* | New. | Ralf Corsepius | 2007-02-22 | 1 | -0/+107 |
* | Preps for gcc-4.1.2. | Ralf Corsepius | 2007-02-20 | 9 | -0/+27 |
* | Preps for gdb-6.6. | Ralf Corsepius | 2007-02-20 | 10 | -0/+50 |
* | New (Identical to gdb-6.6-rtems4.8-20070218.diff). | Ralf Corsepius | 2007-02-20 | 1 | -0/+48 |
* | New (Identical to gcc-core-4.1.2-rtems4.8-20070216.diff) | Ralf Corsepius | 2007-02-20 | 1 | -0/+69 |
* | Add GCC_PGKVERS (Sync with rtems-4.8). | Ralf Corsepius | 2007-02-20 | 9 | -0/+9 |
* | Sync with rtems-4.8. | Ralf Corsepius | 2007-02-20 | 5 | -8/+9 |
* | Add GDB_OPTS | Ralf Corsepius | 2007-02-20 | 11 | -1/+13 |
* | Increment BINUTILS_RPMREL | Ralf Corsepius | 2007-02-19 | 9 | -9/+9 |
* | Cosmetics | Ralf Corsepius | 2007-02-19 | 1 | -1/+1 |
* | 2007-02-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-19 | 4 | -1/+46 |
| | | | | | | * configure.ac: Bump version to 0.5. * apt/sources.list.d/rtems.list.in, yum.repos.d/rtems.repo.in: Add rtems/testing repos. | ||||
* | Sync. with rtems-4.8. | Ralf Corsepius | 2007-02-18 | 1 | -0/+3 |
* | Fix URL. | Ralf Corsepius | 2007-02-17 | 10 | -10/+10 |
* | Add || : to install-info. | Ralf Corsepius | 2007-02-17 | 1 | -10/+10 |
* | Misc. backports from rtems-4.8 | Ralf Corsepius | 2007-02-17 | 3 | -1/+10 |
* | Add ||: to install-info. | Ralf Corsepius | 2007-02-17 | 7 | -40/+40 |
* | Sync with 4.8 | Ralf Corsepius | 2007-02-14 | 1 | -0/+17 |
* | Bump RPMRELS. | Ralf Corsepius | 2007-02-14 | 1 | -2/+2 |
* | Add ||: | Ralf Corsepius | 2007-02-14 | 1 | -2/+2 |
* | Sync with rtems-4.8 | Ralf Corsepius | 2007-02-14 | 5 | -17/+53 |
* | Upgrade to newlib-1.15.0-rtems4.7-20070208.diff | Ralf Corsepius | 2007-02-08 | 9 | -9/+9 |
* | Remove (Obsolete). | Ralf Corsepius | 2007-02-08 | 1 | -862/+0 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2007-02-08 | 9 | -9/+9 |
* | New. | Ralf Corsepius | 2007-02-08 | 1 | -0/+1402 |
* | Remove. | Ralf Corsepius | 2007-01-28 | 1 | -838/+0 |
* | New. | Ralf Corsepius | 2007-01-12 | 1 | -0/+140 |
* | Upgrade to gcc-core-4.1.1-rtems4.7-20070102.diff | Ralf Corsepius | 2007-01-12 | 9 | -9/+9 |
* | Bump GCC_RPMREL = 6 | Ralf Corsepius | 2007-01-12 | 8 | -8/+8 |
* | Upgrade to newlib-1.15.0 | Ralf Corsepius | 2007-01-12 | 18 | -18/+18 |
* | Add newlib-1.15.0 support. | Ralf Corsepius | 2007-01-12 | 9 | -0/+27 |
* | New. | Ralf Corsepius | 2007-01-12 | 1 | -0/+862 |
* | Add BINUTILS += | Ralf Corsepius | 2007-01-12 | 9 | -0/+9 |
* | Add BINUTILS_OPTS. | Ralf Corsepius | 2007-01-12 | 1 | -1/+3 |
* | Update bugfix address | Ralf Corsepius | 2007-01-10 | 1 | -2/+1 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 8 | -4/+20 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | This commit was manufactured by cvs2svn to create branch 'rtems-4-7-branch'. | cvs2git | 2006-11-15 | 1 | -0/+0 |
| | | | | | Cherrypick from master 2006-11-15 14:12:01 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org>': ampolish3 contrib/repo-conf/ChangeLog | ||||
* | 2006-11-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-14 | 1 | -0/+5 |
| | | | | | * configure.ac, Makefile.am, rtems-4.7/Makefile.am: Remove tic4x. * rtems-4.7/tic4x/: Remove. | ||||
* | Remove tic4x | Ralf Corsepius | 2006-11-14 | 2 | -2/+0 |
* | Remove. | Ralf Corsepius | 2006-11-14 | 5 | -72/+0 |
* | Bumb version to 0.4 | Ralf Corsepius | 2006-10-25 | 1 | -1/+1 |
* | Let rtems-@RTEMS_API@-repo-conf.spec depend on configure.ac | Ralf Corsepius | 2006-10-25 | 1 | -1/+1 |
* | Bump version to 0.3 | Ralf Corsepius | 2006-10-24 | 1 | -1/+1 |
* | New URL ftp://ftp.rtems.org/pub/rtems/linux | Ralf Corsepius | 2006-10-24 | 2 | -6/+6 |
* | s/binutils-2.17-rtems4.7-20060921/binutils-2.17-rtems4.7-20061021/ | Ralf Corsepius | 2006-10-24 | 10 | -10/+10 |
* | Remove (Unused) | Ralf Corsepius | 2006-10-24 | 3 | -738/+0 |
* | Resurrect (Still in use ;) | Ralf Corsepius | 2006-10-24 | 1 | -0/+97 |
* | Remove (Unused) | Ralf Corsepius | 2006-10-24 | 1 | -60/+0 |
* | Remove (Unused). | Ralf Corsepius | 2006-10-24 | 1 | -97/+0 |
* | New. | Ralf Corsepius | 2006-10-24 | 1 | -0/+556 |
