* | Sync with CVS-HEAD. | Ralf Corsepius | 2009-02-07 | 9 | -25/+20 | |
* | Regenerate. | Ralf Corsepius | 2009-02-07 | 10 | -145/+89 | |
* | Add NEWLIB_PKGVERS, NEWLIB_RPMREL. | Ralf Corsepius | 2009-02-07 | 1 | -0/+2 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-02-07 | 10 | -10/+30 | |
| | | | | Add NEWLIB_PKGVERS, NEWLIB_RPMREL. | |||||
* | newlib-1.16.0-rtems4.9-20090207.diff | Ralf Corsepius | 2009-02-07 | 10 | -10/+10 | |
* | Remove newlib/libc/include/sched.h. | Ralf Corsepius | 2009-02-07 | 1 | -0/+1079 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-01-21 | 20 | -40/+120 | |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2009-01-21 | 20 | -40/+120 | |
* | Bump RPMREL. | Ralf Corsepius | 2009-01-21 | 3 | -8/+24 | |
* | Regenerate. | Ralf Corsepius | 2009-01-20 | 11 | -66/+286 | |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-01-20 | 11 | -11/+11 | |
* | Sync with CVS-HEAD. | Ralf Corsepius | 2009-01-20 | 1 | -2/+10 | |
* | Regenerate. | Ralf Corsepius | 2008-12-14 | 10 | -69/+79 | |
* | GCC_RPMREL = 18%{?dist}. | Ralf Corsepius | 2008-12-14 | 10 | -10/+10 | |
* | Activate c++. | Ralf Corsepius | 2008-12-14 | 1 | -2/+2 | |
* | Abandon gcc-4.3.1. | Ralf Corsepius | 2008-12-14 | 10 | -59/+19 | |
| | | | | | newlib-1.16.0-rtems4.9-20081203.diff gcc-core-4.3.2-rtems4.9-20081214.diff. | |||||
* | Remove rs6000 MULTILIB_EXTRA_OPTS. | Ralf Corsepius | 2008-12-14 | 1 | -0/+130 | |
* | Regenerate. | Ralf Corsepius | 2008-12-14 | 10 | -40/+40 | |
* | binutils-2.19. | Ralf Corsepius | 2008-12-14 | 10 | -20/+20 | |
* | Update. | Ralf Corsepius | 2008-12-05 | 1 | -2/+2 | |
* | Regenerate. | Ralf Corsepius | 2008-12-05 | 1 | -3/+3 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-12-05 | 1 | -1/+1 | |
* | Make c99 io default. | Ralf Corsepius | 2008-12-05 | 1 | -0/+1061 | |
| | | | | Add prototype for ttyname_t. | |||||
* | gcc/config/rs6000/t-rtems: Fix silly typo. | Ralf Corsepius | 2008-12-05 | 1 | -0/+125 | |
| | | | | gcc/config/arm/rtems-elf.h: Undefine LINK_GCC_C_SEQUENCE_SPEC. | |||||
* | Update. | Ralf Corsepius | 2008-11-19 | 6 | -29/+57 | |
* | Regenerate. | Ralf Corsepius | 2008-11-10 | 10 | -0/+40 | |
* | Regenerate. | Ralf Corsepius | 2008-11-10 | 10 | -50/+420 | |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2008-11-10 | 10 | -10/+10 | |
* | Sync with CVS-HEAD. | Ralf Corsepius | 2008-11-10 | 1 | -1/+2 | |
* | Regenerate. | Ralf Corsepius | 2008-11-08 | 10 | -40/+180 | |
* | Bump BINUTILS_RPMREL. | Ralf Corsepius | 2008-11-08 | 10 | -10/+10 | |
* | Import changes from HEAD. | Ralf Corsepius | 2008-11-07 | 1 | -0/+4 | |
* | Sync with CVS-HEAD. | Ralf Corsepius | 2008-11-06 | 3 | -2/+26 | |
* | Remove cpukit (Unsupported). | Ralf Corsepius | 2008-11-06 | 10 | -61/+0 | |
* | Remove (Unsupported). | Ralf Corsepius | 2008-11-06 | 21 | -1289/+0 | |
* | Abandon freebsd7.0 | Ralf Corsepius | 2008-11-05 | 2 | -4/+0 | |
* | Abandon solaris2.7 | Ralf Corsepius | 2008-11-05 | 2 | -4/+0 | |
* | Add %sysdir %{_prefix} to cater rpm5. | Ralf Corsepius | 2008-10-28 | 2 | -0/+2 | |
* | Sync with HEAD. | Ralf Corsepius | 2008-10-24 | 5 | -16/+22 | |
* | Bump AUTOCONF_RPMREL, AUTOMAKE_RPMREL. | Ralf Corsepius | 2008-10-16 | 3 | -4/+4 | |
* | New. | Ralf Corsepius | 2008-10-16 | 2 | -0/+352 | |
* | Backport from CVS-HEAD. | Ralf Corsepius | 2008-10-16 | 1 | -3/+15 | |
* | Remove. | Ralf Corsepius | 2008-09-18 | 1 | -1041/+0 | |
* | Update to gdb-6.8-rtems4.9-20080917.diff. | Ralf Corsepius | 2008-09-18 | 30 | -40/+40 | |
* | Sync with rtems-4.10. | Ralf Corsepius | 2008-09-18 | 1 | -0/+1740 | |
* | Regenerate. | Ralf Corsepius | 2008-09-10 | 10 | -0/+10 | |
* | Remove. | Ralf Corsepius | 2008-09-10 | 1 | -117/+0 | |
* | Remove freebsd6.* | Ralf Corsepius | 2008-09-10 | 2 | -8/+0 | |
* | Remove rtems-4.10. | Ralf Corsepius | 2008-09-10 | 2 | -14/+0 | |
* | branch cleanup. | Ralf Corsepius | 2008-09-10 | 111 | -13279/+0 | |
