* | Regenerate. | Ralf Corsepius | 2009-08-25 | 1 | -6/+6 |
* | gcc-core-4.3.2-rtems4.9-20090825.diff | Ralf Corsepius | 2009-08-25 | 1 | -1/+1 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-08-25 | 1 | -1/+1 |
* | avr: Use _exit from newlib | Ralf Corsepius | 2009-08-25 | 1 | -0/+139 |
* | Remove centos-4, tighten up suse, move fedora-9 to centos-5. | Ralf Corsepius | 2009-08-13 | 1 | -12/+5 |
* | Regenerate. | Ralf Corsepius | 2009-07-26 | 2 | -4/+15 |
* | Set amvers to 1.10. | Ralf Corsepius | 2009-07-26 | 1 | -1/+1 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-26 | 4 | -9/+22 |
* | Don't pass %{?dist} to *_RPM_REL | Ralf Corsepius | 2009-07-26 | 1 | -2/+2 |
* | Remove. | Ralf Corsepius | 2009-07-23 | 3 | -359/+0 |
* | Abandon cpukit. | Ralf Corsepius | 2009-07-23 | 6 | -115/+0 |
* | Abandon mingw32. | Ralf Corsepius | 2009-07-23 | 1 | -1/+0 |
* | Abandon cygwin, mingw. | Ralf Corsepius | 2009-07-23 | 1 | -6/+0 |
* | Abandon cygwin. | Ralf Corsepius | 2009-07-23 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2009-07-23 | 9 | -9/+9 |
* | Update to newlib-1.16.0-rtems4.9-20090324.diff. | Ralf Corsepius | 2009-07-23 | 9 | -9/+9 |
* | Regenerate. | Ralf Corsepius | 2009-07-23 | 10 | -60/+110 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-07-23 | 10 | -10/+10 |
* | Sync. with rtems-4.10. | Ralf Corsepius | 2009-07-23 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2009-07-21 | 10 | -20/+20 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-21 | 10 | -10/+10 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-07-21 | 10 | -10/+10 |
* | New (Backport from rtems-4.10). | Ralf Corsepius | 2009-07-21 | 1 | -0/+2151 |
* | Regenerate. | Ralf Corsepius | 2009-07-21 | 1 | -1/+1 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-21 | 1 | -1/+1 |
* | Remove. | Ralf Corsepius | 2009-07-21 | 1 | -16245/+0 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-07-20 | 10 | -10/+10 |
* | Regenerate. | Ralf Corsepius | 2009-07-20 | 11 | -91/+371 |
* | Sync with rtems-4.10. | Ralf Corsepius | 2009-07-20 | 1 | -1/+1 |
* | Remove %{?dist} from BINUTILS_RPMREL. | Ralf Corsepius | 2009-07-20 | 10 | -10/+10 |
* | Update to gdb-6.8-rtems4.9-20090312.diff. | Ralf Corsepius | 2009-07-20 | 9 | -9/+9 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-07-20 | 11 | -11/+11 |
* | Sync with rtems-4.10 | Ralf Corsepius | 2009-07-20 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2009-07-19 | 10 | -20/+20 |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2009-07-19 | 10 | -10/+10 |
* | Sync with CVS-HEAD. | Ralf Corsepius | 2009-07-18 | 1 | -1/+1 |
* | Merge changes from CVS-HEAD addressing Fedora 11 rpm regressions. | Ralf Corsepius | 2009-04-30 | 4 | -27/+50 |
* | Bump version. | Ralf Corsepius | 2009-04-08 | 1 | -1/+1 |
* | Use mirrorlists. | Ralf Corsepius | 2009-04-08 | 1 | -12/+6 |
* | Add rtems.eu | Ralf Corsepius | 2009-04-07 | 2 | -3/+6 |
* | Backport from CVS-HEAD. | Ralf Corsepius | 2009-03-30 | 1 | -0/+5 |
* | Regenerate. | Ralf Corsepius | 2009-03-24 | 1 | -6/+6 |
* | Remove libc/machine/powerpc/times.c. | Ralf Corsepius | 2009-03-24 | 1 | -0/+1199 |
* | newlib-1.16.0-rtems4.9-20090324.diff | Ralf Corsepius | 2009-03-24 | 1 | -1/+1 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-03-24 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2009-03-12 | 1 | -8/+36 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-03-12 | 1 | -1/+1 |
* | gdb-6.8-rtems4.9-20090312.diff | Ralf Corsepius | 2009-03-12 | 1 | -1/+1 |
* | Add psim/configure. | Ralf Corsepius | 2009-03-12 | 1 | -0/+2032 |
* | Sync w/ cvs-head. | Ralf Corsepius | 2009-03-12 | 2 | -6/+34 |
