HEAD addressing Fedora 11 rpm regressions. | Ralf Corsepius | 4 | -27/+50 | |
2009-04-08 | Bump version. | Ralf Corsepius | 1 | -1/+1 | |
2009-04-08 | Use mirrorlists. | Ralf Corsepius | 1 | -12/+6 | |
2009-04-07 | Add rtems.eu | Ralf Corsepius | 2 | -3/+6 | |
2009-03-30 | Backport from CVS-HEAD. | Ralf Corsepius | 1 | -0/+5 | |
2009-03-24 | Regenerate. | Ralf Corsepius | 1 | -6/+6 | |
2009-03-24 | Remove libc/machine/powerpc/times.c. | Ralf Corsepius | 1 | -0/+1199 | |
2009-03-24 | newlib-1.16.0-rtems4.9-20090324.diff | Ralf Corsepius | 1 | -1/+1 | |
2009-03-24 | Bump GCC_RPMREL. | Ralf Corsepius | 1 | -1/+1 | |
2009-03-12 | Regenerate. | Ralf Corsepius | 1 | -8/+36 | |
2009-03-12 | Bump GDB_RPMREL. | Ralf Corsepius | 1 | -1/+1 | |
2009-03-12 | gdb-6.8-rtems4.9-20090312.diff | Ralf Corsepius | 1 | -1/+1 | |
2009-03-12 | Add psim/configure. | Ralf Corsepius | 1 | -0/+2032 | |
2009-03-12 | Sync w/ cvs-head. | Ralf Corsepius | 2 | -6/+34 | |
